Roksan Kandy K2 TR-5 Loudspeaker
tsip
19 January 2008
1,912
Cambridge
ΑμανΑμανΑμαν...
Λουκουμακια μου φαινονται, τα εχει ακουσει κανεις, ο αντιπροσωπος τα έχει φέρει? Το whathifi γραφει τα καλυτερα.
Ριμπον τουιτερ και καστομ γουφερ :grinning-smiley-043
Τιμη 800 λιρες
Ιδου ολιγα σπεκς:
[FONT=Verdana, Arial, Helvetica, sans-serif]Features[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]130mm high power handling custom designed woofer[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Custom designed treated & coated paper woofer cone[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Cast woofer chassis for extra rigidity[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]High tolerance dedicated ribbon tweeter[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Tweeter dispersion damping foam[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Internally braced, double cavity 15 mm high quality MDF cabinet[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]High quality 2oz copper, double sided X-over PCB[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Large, low impedance, air core X-over coils [/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]5% tolerance metalised polyester X-over capacitors[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]High quality, gold plated bi-wireable speaker binding terminals[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Fire retardant, high absorption internal acoustic damping foam[/FONT] (μονο για αυτο τα αγοραζω :)
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Tolerance matched compensation circuit components
    Specifications
    Tweeter High tolerance dedicated Ribbon
    Woofer Custom designed, 130mm coated paper
    Cast chassis with double magnets
    [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
    Input Sensitivity (1W, 1m) >88 dB
    Impedance >6Ω
    Frequency response 39 Hz – 20 kHz (in room response)
    55 Hz – 20kHz (-6dB)
    Nominal Power Handling 60 Watts
    Peak Power Handling 100 Watts
    Dimensions 190 x 280 x 370 (W x D x H) mm
    Weight 8.0 Kg
    [/FONT]
http://www.roksan.co.uk/
http://whathifi.com/Review/Roksan-Kandy-K2-speakers/
Άκουσε κανείς αυτά τα ηχεία?
Στην Ελλάδα μπορεί να τα βρεί κανείς πουθενά?
Τότε στείλε ένα e-mail εδώ [email protected] και ρώτα τους αν μπορείς να το βρείς σε Ελληνικό μαγαζί.
Πάντως στα 1000 Ευρώ που είναι αυτό, μπορείς να βρείς πάρα πολλά και εξαιρετικά ηχεία βάσης. Δεν είναι ανάγκη να είναι Roksan....
Μη δίνεις σημασία στα review των ηχείων. Αν δεν ακούσεις δεν μπορείς να καταλάβεις τίποτα.
Ναι, σίγουρα, απλώς έχουν ρίμπον και κάστομ γούφερ και η Roksan είναι σοβαρή εταιρεία.
Μα φυσικά τα έχω δει στο συγκεκριμένο site, αλλά θα αγόραζε κανείς ηχεία χωρίς να τα έχει ακούσει!?
