Samsung Blu-Ray / HD-DVD player
GeonX
2,756
Το είχαμε αναφέρει και παλιότερα όταν ακούστηκαν οι πρώτες φήμες (Σεπτ. 05) αλλά από ότι φαίνεται η Samsung προχωράει προσεκτικά (λόγο Sony ) στην κατασκευή ενός hydrid player που θα υποστηρίζει και τα δυο format… μπορεί η Sony και η Toshiba να έχουν τι δική τους agenda αλλά είναι ξεκάθαρο ότι οι υπόλοιποι κατασκευαστές δεν σκοπεύουν να τα βάλουν όλα σε ένα καλάθι…
Samsung considering hybrid Blu-ray, HD-DVD player
by Cyril Kowaliski - 04:20 pm, June 21, 2006
With its first Blu-ray player just days away from hitting store shelves, Samsung has revealed that it is building a hybrid drive with support for both Blu-ray and HD-DVD formats. At a briefing in Samsung's South Korea HQ, company Home-Platform Product Planning Assistant Manager Kim Du-Hyon stated the following:
"We don't have a plan to make an HD DVD-only player but are considering a universal player," he said. "We are preparing HD DVD [support] now and if we launch a universal player it will be the end of this year or early next year."
Kim underlined Samsung's belief that Blu-ray Disc will beat HD DVD in the commercial marketplace, but said Samsung will consider a universal player should HD DVD prove as successful as Blu-ray Disc.
If Samsung chooses to introduce a hybrid player, it will join LG as one of the first manufacturers to unite the two formats. Three months ago, LG disclosed that it had a hybrid Blu-ray/HD-DVD player in the pipeline for a release in the fall. This type of convergence may bode well for consumers, but neither LG nor Samsung seems to have indicated a price range for their hybrid players. Considering the $1,000 launch price for Samsung's upcoming BD-P1000 Blu-ray player and the $461-499.99 street price of Toshiba's HD-DVD player, hybrid models may not be cheap.
http://techreport.com/onearticle.x/10221
συμφωνω με Θανο,
η SONY ελεγχει τα μεγαλυτερα στουντιο και επισης κατι σημαντικο μαζι της ειναι και αρκετοι κατασκευαστες συσκευων που σημαινει οτι δεν περιοριζεται ο καταναλωτης αλλα εχει την δυνατοτητα να διαλεξει
ενω στην αντιπερα οχθη η επιλογη TOSHIBA ειναι μονοδρομος
Ναι μεν αλλά...
Πιστεύω ότι το τελευταίο που θα μας συνέφερε ως καταναλωτές, θα ήταν να επικρατήσει ολοκληρωτικά η Sony σε αυτόν το πόλεμο των φορμά και να επιβάλει στη παγκόσμια αγορά τις συνηθισμένες μονοπωλιακές τακτικές της.
Καλώς ή κακώς, η Sony έχει δείξει άπειρες φορές στο παρελθόν την αλαζονεία της, όπως επίσης και το ΠΟΥ ακριβώς γράφει τον τελικό καταναλωτή καθώς και τα ανθρώπινα δικαιώματά του, όπως είναι τα προσωπικά δεδομένα, κτλ.
Μου είναι πραγματικά δύσκολο να αντιληφθώ ότι μια εταιρεία με το μέγεθος της Sony αδυνατεί να συνειδητοποιήσει ότι έχει εμπλακεί σε ένα ατελέσφορο κυνήγι μαγισσών όσον αφορά τη μουσική βιομηχανία, όπως επίσης και το γεγονός ότι δεν μπορεί να κερδίσει τον πόλεμο που έχει κηρύξει κατά των απανταχού χακεράδων του πλανήτη. Είναι σαν να κυνηγάς τον άνεμο και να ελπίζεις ότι όχι μόνο θα τον πιάσεις, αλλά θα τον βάλεις και στη φυλακή! :D
Νομίζω πως τελικά θα επικρατήσουν οι players που υποστηρίζουν και τα δύο φορμά. Από συζήτηση που είχαμε και παλιότερα στο forum αυτή ήταν και η άποψη των περισσοτέρων. Δεν θα ήθελα να σκεφθώ το σενάριο ότι τελικά επικρατεί ο ένας ή ο άλλος και όπως λέει και ο Παναγιώτης, ο Θεός να μας φυλάει από το μονοπώλιο της Sony. Εκτός κι αν θεσπιστεί ένα νομικό πλαίσο που διαφυλάξει τους υπόλοιπους κατασκευαστές από μονοπωλιακές τακτικές.
