- 17 June 2006
- 5,410
Τον Αύγουστο του 2011 η θαυματουργή Samyang προανήγγειλε άλλη μία προσθήκη στη σειρά των prime manual focus φακών, διαθέσιμη για όλες σχεδόν τις μοντούρες.
Εναν 24άρη f/1.4.
Εναν 24άρη f/1.4.
Optics of the lens has been constructed based on the system of 13 lenses arranged in 12 groups. It should be noted that 4 lenses has been made of the low-dispersion glass (ED), while two another are aspheric lenses. We have also employed multi-layered and anti-reflection coatings of UMC type adding to the perfect light transmission. Samyang 24 mm F1.4 ED AS UMC has been designed to work with most popular reflex cameras produced by renown manufacturers and equipped with small-image sensors or smaller. The lens will be available with a mount for the following systems: Canon, Four Thirds, Nikon AE, Pentax, Samsung NX and Sony Alpha.
24mm focus is tailor-made for most of the sensors available on the market today. In the case of full-frame cameras, it constitutes a high-quality wide-angle lens perfect for street, landscape and architecture shooting. Whereas photographers using DX sensors will get just perfect lens for the purposes of calmer journalist and landscape photography. The lens attached to Four Thirds cameras will create a universal and bright construction corresponding to the 50mm focal length.
