Καλησπερα. ηθελα να ρωτησω επειδη διαβαζω συνεχεια για τα dac .
Εχω την msi 970 gaming η οποια εχει ενσωματωμενη καρτα ηχου με τα εξης χαρακτηριστικα.
τα εχω συνδυασει με τα edifier r1800t και ο ηχος ειναι εξαιρετικος (τουλαχιστον για τα αυτια μου)
τα συνδεω με minijack σε rca . Η αναλυση στην καρτα ηχου ειναι στα 24bit/192000hz.
το ερωτημα ειναι εχει μεγαλη διαφορα ενα μικρο (φτηνονο ) dac?
η ειναι μια διαφορα που δεν θα καταλαβω ευκολα.
ουσιαστικα και η καρτα μου δεν λειτουργει σαν dac εφοσον το ψηφιακο σημα το παιρνω αναλογικα για τα ενεργα ηχεια μου?
ευχαριστω για τις τυχον απαντησεις.
With golden audio connectors you get the best possible signal output with less chance of distortion.
Get ready for ear-drum shattering sound, with MSI Audio Boost 2! With Audio Boost 2 we're delivering the highest audio quality with the use of Creative Sound Blaster Cinema 2 so you can enjoy crystal clear sound and music through 8-channel HD Audio.
ISOLATED AUDIO PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Audio Boost 2 acts like a dedicated soundcard by physically isolating the audio circuitry which is separated by a red LED path. Less interference gives you a more clear audio signal.
CREATIVE SOUND BLASTER CINEMA 2
Thanks to Creative Sound Blaster Cinema 2, you're getting amazing surround sound with just stereo headphones or speakers.
Creative Sound Blaster Cinema 2 enables you to clearly hear specific sounds in gaming environments. Hear your enemies perfectly, make your ears a decisive tool to finish on top.
EMI SHIELDING
To shield the audio core from EMI (Electromagnetic Interference) caused by other add-in cards the audio chip is protected by a high-grade EMI cover with backlight illumination.
DUAL HEADHPONE AMPLIFIERS
Prepare for an eargasm. The built-in dual headphone amplifier rewards your high quality headphone with the most amazing studio level sound quality up to 600Ω delivered from your gaming PC.
Tired of having to connect your headset in difficult to reach places? MSI GAMING motherboards are designed to be easy to use, featuring front & rear audio outputs fueled by Audio Boost 2.
HIGH QUALITY AUDIO CAPACITORS
With the use of professional Nichicon Japanese capacitors, specially designed for audio purposes, MSI GAMING motherboards provide the highest possible audio signal filtering. Delivering high fidelity crystal clear sound with exceptional acoustics and realism.
GOLDEN AUDIO CONNECTORS
- Up to 600Ω crystal clear sound with exceptional acoustics
- Dedicated amplified output (red) optimized for studio-grade headgear
- Superb signal conductivity and will not wear over time
ISOLATED AUDIO PCB
EMI SHIELDING
- Acoustic series
- Lower Tolerance
- Lower Dielectric Absorption
- Lower ESR
- Lower Leakage Current
- Higher Stability
