Sherwood R-872
marios
20 June 2006
491
Ξέρει κανείς τον εν λόγω ενισχυτή?
Γενικά έχετε άποψη για τους sherwood?
Είχα πάει σε μαγαζί για να δω τους Yamaha 1800 & Onkyo 705
και είδα ένα σχετικό φυλλάδιο γι αυτούς.
Πάντως στα spec είναι πολύ καλός ....
* 100 Watts per Channel from 20 Hz-20 kHz in Stereo Mode, 8 ohms, with <0.05% THD
* 100 Watts per Channel x 7 in Surround Mode
* 4 in 1 out HDMI 1.3 switching
* Scales all video to 720p/1080i/1080p
* Faroudja 2301 Scaler/Deinterlacer
* Decodes DTS Master Audio HD and Dolby Tru HD
* DTS-ES Discrete and Matrix
* DTS-96/24 DTS
* DTS NEO-6 Cinema and Music
* Dolby Digital EX
* Adjustable Dolby Pro Logic IIx
* Dolby Headphone Layers 1, 2, 3
* Digitally Re-Masters PCM input to 96 kHz/ 24-bit
* Automatic Format Detection
* 192 kHz 24-bit DAC’s for all channels
* Dolby Virtual Speaker
* Pure Audio Mode
* Crossover frequency 40 to 250 Hz
* A/V Synch delay by input
* Firmware upgradeable
* SNAP 12-band EQ per channel
* RS-232 and USB
* Universal Video™ upconverts composite and S-Video to Component Video
* 4 Optical and 2 Co-ax Digital Inputs
* Digital Output
* On Screen Display (available from all video outputs)
* RF + IR Learning remote with LCD display
* Programmable Input Labeling
* Crystal 32-Bit DSP processor
* 8 DSP Modes
* 7.1 channel direct input
* 8 Pre-Amp Outputs (L, C, R, L. Surround, L Rear Center Surround, R Rear Center Surround, R. Surround, Subwoofer)
* Room 2 A/V Output w/ fixed/variable audio level, S-Video
* Automatic 7.1 to 5.1 + Stereo
* Lockable "Installer Memory"
* Rear Panel Room-2 IR control with 1 input and 1 output
* Dedicated Room 2 Remote
* 12-Volt Trigger
* 3 HDTV-Ready Component Video Inputs
* Component Video Output
* 4 Rear Panel Audio/Video Inputs
* 4 Audio Inputs
* Front Panel A/V Input Including S-Video and Optical Digital
* Cinema EQ
* Tone Defeat
* Automatic set-up for speaker level and distance
* Channel Level Memory
* 10-step Dynamic Range Control
* Totally Discrete Amplifier Stage (TDAS)
* Heavy Duty Speaker Binding Posts
* XM Connect and Play XM Neural Surround
* 4 Gang FM tuner
* Preset Scan
* 30 XM Presets
* 30 AM/FM Station Presets
* Digi-Link III
* Sleep Timer
* Aluminum Front Panel Dimensions: 17 3/8" W x 6" H x 15" D
