SONY 400 Blu-ray Discs Mega Changers
kblachos
18 February 2009
17,144
ΑΓΙΟΙ ΑΝΑΡΓΥΡΟΙ
Η SONY ανακοίνωσε την κυκλοφορία 2 νέων Blue Ray /DVD /CD Mega changers με χωρητικότητα 400 δίσκων!!!
Πρόκειται για τα BDP-CX7000ES και BDP-CX960.
Το εισαγωγικό μοντέλο BDP-CX960 είναι profile 2.0 έχει ενσωματωμένους αποκωδικοποιητές για HD ήχο και η τιμή του θα είναι περίπου 800 δολάρια.
Το ποιό ποιοτικό BDP-CX7000ES, διαθέτει επιπλέον 7.1 αναλογικές εξόδους, θύρα RS-232, και καλύτερη ποιότητα κατασκευής. Η τιμή του θα κυμαίνεται κοντά στα 1.700 δολάρια.
http://news.cnet.com/8301-17938_105-10293079-1.html?tag=mncol;title
http://www.fullhd.gr/hd-players/dvd/1689-sony-bdp-cx7000es-a-bdp-cx960-.html
Sony announced the first Blu-ray megachanger back in 2007, and now, two years later, the company is following up on the effort. The BDP-CX960 ($800, coming in the fall) and BDP-CX7000ES ($2,000, coming in August) both hold 400 Blu-ray Discs and use Gracenote's VideoID and MusicID service to automatically retrieve disc data over an Ethernet connection. That's big news, as our biggest complaint with Sony's older DVD megachanger was how tedious it was to manually enter program data.
Sony BDP-CX7000ES
The entry-level BDP-CX960 comes equipped with all the features that are now standard on Blu-ray players, including Profile 2.0 compatibility and onboard decoding for Dolby TrueHD and DTS-HD Master Audio.
The step-up BDP-CX7000ES adds 7.1 analog outputs, an RS-232 port, better build quality, IR inputs and outputs, plus Sony is claiming superior video performance, thanks to technology like the Sony's HD Reality Enhancer. In Sony's words, the HD Reality Enhancer "continually analyzes the original source bit by bit, sharpening edges and reproducing detail, while reducing the effects of film grain." That sounds similar to Toshiba's XDE processing, which were weren't exactly fans of. The BDP-CX7000ES's upgrades don't seem nearly significant enough to justify the $1,200 price increase, but this model is clearly aimed at the "price is no object" crowd that will be taking advantage of the custom installer options.
Both players will use Sony's XMB interface to handle navigating the giant media libraries. We're definitely fans of the XMB interface on the PS3 and AV receivers, but we're interested to see how Sony has adapted it to handle media libraries.
While it's true that most buyers won't have 400 Blu-ray Discs in their collections, the idea of a megachanger than can consolidate all your discs (Blu-rays, DVDs and CDs) still has some merit. On the other hand, we're surprised that neither player has integrated Wi-Fi or any streaming-video capabilities, which are available on considerably cheaper players.
Επίσης, μαζί με την κυκλοφορία των 2 αυτών players, ανακοινώθηκε και η κυκλοφορία του BDP-S1000ES.
Πρόκειται για ένα ακόμη player της σειράς ES, θα έχει ενσωματωμένο wi-fi και αποκωδικοποιητές ήχου HD.
http://www.itechnews.net/2009/07/23/sony-bdp-cx960-bdp-cx7000es-blu-ray-megachangers-and-bdp-s1000es-blu-ray-player/
Sony BDP-S1000ES Blu-ray Player
Along with MegaChangers, Sony brings the BDP-S1000ES, which is also part of the ES line. It also offers full HD 1080/60p and 24p True Cinema output, DVD upscaling hrough Sony’s Precision Cinema HD Upscale technology, and built-in WiFi 802.11a/b/g/n connectivity for easy BD-Live access. It includes also HD Reality Enhancer, Super Bit Mapping, and Precision Drive HD technology. It costs $700 and will be released in August.
Other than Blu-ray video discs, all these Blu-ray players support DVD+/-Video/R/RW, CD/R/RW, and MP3/JPEG on BD/DVD/CD recordable media as well as AVCHD video. They all support 7.1 channel Dolby TrueHD and Dolby Digital Plus, DTS-HD High Resolution Audio, and DTS-HD Master Audio decoding as well as bit-stream output via HDMI. The BDP-CX7000ES also supports Deep Color via HDMI (v1.3).
Άν το μηχάνημα είχε χωρητικότητα 800 δίσκων θα το σκεφτόμουν αλλά μόνο με 400 δεν μπορώ να αγοράσω δύο από αυτά, δεν έχει χώρο το rack μου....:flipout::flipout::flipout:
