SONY NEX3N + 16-50 PZ OSS λευκη, αγορασμενη 10/2013 πωλειται
Status
Not open for further replies.
etsap
22 June 2008
5,861
Αθηνα-Ν.Ψυχικο
Λογω μικρου προβληματος στα ματια (πρεσβυωπια λεγεται κοινως...) αποχωριζομαι τη μικρουλα SONY της υπογραφης μου με τον 16-50PZ OSS.
Tα προτερηματα της γνωστα.
Η μηχανη σε ΑΡΙΣΤΗ κατασταση, με ΠΛΗΡΗ την συσκευασια της
Το exif της τελευταιας της φωτο:
[TABLE="align: center"]
[TR="bgcolor: #eeeeee"]
[TD]File Name [/TD]
[TD]DSC02682.JPG [/TD]
[/TR]
[TR="bgcolor: #ffffff"]
[TD]File Size [/TD]
[TD]5.2 MB [/TD]
[/TR]
[TD]File Modification Date/Time [/TD]
[TD]2014:02:23 07:13:33-08:00 [/TD]
[/TR]
[TD]File Permissions [/TD]
[TD]rw-r--r-- [/TD]
[/TR]
[TD]File Type [/TD]
[TD]JPEG [/TD]
[/TR]
[TD]MIME Type [/TD]
[TD]image/jpeg [/TD]
[/TR]
[TD]Exif Byte Order [/TD]
[TD]Little-endian (Intel, II) [/TD]
[/TR]
[TD]Image Description [/TD]
[TD]
[/TD]
[/TR]
[TD]Make [/TD]
[TD]SONY [/TD]
[/TR]
[TD]Camera Model Name [/TD]
[TD]NEX-3N [/TD]
[/TR]
[TD]Orientation [/TD]
[TD]Horizontal (normal) [/TD]
[/TR]
[TD]X Resolution [/TD]
[TD]350 [/TD]
[/TR]
[TD]Y Resolution [/TD]
[TD]350 [/TD]
[/TR]
[TD]Resolution Unit [/TD]
[TD]inches [/TD]
[/TR]
[TD]Software [/TD]
[TD]NEX-3N v1.00 [/TD]
[/TR]
[TD]Modify Date [/TD]
[TD]2014:01:26 17:11:07 [/TD]
[/TR]
[TD]Y Cb Cr Positioning [/TD]
[TD]Co-sited [/TD]
[/TR]
[TD]Exposure Time [/TD]
[TD]1/50 [/TD]
[/TR]
[TD]F Number [/TD]
[TD]4.5 [/TD]
[/TR]
[TD]Exposure Program [/TD]
[TD]Manual [/TD]
[/TR]
[TD]ISO [/TD]
[TD]3200 [/TD]
[/TR]
[TD]Exif Version [/TD]
[TD]0230 [/TD]
[/TR]
[TD]Date/Time Original [/TD]
[/TR]
[TD]Create Date [/TD]
[/TR]
[TD]Components Configuration [/TD]
[TD]Y, Cb, Cr, - [/TD]
[/TR]
[TD]Compressed Bits Per Pixel [/TD]
[TD]2 [/TD]
[/TR]
[TD]Brightness Value [/TD]
[TD]0.98203125 [/TD]
[/TR]
[TD]Exposure Compensation [/TD]
[TD]0 [/TD]
[/TR]
[TD]Max Aperture Value [/TD]
[TD]4.5 [/TD]
[/TR]
[TD]Metering Mode [/TD]
[TD]Multi-segment [/TD]
[/TR]
[TD]Light Source [/TD]
[TD]Unknown [/TD]
[/TR]
[TD]Flash [/TD]
[TD]Off, Did not fire [/TD]
[/TR]
[TD]Focal Length [/TD]
[TD]27.0 mm [/TD]
[/TR]
[TD]Auto HDR [/TD]
[TD]Off [/TD]
[/TR]
[TD]Sony Date Time [/TD]
[/TR]
[TD]Color Reproduction [/TD]
[TD]Standard [/TD]
[/TR]
[TD]Color Temperature [/TD]
[TD]Auto [/TD]
[/TR]
[TD]Color Compensation Filter [/TD]
[TD]0 [/TD]
[/TR]
[TD]Scene Mode [/TD]
[TD]Standard [/TD]
[/TR]
[TD]Zone Matching [/TD]
[TD]ISO Setting Used [/TD]
[/TR]
[TD]Image Stabilization [/TD]
[TD]On [/TD]
[/TR]
[TD]Color Mode [/TD]
[TD]Standard [/TD]
[/TR]
[TD]Full Image Size [/TD]
[TD]4912x3264 [/TD]
[/TR]
[TD]Preview Image Size [/TD]
[TD]1616x1080 [/TD]
[/TR]
[TD]File Format [/TD]
[TD]Unknown (3 3 0 0) [/TD]
[/TR]
[TD]Flash Exposure Compensation [/TD]
[TD]-2 [/TD]
[/TR]
[TD]White Balance Fine Tune [/TD]
[TD]0 [/TD]
[/TR]
[TD]White Balance [/TD]
[TD]Auto [/TD]
[/TR]
[TD]Sony Model ID [/TD]
[TD]Unknown (305) [/TD]
[/TR]
[TD]Teleconverter [/TD]
[TD]None [/TD]
[/TR]
[TD]Lens Type [/TD]
[TD]T-Mount or Other Lens or no lens [/TD]
[/TR]
[TD]Quality [/TD]
[TD]Unknown (65535) [/TD]
[/TR]
[TD]Anti-Blur [/TD]
[TD]On (Shooting) [/TD]
[/TR]
[TD]Dynamic Range Optimizer [/TD]
[TD]Standard [/TD]
[/TR]
[TD]Intelligent Auto [/TD]
[TD]Off [/TD]
[/TR]
[TD]User Comment [/TD]
[TD]
[/TD]
[/TR]
[TD]Flashpix Version [/TD]
[TD]0100 [/TD]
[/TR]
[TD]Color Space [/TD]
[TD]sRGB [/TD]
[/TR]
[TD]Exif Image Width [/TD]
[TD]4912 [/TD]
[/TR]
[TD]Exif Image Height [/TD]
[TD]3264 [/TD]
[/TR]
[TD]Interoperability Index [/TD]
[TD]R98 - DCF basic file (sRGB) [/TD]
[/TR]
[TD]Interoperability Version [/TD]
[TD]0100 [/TD]
[/TR]
[TD]File Source [/TD]
[TD]Digital Camera [/TD]
[/TR]
[TD]Scene Type [/TD]
[TD]Directly photographed [/TD]
[/TR]
[TD]Custom Rendered [/TD]
[TD]Normal [/TD]
[/TR]
[TD]Exposure Mode [/TD]
[TD]Manual [/TD]
[/TR]
[TD]Digital Zoom Ratio [/TD]
[TD]1 [/TD]
[/TR]
[TD]Focal Length In 35mm Format [/TD]
[TD]40 mm [/TD]
[/TR]
[TD]Scene Capture Type [/TD]
[TD]Standard [/TD]
[/TR]
[TD]Contrast [/TD]
[TD]Normal [/TD]
[/TR]
[TD]Saturation [/TD]
[TD]Normal [/TD]
[/TR]
[TD]Sharpness [/TD]
[TD]Normal [/TD]
[/TR]
[TD]Compression [/TD]
[TD]JPEG (old-style) [/TD]
[/TR]
[TD]Thumbnail Offset [/TD]
[TD]37048 [/TD]
[/TR]
[TD]Thumbnail Length [/TD]
[TD]8505 [/TD]
[/TR]
[TD]MPF Version [/TD]
[TD]0100 [/TD]
[/TR]
[TD]Number Of Images [/TD]
[TD]2 [/TD]
[/TR]
[TD]MP Image Flags [/TD]
[TD]Dependent child image [/TD]
[/TR]
[TD]MP Image Format [/TD]
[TD]JPEG [/TD]
[/TR]
[TD]MP Image Type [/TD]
[TD]Large Thumbnail (full HD equivalent) [/TD]
[/TR]
[TD]MP Image Length [/TD]
[TD]593941 [/TD]
[/TR]
[TD]MP Image Start [/TD]
[TD]4862976 [/TD]
[/TR]
[TD]Dependent Image 1 Entry Number [/TD]
[TD]0 [/TD]
[/TR]
[TD]Dependent Image 2 Entry Number [/TD]
[TD]0 [/TD]
[/TR]
[TD]Image Width [/TD]
[TD]4912 [/TD]
[/TR]
[TD]Image Height [/TD]
[TD]3264 [/TD]
[/TR]
[TD]Encoding Process [/TD]
[TD]Baseline DCT, Huffman coding [/TD]
[/TR]
[TD]Bits Per Sample [/TD]
[TD]8 [/TD]
[/TR]
[TD]Color Components [/TD]
[TD]3 [/TD]
[/TR]
[TD]Y Cb Cr Sub Sampling [/TD]
[TD]YCbCr4:2:2 (2 1) [/TD]
[/TR]
[TD]Aperture [/TD]
[TD]4.5 [/TD]
[/TR]
[TD]Image Size [/TD]
[TD]4912x3264 [/TD]
[/TR]
[TD]Lens ID [/TD]
[/TR]
[TD]Scale Factor To 35 mm Equivalent[/TD]
[TD]1.5 [/TD]
[/TR]
[TD]Shutter Speed [/TD]
[TD]1/50 [/TD]
[/TR]
[TD]Circle Of Confusion [/TD]
[TD]0.020 mm [/TD]
[/TR]
[TD]Field Of View [/TD]
[TD]48.5 deg [/TD]
[/TR]
[TD]27.0 mm (35 mm equivalent: 40.0 mm) [/TD]
[/TR]
[TD]Hyperfocal Distance [/TD]
[TD]7.99 m [/TD]
[/TR]
[TD]Light Value [/TD]
[TD]5.0
[/TD]
[/TR]
[/TABLE]
Δεν εχω κανει ποτε reset, αρα ο αριθμος της φωτο αντικατοπτριζει τον αριθμο των ληψεων της.
Τιμη 225 , με υπολοιπο εγγυησης (αγορασμενη απο PhotoAgora στην Ακαδημιας) και αποδειξη αγορας 10/2013.
Δωρο Τσαντακι μεταφορας Lowepro, και καρτα μνημης LEXAR 8GB.
Απαντησεις με pm (παρακαλω ΟΧΙ παζαρια, αν δεν πιασει την τιμη θα δοθει δωρο)
Status
