SONY PXW-FX6 camera
Kosh
7 September 2006
106,156
Εκεί ψηλά.....
Παρουσιαστηκε και η μικροτερη καμερα της σειρας η Sony PXW-FX6
https://www.youtube.com/watch?v=l0asz2VuXIg&feature=emb_logo
https://www.youtube.com/watch?v=a8xsjG6BSdE
Full-frame 4K recording at up to 120p
15+ stop wide dynamic range
Variable ND filter, LUTs input & S-Cinetone
Fast Hybrid AutoFocus System
Outstanding mobility, reliability and expandability
Sensor Type: CMOS
Sensor Size: 35mm, Full Frame
Sensor Resolution: 4096 x 2160
Video Resolution: 4K
Sensor Resolution (Mega Pixels): 12.9MP
Native ISO: ISO 12800, ISO 800
Lens Mount: Sony E Mount
CODEC: XAVC I, XAVC L
SDI Output: Yes
Weight: 0-2kg
Tιμή 5,515.84 προ φπα
6,619.01 μετά φπα (uK)
Ακομα δυσευρετη καμερα (τρομερα προβληματα παραδοσεων εχει εδω και πολελς εβδομαδες, τα οποια θεωρητικα αναμενεται να λυθουν τελος Ιουλιου)
Οτι θα χρειαστειτε για να την κανετε αστακο.
The Sony FX6 firmware update version 5.1 also includes the following features from version 5.0:
  • Adds support for the new preset 709tone Base Look
  • Adds a 1.5x De-Squeeze setting for both the viewfinder and HDMI output
  • Adds support for the Monitor & Controlapp, including:
    • Waveform and histogram displays
    • False-color and Focus Map displays
    • Monitoring at 1024×576 resolution
    • Note:
    Please update the Monitor & Control app to the latest version (Ver. 2.0 or later) to continue using this feature after the update.
  • Adds support for the Area Indication setting when using the Multi Matrix correction feature
  • Improves the image quality when using 3D LUT software
  • Adds 23.98PsF (progressive segmented frame) support for SDI output
  • Adds support lenses (SEL100400GM, SEL200600G) for the Breathing Compensation function
  • Adds the ability to use the multi-selector to choose the focus target for the real-time tracking auto-focus feature
  • Adds the following settings:
    • Format Media A or B setting on the Media status screen
    • Wireless LAN, Wired LAN, or Modem setting on the Network status screen
  • Improves the adjustment range of the Matrix/Multi Matrix settings when the Base Look is set to between User1 and User16, and when Target Display is set to HDR (HLG)
    Note:
    The effect on the setting values is different from Ver. 4.0 or earlier. If you are using the Matrix or Multi Matrix settings, please readjust the range.
