Sony str da3400es
Status
Not open for further replies.
panakos
22 September 2008
139
Σχεδόν έτους χρώμα ασημί , το οποίο είναι και ο λόγος που τον πουλάω.
τιμή 550euro
Παναγιώτης
450 τελικη
Product Specifications
Convenience
AM/FM Memory Presets : 30 FM - 30 AM
Preset Memory : 30 Sirius® Presets
Timer Clock : Yes (Sleep)
XM® Connect and Play™ Compatible : Yes (Neural 5.1 Surround Sound Decoding)
XM® Memory Presets : 30
Power
Power Consumption (in Operation) : 480W
Power Consumption (in Standby) : 1W
Power Requirements : AC120V, 60 Hz
Video Features
Time : 300msec
Up Conversion : Yes (HDMI, Component 1080p)
Up Scaling : Yes (HDMI Up Scaling up to 1080p)
x.v.Color™ Technology : Yes
Weights and Measurements
Dimensions (Approx.) : 17" x 6 1/4" x 15 3/8" (430mm x 157.5mm x 388mm)
Weight (Approx.) : 26 lb 15oz (12.2kg)
Audio Features
Amplification Relocation : Yes
Digital Cinema Sound™ Technology : Yes
Dolby® Digital Decoding : Yes
Dolby® Digital Dual Mono : Yes
Dolby® Digital EX Decoding : Yes
Dolby® Digital plus Decoding : Yes
Dolby® Pro Logic® Decoding : Yes
Dolby® Pro Logic® II Decoding : Yes
Dolby® Pro Logic® IIX Decoding : Yes
Dolby® TrueHD Decoding : Yes
THX Surround : Yes(225,227 only)
dts® 96/24 Decoding : Yes
dts® Decoding : Yes
dts® NEO:6 Decoding : Yes
dts®-ES Decoding : Yes
General
A/V SYNC (Lip Sync) : Yes (Variable)
Day/Night Function : Yes (Night Mode)
Inputs and Outputs
12V Trigger Output(s) : 3 (Rear)
AC Outlet : Yes
Analog Audio Input(s) (Total) : 4 (Rear)
Analog Audio Output(s) : 1 (Rear)
Antenna Terminal (AM Loop) : 1 (Rear)
Antenna Terminal (FM 75 Ohm) : 1 (Rear)
Coaxial Audio Digital Input(s) : 3 (Rear)
Component Video (Y/Pb/Pr) Input(s) : 3 (Rear)
Component Video (Y/Pb/Pr) Output(s) : 1 (Rear)
Composite Video Input(s) : 1 (Rear)
Composite Video Output(s) : 3 (Rear-1 Monitor Output, 2 Video Outputs)
Control S : Connection(s) - Yes
Digital Media Port : Yes
HD Component Video Input(s) : 3 (Rear)
HD Component Video Output(s) : 1 (Rear)
HDMI™ Connection Input(s) : 4 (Rear)
HDMI™ Connection Output(s) : 1 (Rear)
Headphone Output(s) : 1 (Front- Gold)
IR Input(s) : 2 (Rear)
IR Output(s) : 1 (Rear)
Multi-Channel Input(s) : 1 (Rear, 7.1 Channel)
Optical Audio Input(s) : 5 (1 Front/4 Rear)
Optical Audio Output(s) : 2 (Rear)
Phono Input(s) : 1 (Rear)
RCA Audio Input(s) : 5 (Rear)
RCA Audio Output(s) : 2 (Rear)
RS232 Control : 1 (Rear)
Subwoofer Output(s) : 1 (Rear)
Speaker
Center Speaker Terminal : Yes
Speaker Terminal Type : Screw Binding Posts
Surround Back Speakers : Screw Binding Posts
Surround Speaker Terminal : Yes
Hardware
Remote Control : Yes (Advanced Learning/Pre Programed)
Convenience Features
A/B Speaker Switch : Yes (A / B / A+B)
BRAVIA® Sync™ : Yes
Digital Cinema Auto Calibration : Yes (Mic-Stereo)
HDMI™ Technology : Intelligent A/V Selector
On-Screen Display : Yes
Audio
Channel Power Rating : 7.1 Channel Power Rating: 100W x 7 Amp Power (8 ohms, 20Hz-20Khz, THD 0.09%)
Frequency Range : 192kHz
Impedance : 8 Ohms
Sound Fields : Cinema - 4; Music - 7; Auto Format Decoding - 14; 2 Channel - 1; Headphone - 4
Tuner Type : Auto Tuning, Direct Tuning, Station Name, Presets 30/30/30 (XM/FM/AM)
Zones : 2 Zone/2 Room Control with 2nd Room Audio
In the Box
AM Loop Antenna
1 Basic Remote Commader
Instruction Manual
Size AA Batteries: 2
Mono Mic (for Auto Calibration only)
FM Wire Antenna
1 Way Pre Programmed Remote Commander® Remote Control
http://www.sonystyle.com/webapp/wcs...ngId=-1&productId=8198552921665491076#reviews
Επαναφέρω την αγγελία στα 450 ευρώ.
Δεκτή και ανταλλαγή με καποιο μοντελο κατηγοριας Pioneer vsx AX10 , AX5Ai και σε αλλες μάρκες.
O Ενισχυτης ειχε ενα FW Bug γνωστο και ως SKY-FIX κοινο με τον 2400.
Στα πλαισια της εγγυησης εγινε αναβαθμιση και εχει γραπτη εγγυηση μεχρι 31/03/2011.
Ο λόγος που τον πουλάω είναι ότι στην μουσική δεν ταιριάζει με τα ηχεία μου Crystal Audio T3 και δεν με ικανοποιεί όσο ο Pioneer Vsx 909RDS-G που έχω.
Στις ταινίες είναι σε άλλη κλάση βέβαια όντας και το μικρο αδερφάκι του 5400 που είχε σαρώσει τις διακρίσεις το 2008.
Status
