Sony STR-DB780QS/S AV-Receiver silver
panakos
22 September 2008
139
Surround: 100W x 5
Stereo: 100W x 2
Dolby Digital
Dolby Pro Logic
DTS
Dolby Pro Logic II
3 x DCS Modes
4 x DSP Surround Sound Fields
Normal Surround
DPLII Movie & Music Modes
Parametric EQ & Audio Control
Independent Level Controls for Centre and Surround Channels
Balance Control for Front Speakers
Bass & Treble EQ for Front Speakers with Selectable Turnover Frequency
Variable Dynamic Range Compression Control
LFE (Low Frequency Effect) Mix Level Control
DSP Effect Level Control
Speaker Distance Control for Front, Centre, Surround & Sub
Speaker Size Control for Centre, Front & Surround
Surround Speaker Height Control
Surround Speaker Position Control
Multi-Channel Input Sub Level Control
Control for DPLII Music Mode
Crossover Frequency Control for Front, Centre & Surround
(adjustable from 40Hz to 200Hz in 10Hz steps)
Subwoofer High Cut Filter (adjustable from 40Hz to 200Hz
in 10Hz steps)
Wall Material Compensation Control
Reverberation Control
Screen Depth Matching Control
30 Preset AM/FM Tuner
Station Naming
RDS
Inputs / Outputs
Total Sources: 8
AV Inputs x 2 (Composite & S-Video)
AV In/Out x 2 (1 x Composite & 1 x S-Video & Composite)
Stereo Audio Input x 1
Stereo Audio In/Out x 1
5.1 Multi-Channel Input
Optical Digital Input x 3
Coaxial Digital Input (assignable)
Switched Video Out (Composite & S-Video)
Subwoofer Output
Front AV Input (Composite & S-Video Digital Optical)
Optical Digital Output
Phono Input
SACD Bandwidth capable
Headphone Socket
Remote Control compatible with other Sony components
Input Naming
Sound Field Link
Display Dimmer
Muting Button
Sleep Timer
Control A1II
Speaker Binding Posts
http://www.sony.com.au/objects/pdf/STRDB780.pdf
σε άριστη κατάσταση , ελάχιστα χρησιμοποιημένος
τιμή 250 ευρω
