Πωλούνται τα γνωστά mini monitor Spendor 3/5.
Κλασσικός ήχος monitor της αγγλικής - BBC σχολής με εκπληκτικά μεσαία και όχι μόνο.
Είναι δύο ετών σε άψογη κατάσταση ηχητικά και αισθητικά.
Λίγα λόγια ακόμα...
For over two decades Spendor was licensed to manufacture the legendary LS3/5a BBC mini-monitor loudspeaker. It became an international reference standard. In 1998 when Spendor learned that manufacture of the LS3/5a drive units was to cease, we decided to develop our own 140mm (5inch) bass-midrange drive unit using modern materials and technology. Combining this with a small 20mm Vifa soft dome tweeter, new crossover engineering and a more up-to-date look we created the Spendor S3/5. Many discerning listeners consider it to be the most transparent and truly musical mini-loudspeaker they have ever heard and the S3/5 has won many awards.
Description 2 way stand mounted loudspeaker
S3/5 bass unit
Enclosure type Sealed enclosure
Drive units HF 20mm coated fabric dome
Drive units LF/MF 140mm homo polymer cone
Frequency response
90Hz-20kHz ± 3dB on reference axis
Frequency range
-6dB at 70Hz
Dispersion Within 3dB of response on reference axis Horizontal over 40° arc ( ±20°)
Vertical over 20° arc ( ±10°)
Sensitivity for 1W @ 1m 84dB
Impedance nominal 8 ohms
Impedance minimum 4.9 ohms
Crossover frequencies 4.5kHz
Power handling 15 - 70 watts into 8 ohms unclipped
Harmonic distortion
<1% 100Hz – 20kHz 90 dB @ 1m
2/3 way gold plated bi-wirable terminals
Magnetic shielding All drive units shielded
Dimensions H x W x D 305 x 165 x 190mm (12.0 x 6.5 x 7.5in)
Spikes/feet/stand height 500-650mm (20-26in) stand not supplied
Net weight 4.6kg (10.2lb)
Shipping weight 10.5kg pair (23.2lb pair)
Το χρώμα τους είναι το Rosewood και μαζί δίνονται βάσεις Gale
Τιμή 800
Λίγα λόγια ακόμα...
S3/5 bass unit
Frequency response
Frequency range
-6dB at 70Hz
Harmonic distortion
Τιμή 800
