SPIDERBOX 7000 HD
teomad
Banned
5 July 2008
1,980
προσεχως!!!
οι πρωτες πληροφοριες που βρηκα για τον δεκτη
Supports MPEG-2, MPEG-4, H.264 and fully DVB compliant
- Satellite receiver
- 1 Slot smart card
- DiSEqC 1.0, 1.1, 1.2 and USALS
- Aspect ratio adjustment 4:3 (16/9 crop), 4:3 (16/9 letterbox), 16:9 (4/3 pillar box)
-User friendly OSD and operation
- Total 8,000 Channels Programmable
- Multi-language audio support Multi-language menu text support
- Favorite channel selections
- Parental Guide and rating control
- EPG(Provider Electronic Program Guide) for On Screen Channel Information
- On-Screen Display with 65,536 Color
- Blind scan(Power Scan) & Powerful EPG
- Zoom Function in Pause
- Dolby Digital Bitstream Out through S/PDIF(Optical & Coaxal)
- Seletable output for 1080i, 720P, 480P and 480i format
- Multiple Video Outputs
“HDMI1.1, Component(YPbPr), Composite”
- USB 2.0 Host (Access to HDD, USB memory, Others etc) : 2 Port
- Upgrade Software & Update Channel Database through USB 2.0 Port and RS232
- MP3 File Play by USB 2.0
- PVR Ready via USB
- Recorded file play on PC
- Reservation Recoding by EPG function
- Multimedia file play by USB 2.0
- Home streaming
1. Conditional Access Interface
SMART CARD 1 Slot
2. Tuner & Channel(DVB-S2)
F Type, IEC169-24, Female
´ Type 1 l
l Frequency Rage 950MHz to 2150MHz
RF Impedance 75 Ohm unbanlanced
l
l Signal Level -65 to -25 dBm
LNB Power 13/18Vdc +/- 5%, 0.5Amax, Overload
l Protected
22KHz Tone Frequency :224KHz +/- 2KHz, 0.6Vpp +/- 0.2V
l
l DiSEqC Control Version1.0, 1.2, Tone burst A/B
Demodulation QPSK, 8PSK
l
l Input Symbol Rate DVB-S QPSK : 1~45 Msps
DVB-S2 8PSK/QPSK : 10~30Msps
l FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode.
1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode.
3. System & Memory
Main Processor
l STi7101
Flash Memory 8 Mbytes
l
System Memory 128 Mbytes
l
A/V Memory
l 64 Mbytes
Channel Capacity Digital Channel: 8,000
l
Front 7-Keys,
l 7-SEGMENT DISPLAY
4. MPEG Transport Stream & A/V Decoding
Transport
l Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification
Profile
l Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC
Input Rate
l Max. 90Mbit/s
Aspect Ratio 4:3, 16:9, Letter Box
l
Frame Rate 25Hz for
l PAL, 30Hz for NTSC
Video Resolution 576i, 576p, 720p, 1080i
l
Teletext
l Through VBI
Audio Decoding MPEG-1 Layer 1
l & 2, Dolby Downmix
Audio
l Mode Single Channel/Dual Channel Joint Stereo/Stereo
Frequency Response
l 20~20kHz, <+/-2dB
60Hz ~ 18kHz <+/- 0.5dB
Sampling Rate 32, 44.1,
l 48KHz
5. A/V & Date In/Out
HDMI HD Video/Audio Output
l
RCA
l Output CVBS, L, R Output(Yellow, White, Red Jack) with Volume Control
Component Video(YPbPr) Out
SPDIF Dolby Digital Bitstream
l Out(Coaxal, Optical)
Data Interface - RS-232, Bit Rate:
l 115,200baud
Connector: 9-pin D-sub Male type
- USB : USB 2.0, Type A Connector, 2Port
- Ethernet : 10/100Mbps, DHCP Supporting, RJ-45
6. Power Supply
Input
l Voltage AC 90V ~ 250V, 50Hz ~ 60Hz
Power Consumption Max 40W
l
l Protection Separate Internal Fuse
The input shall the lighting protection
7. Physical Specification
Size(WxHxD) 300mm x 65mm x
l 215mm
Weight 1.5 KG
l
8. Environmental Condition
Operating
l 40 °C~Temperature 0 °C
50 °C
~ Storage Temperature -10 °C l
Operating
l Humidity Range 10~85% RH, Non-condensing
Storage Humidity Range 5~90% RH,
l Non-condensing
ΤΙΜΗ: 176E
Απάντηση: Re: SPIDERBOX 7000 HD
Αμα εχει δωρο κινδυνευει για κλειδωμα.:flipout:
Δυστυχώς δεν μπορώ να γελάσω με το αστείο σου. Αν θέλετε να βλέπετε "τζάμπα" να πάτε στο Αλσατ. Οχι εδώ. Εδώ δεν έχουν θέση οι "κουμπωτοί" δέκτες. Και αυτός ο δέκτης εντάσσεται σε αυτή την κατηγορία.
http://supersatshop.eu/products/Spi...ET-%2b-gift-inc.Delivery.html?setCurrencyId=2
βλέπε ->gift.
Το θέμα με τους Spiderbox έχει καταστρατηγηθεί από τον John78 συνεπικουρούμενο από τον teomad σε πολλές περιπτώσεις, με στόχο την εμπορική προώθηση του δέκτη, αρνούμενοι να δεχτούν οποιαδήποτε αδυναμία του καταγράφεται από χρήστες, αποκαλώντας τους μάλιστα ψεύτες.
Δυστυχώς η συμπεριφορά των ως άνω προσώπων δεν αφήνει τα περιθώρια για την ανάπτυξη ουσιαστικής συζήτησης περί των τεχνικών δυνατοτήτων και λειτουργιών των δεκτών Spiderbox, καθότι με συνεχή δημοσιεύματα επιχειρούν να εξάπτουν την φαντασία των εν δυνάμει αγοραστών με το δέλεαρ της "δωρεάν" θέασης συνδρομητικών υπηρεσιών.
Οποιοσδήποτε αντίλογος περί των ανωτέρω, σκοντάφτει στο γεγονός ότι ουδέποτε επιδόθηκαν με τέτοιο ζήλο στην παρουσίαση άλλων δεκτών. Επίσης δεν είναι τυχαίο ότι οι δέκτες, τα μοτέρ και τα LNB που τεχνηέντως προωθεί ο John78, προέρχονται από συγκεκριμένο ηλεκτρονικό κατάστημα που διατηρεί "ενημερωτική" ιστοσελίδα.
Οι μέθοδοι που χρησιμοποιεί ο δέκτης και εννοείται ότι αναφέρομαι στο παρεχόμενο με την αγορά του software, είναι μη νόμιμες. Αλλωστε το κίνητρο για την αγορά των συγκεκριμένων δεκτών είναι το gift διότι κατά τα λοιπά, αν εξαιρέσει κανείς ισως το blind scan, πρόκειται για κοινούς δέκτες όπου ο ανταγωνισμός σε πάρα πολλές περιπτώσεις είναι ανώτερος.
Επειδή, το Avclub δεν θα γίνει βήμα διαφήμισης, ούτε υποκατάστημα πωλήσεων οποιουδήποτε επιτήδειου,
Επειδή, το Avclub, παραμένει ανεξάρτητο χωρίς επιρροές και μακριά από εμπορικά συμφέροντα,
Επειδή, δεν επιθυμούμε τη φιλοξενία προιόντων τα οποία έχουν ως πρωταρχικό σκοπό τη μη εξουσιοδοτημένη θέαση συνδρομητικών υπηρεσιών,
Επειδή, με αυτά τα κριτήρια καθιερωθήκαμε στη συνείδηση των μελών και επισκεπτών μας,
Επειδή, σε πείσμα των καιρών, με ισχυρή βούληση παραμένουμε αδιάβλητοι και λειτουργούμε διαφορετικά από οποιοδήποτε άλλο ομοειδή ιστοχώρο,
Για τους λόγους αυτούς και με την επιφύλαξη παντός δικαιώματος του Avclub,
Το θέμα SPIDERBOX κλειδώνεται οριστικά και δεν είναι επιθυμητή οποιαδήποτε συζήτηση για τους δέκτες και τα υποπροϊόντα αυτής της συνειδητά επιχειρούμενης προώθησης.
Με αυτή μου την δήλωση (και κίνηση) δυστυχώς θα στενοχωρήσω και κάποια μέλη τα οποία δε φέρουν καμία ευθύνη, όμως όλες μου οι εκκλήσεις να μη παρεκκλίνει το (προηγούμενο) θέμα αγνοήθηκαν, μάλιστα δέχτηκα και κακόβουλη κριτική για τις συντονιστικές μου ικανότητες.
To thread διατίθεται και πάλι για δημόσια συζήτηση. Ομως περιοριστείτε αυστηρά στις τεχνικές και λειτουργικές δυνατότητες του δέκτη. Οποιαδήποτε εκτροπή στο μέλλον θα οδηγήσει χωρίς περαιτέρω προειδοποίηση σε αποκλεισμό του χρήστη. Ως τέτοια αναφέρω ενδεικτικά ότι θεωρώ δημοσιεύσεις για τη μη νόμιμη λειτουργία ή την διαφημιστική προβολή του με οποιονδήποτε τρόπο.
Η δήλωση του προηγούμενου μηνύματος μου ισχύει αυτούσια. (πλην μιας παραγράφου εννοείται)
Καλησπέρα σε όλους,
Επειδή θέλω να πάρω δεύτερο δέκτη και επειδή φοβάμαι να πάρω ένα δεύτερο AZBox μπορεί κάποιος να μου πει:
1) Επειδή βλέπω πως έχει hdmi 1.1, θα συνεργάζεται ομαλά με τον HK AVR 255 (εικόνα ήχος)???
2) Αν το cccam δουλεύει απροβλημάτιστα???
Μα ο νέος δέκτης είναι ίδιος με τον 9000 απλά δεν έχει rf modulator, δεν έχει CI & έχει 1 scart. Το λογισμικό και το HW θα είναι τα ίδια οπότε η ερώτησή μου στην ουσία απευθύνεται στους κατόχους του 9000 εκτός βέβαια και αν δεν κατάλαβα καλά τα τεχνικά του χαρακτηριστικά.
Απο οτι βλεπω δεν ειναι "κουμπωτοί" δέκτες μια και επιπλεον του...δωρου τους παιρνει και CCamγραμμες απο Servers. 200euro με τα μεταφορικα ειναι πειρασμος για HD . H DM800 μαιμουδες ειναι πιο ακριβοι
Ολα τα παραπάνω είναι γνωστά. Δεν είναι ο μόνος που παίρνει γραμμές σε αυτά ή λίγα περισσότερα χρήματα.
Εδώ όμως εξαντλείται και η σχετική συζήτηση επί αυτού του θέματος.
Μόλις αγόρασα τον σιγκεκριμένο δέκτη και τρόμαξα όταν έβαλα να δω το πρώτο μου δορυφορικό καναλι...Χειρότερη ποιότητα εικόνας δεν έχω ξαναδει .........
