στοιχεια προς συγκριση
argi
Banned
17 July 2006
7,032
salmonela
του νεου pioneer
Main Features KRF-9000FD
Device 0.7 inch D-ILA x 3
Resolution 1,920 x 1,080
HD Ready 1080p Yes
HD Digital Film Direct 24 Yes
Lens 2 x motorised zoom / focus lens
f = 21.3 – 42.6 mm, F=3.2 – 4.3
Lens Shift Function ± 80% vertical, ± 34% horizontal
Projection Size 60 – 200 inches
Lamp 200W ultra high-pressure mercury lamp
Light Output 600 lm
Contrast Ratio 30,000 : 1
Input Terminals 2 x HDMI
1 x Component
1 x S-Video
1 x Composite
Control Terminals RS-232C (D-sub, 9-pin)
Video Input Signals 480i/p
576i/p
720p 50 / 60p
1080i 50 /60p
1080p 60 / 50 / 24
NTSC/NTSC4.43
PAL, PAL-M, PAL-N
SECAM
Noise Level 24 dB (in normal mode)
Power Consumption (in use / standby) 280W / 2.7W
Dimensions (W x H x D) 455 x 172.5 x 418.5 mm
Weight 11.6 kg
