SUPERDISC από MonsterMusic
Γιώργος ΚΟΨ
20 June 2006
3,250
GLYFADA
Κι άλλη εταιρεία συνδυάζει τα αρχεία υψηλής ανάλυσης, με "πληθωρικό" φυσικό μέσο που περιέχει διάφορες εκδόσεις (ακόμη και ειδική έκδοση για ακουστικά) νέα pcm remaster αλλά και HiRez files για download
SUPERDISC FEATURES
High Definition Surround - Mastered for today's 5.1 home theater systems to bring out more character and discreet instrumentation.
"In The Band" Surround Experience - 1.54 Mbps DTS 96/24 and Dolby 448kbps 48/16, sounds like you are at a live session.
High Definition Stereo - Audiophile Mastered PCM Stereo Tracks
Also includes the original 2-channel stereo CD.
High Definition Digital Music Files ready to "Drag and Drop"
:SFGSFGSF:
Dolby Headphone Surround for virtual surround sound from MP3 Players
2 Bonus Tracks
http://www.monstermusic.com/superdisc.asp
http://www.monstermusic.com/default.asp
έχει και dvds με μίξεις σε θέση κοινού ή / και on stage με τη μπάντα (!)
και high definition video.
Ανάλογα με την κυκλοφορία, προσέξτε τι εκδόσεις περιλαμβάνει....
Q&A
What is the difference between a CD and a SuperDisc?
A SuperDisc offers much better sound quality than a typical CD. CDs use a sample rate of 44.1 kHz while SuperDiscs are 96 kHz. This captures more of the sound wave for powerful dynamic range, improved vocal presence and a much more natural and realistic sound.
Where Do I Find the Digital Music Files?
Insert the DVD into your computer and locate the folder labeled "digital music files." You will find two subfolders, one for Windows® and another for Mac®. The Windows folder contains WMA files in stereo or Dolby® Headphone. The Mac folder contains AAC files in stereo and Dolby Headphone surround. These are already "ripped" directly from the masters so you can drag the files into your favorite music software or portable music player.
Will a SuperDisc play in a regular CD player?
No, but most Monster Music releases include a CD of the original recording for your CD player.
Will a Monster Music SuperDisc play on my DVD Player?
Yes. SuperDiscs are compatible with any DVD player.
Εχω το Cd του Cincotti (δε το βλεπω πια στο catalogue) εδω και 4 χρονια καθως και το dvd Των 3 doors down επισης πριν 4 χρονια.
Μου τα ειχε φερει φιλος απο την εκθεση του Μοναχου. Αλλα δε ξαναασχοληθηκα καθως δεν υπηρχε εξελιξη.
Το cd ειχε εξαιρετικη εγγραφη.
