Σύνδεση AV Yamaha rx 1600 με Azur 740 a
Vakis 2000
9 February 2010
188
Καλημέρα,
Από χθες είμαι κάτοχος του 740 a. Θέλω να τον συνδέσω με τον Yamaha για αναβάθμιση του ήχου σε επίπεδο stereo. Γνωρίζει κανείς σε πιο σημείο πρέπει να βρίσκεται η στάθμη του ήχου του 740 για τον σωστό συγχρονισμό με τον Yamaha?
Ιάκωβος.-
Ιάκωβε διάβασε το manual.
Fixed level inputs
Any input of the 740A is able to be set for fixed gain. Whenever this input
is selected the gain will automatically go to this value and will not be
adjustable by the volume control. This feature allows the 740A to be
effectively used as a stereo power amplifier (for that selected input only).
For example, as well as operating as a pure stereo amplifier, the 740A
can provide the amplification for the front left and right channels of a
surround sound setup with an AV receiver providing amplification for the
other channels and controlling the overall system volume.
When listening in stereo use the 740A and connected stereo sources as
normal for best possible sound quality. For surround sound, select the
fixed level input you have chosen on the 740A and now use the AV
receiver to control the volume, select connected surround sound
sources etc. You may wish to re-name the fixed level input as “A/V
mode” or similar on the 740A. Make connections as below, the left and
right preamp outputs of the AV receiver connect to the fixed gain input
chosen on the 740A. As the gain can be fixed to any value it is easy to
match the level of the 740A to that of the other AV channels.
To set a fixed volume for a source, select FIXED INP in the System
Configure menu.
Select the input required and set the fixed gain using the volume control
(the OFF setting does not disable the input but leaves the input gain
subject to the volume control which is the default setting). When a
source has a fixed input, the balance is always set to neutral. Press the
Mode button to exit.
Απ' τη στιγμή που έχει passthrough και μπορεί να δουλέψει ώς τελικός stereo για τα front channels, ο διακόπτης της έντασης δεν θα λειτουργεί. Το master volume θα ελέγχεται απ' τον Yamaha. Απλώς θα πρέπει να ρυθμίσεις το input gain του Campridge. Ρίξε μία ματιά στο manual.....
Εdit: Με πρόλαβε ο συνάδελφος
Απάντηση: Re: Σύνδεση AV Yamaha rx 1600 με Azur 740 a
Δεν είναι τυχαίο ότι με αποκαλούν lucky look του πληκτρολογίου. Δακτυλογραφώ πιο γρήγορα και από τον ίσκιο μου. Αφού να φανταστείς έχω πάντα και ένα ποτήρι νερό δίπλα στο πληκτρολόγιο για να βουτάω τα δάκτυλα όταν ανάβουν από την ταχύτητα.:BDGBGDB55:
:flipout::flipout::flipout:
Ευχαριστώ πολύ παιδιά.
Το είδα το σημείο αυτό στο manual αλλά λόγω του ότι δεν τα πάω καλά με τα Αγγλικά, έχω κάποια κενά. Ελπίζω ότι όταν θα τα συνδέσω, θα βγάλω άκρη.
Αν είχα κάποια μετάφραση της παραπάνω παραγράφου θα ήμουν ευτυχής.
Κάτι άλλο, για τα παραπάνω μηχανήματα τι ποσό πρέπει να διαθέσω για τα καλώδια? (Όχι υπερβολές).
Fixed level inputs
Οποιαδήποτε είσοδος του 740Α μπορεί να σεταριστεί σε σταθερό gain (ας πούμε απολαβή ή ένταση). Ετσι όταν επιλέγεται αυτή η είσοδος, η ένταση θα πηγαίνει στην σταθερή αυτή τιμή και το volume control θα είναι ανενεργό. Αυτή η ιδιότητα επιτρέπει στον 740Α να λειτουργεί ως stereo τελικός ενισχυτής (Προσοχή!! Μόνο στη συγκεκριμένη αυτή είσοδο).
Για παράδειγμα όσο καλά λειτουργεί ο 740Α σαν stereo ενισχυτής, μπορεί το ίδιο καλά να χρησιμοποιηθεί για ενίσχυση των εμπρός καναλιών σε πολυκάναλο σύστημα με τον A/V Receiver στην περίπτωση αυτή να ενισχύει τα υπόλοιπα κανάλια και να ελέγχει την ένταση όλου του συστήματος. Μπορούμε να ακούσουμε stereo ήχο από όλες τις εισόδους και τις πηγές που είναι συνδεδεμένες πάνω στον 740Α. Για πολυκάναλο ήχο δεν έχουμε παρά να επιλέξουμε την είσοδο που έχουμε σετάρει ως fixed gain, και τότε μπορούμε να ελέγξουμε τον ήχο απ' τον A/V ενισχυτή. Η είσοδος αυτή είναι δυνατόν να μετονομαστεί από το menu του 740Α (π.χ. A/V mode ή αλλιώς).
Configure menu.
Κάνετε τις συνδέσεις ώς εξής:
Από τις εξόδους προενίσχυσης (pre outs) του A/V συνδέουμε τις L και R outputs στην είσοδο που έχουμε επιλέξει ως fixed gain, π.χ. την input 1
Για να επιλέξουμε την input 1 ως είσοδο σταθερού gain, επιλέγουμε "FIXED INP" στο menu του ενισχυτή. Διαλέγουμε την είσοδο (input 1) και εν συνεχεία σετάρουμε το gain δίνοντας μία τιμή (εκτός από OFF) περιστρέφοντας τον διακόπτη του volume. Εν συνεχεία πατάμε το "MODE" για να εξέλθουμε.
Ευχαριστώ πολύ Κώστα,
Από μετάφραση σκίζω.To gain νόμιζα ότι έπρεπε να είναι στο OFF.
Επί τέλους ακούω μουσική σωστά!!!
Άστρωτος ακόμη ο 740 και η διαφορά στον ήχο είναι τεράστια.
Σαν δικάναλος απλά τέλειος για τα γούστα μου. Διαφάνεια, δυναμικά, και κρυστάλλινα πρίμα. Σαν τελικός στο home cinema αναβάθμισε τον ήχο σε όλες του τις παραμέτρους. Και να στεφτεί κανείς ότι ο 1600 θεωρείται αρκετά μουσικός, όπως και κάθε Yamaha αλώστε. Όσοι μπορείτε, ακολουθείστε αυτή την μέθοδο και θα έχετε το τέλειο σύστημα με όσο γίνεται χαμηλότερο κόστος . Μπράβο στα παιδιά για τις πληροφορίες τους.
