- 20 May 2009
- 5,856
Ηχεία της σειράς Concept από την βραβευμένη δανέζικη εταιρεία ηχείων Hi-Fi, Dali και subwoofer της Velodyne, αρχικής αξίας 1229 ευρώ!
Mεταχειρισμένα σε πολύ καλή κατάσταση.
Dali Concept Center black
• Frequency range 72 - 22500
•Power(Watt) 25 - 120
•Dimmension(HxWxD) cm 16 x 50 x 23
•Weight (kg) 6,6
Dali Concept 1 Black (Ζεύγος)
[TABLE="width: 938"]
[TR]
[TD]Frequency response[/TD]
[TD]62.5 Hz - 22.5 kHz[/TD]
[/TR]
[TR]
[TD]Sensitivity[/TD]
[TD]87 dB[/TD]
[/TR]
[TR]
[TD]Nominal impedance[/TD]
[TD]8 ohms[/TD]
[/TR]
[TR]
[TD]Recommended amplication[/TD]
[TD]25 - 100 Watts[/TD]
[/TR]
[TR]
[TD]Dimensions[/TD]
[TD]310(H) x 170(W) x 190(D) mm[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]4kg[/TD]
[/TR]
[TR]
[TD]Finishes available[/TD]
[TD]Black and Cherry[/TD]
[/TR]
[TR]
[TD]High frequency driver[/TD]
[TD]1 x 1"[/TD]
[/TR]
[TR]
[TD]Low frequency driver[/TD]
[TD]1 x 5"[/TD]
[/TR]
[/TABLE]
Dali Concept 6 Black (Ζεύγος)
[TR]
[TD]Frequency range (+/- 3dB) [Hz][/TD]
[TD]41 - 25.000[/TD]
[/TR]
[TR]
[TD]Sensitivity (2,83 V/1 m) [dB][/TD]
[TD]91,0[/TD]
[/TR]
[TR]
[TD]Nominal impedance [ohms][/TD]
[TD]8[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Maximum SPL [dB][/TD]
[TD]110[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Recommended amplifier power [W][/TD]
[TD]30 - 150[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Crossover frequencies[/TD]
[TD]3.000[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]1 x 1 " Soft textile dome[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2 x 6.5" Paper fibre cone[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Enclosure type[/TD]
[TD]Bass reflex[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Bass reflex tuning frequency [Hz][/TD]
[TD]38,0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Connection input(s)[/TD]
[TD]Single wire[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Recommended placement[/TD]
[TD]Floor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Loudspeaker type[/TD]
[TD]Front[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Magnetic shielding[/TD]
[TD]Semi magnetic shielded[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Max loudspeaker dimensions incl. base and grille (HxWxD) [mm][/TD]
[TD]930 X 200 X 260[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Loudspeaker weight [kg][/TD]
[TD]14,2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Velodyne CHT-8Q
• Τύπος: Eνεργό Subwoofer
• Ισχύς: 180W
• Απόκριση: 32 – 120 Hz ±3dB
• Διαστάσεις: Μεγαφώνων: Woofer 8' /' Ηχείου: 305 x 387 x 416 χιλ.
• Λοιπά Χαρακτηριστικά: LED Display, Gold plated Inputs, Auto On/Off
Photos:
Τιμή πακέτου: 750
(Για αρχή, θα πωλείται μόνο ως πακέτο)
Επικοινωνία ΜΟΝΟ τηλεφωνικώς στο 6979 980 063
Σας μερσω... :ernaehrung004:
Επειδή ζητήθηκε, επιτρέψτε μου να ανεβάσω φώτο του κεντρικού:
•Weight (kg) 6,6
[TR]
[/TR]
[TR]
[TD]87 dB[/TD]
[/TR]
[TR]
[TD]8 ohms[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Dimensions[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]4kg[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]1 x 1"[/TD]
[/TR]
[TR]
[TD]1 x 5"[/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[TD]91,0[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]110[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]30 - 150[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]3.000[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]38,0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Floor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Front[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]14,2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Velodyne CHT-8Q
• Ισχύς: 180W
Photos:
Τιμή πακέτου: 750
