Technomate 6800 & 6900 HD Combo (όχι τα μοντέλα "super")
AlexT_
10,461
H αγγλική Technomate κυκλοφόρησε δύο HD δέκτες. Πρόκειται για τον combo (DVB-S/S2 - HD DVB-T) TM-6900 COMBO HD και τον TM-6800 HD.
Ο πρώτος έρχεται μάλιστα με δυνατότητες DVB-T HD!
» High Definition Satellite & High Definition Terrestrial + 10,000 Channels + USB 2.0 with: PVR Ready for Timeshift, Record & Playback of Channels, MP3/JPEG & Software Download + 1 Card Reader + 2 Common Interface (2CI) + HDMI & Component with Upscaler
viewpic.php
Specification
  • 2 High Definition Tuners: DVB-S/DVB-S2 Satellite & DVB-T Terrestrial Compliant (MPEG-II/ MPEG-IV/ H.264)
  • Output Resolution: 576p & 576i, 720p & 1080i
  • 1 Smart Card Reader & 2 Common Interfaces (2CI)
  • HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
  • 10,000 TV & Radio Channels
  • USB2.0 PVR Ready via external HDD or USB Flash Drive (memory stick) with Timeshift, Record & Playback functions
  • MP3 player and JPEG viewer via external HDD or USB Flash Drive (memory stick)
  • Software & Channel List download via USB 2.0
  • Fully Featured VFD text Front Panel Display
  • Sensitive Tuner
  • Less than 1 second channel change
  • Dolby Digital Optical S/PDIF
  • DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
  • Auto Navigation system – select as many satellites as you want to search
  • On-screen display with true full color resolution
  • Enhanced 16 Favorite channel groups
  • Channel control by: Favorites, Lock, Skip, Move & Delete
  • Channel sort by: All, Alphabet, Transponder & CAS
  • Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Persian
  • Extended EPG and program reservation on EPG
  • Teletext & Subtitle by OSD and VBI
  • Last channel memory function
  • Factory default channel list
  • Various games
  • Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
  • Parental, Installation & Receiver Lock
  • Zoom function on Pause & Live channel
  • Multipicture display
  • Support for multiple language broadcasts
  • SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
  • Multi TV Standards supported: PAL G, I, K, M & NTSC M with 4:3 & 16:9 Screen Formats
  • 90-250V AC 50/60 Hz
  • LNB Short Circuit protection onboard
  • 2 Scarts, (RGB, CVBS) & S-Video
  • Dimension 390X272X70 MM
Απάντηση: Technomate TM-6900 COMBO HD και TM-6800 HD
Ο "συμβατικός" TM-6800 HD, έρχεται με μονό tuner επιπέδου DVB-S/DVB-S2, PVR Ready και ίδια τα υπόλοιπα χαρακτηριστικά.
Technomate 6900 HD Combo (όχι το μοντέλο "super")
Καλησπέρα. Έχω το συγκεκριμένο μοντέλο δέκτη και ήθελα να ρωτήσω, αν κάποιος φίλος γνωρίζει κάτι σχετικά με το ίδιο μοντέλο, που έχει θύρα ethernet. Aν είναι ενεργοποιημένη και πιά είναι η χρήση της μέχρι τώρα. Επίσης, αν το νέο μοντέλο βγάζει σήμα RGB από το SCART, γιατί ο απλός (χωρίς τη θύρα ethernet), βγάζει μόνο CVBS μέσω του SCART, με συνέπεια να υποβαθμίζεται λίγο η ανάλυση στα SD κανάλια. Ευχαριστώ.
Re: TECHNOMATE 6900 HD COMBO
καταρχην να πουμε εδω οτι σε ολους τους δεκτες οι θυρες ethernet ειναι ενεργοποιημενες με την εννοια αναβαθμισης του δεκτη συδεσης του δεκτη με τον την σελιδα του κατασκευαστη(αν εχει )
ακομα μπορουμε να συνδεσουμε δυο δεκτες μεσα στο σπιτι μας αφου τον ενα τον κανουμε server εφοσον το menu του δεκτη το επιτρεπει
δες εδω ενα σχεδιο απο αυτον τον δεκτη
http://i692.photobucket.com/albums/vv284/fresh2/clip_image002-1.jpg
νομιζω και ο αυτο το μοντελο πρεπει να κανει τετοια θεματα αλλα δεν το γνωριζω
σιγουρα καποιος θα μας πει
Απάντηση: TECHNOMATE 6900 HD COMBO
Για το RGB, δοκίμασες και στα δύο Scart?
Μήπως αν απενεργοποιήσεις την Component ή την HDMI, ή να αλλάξεις κάποια ρύθμιση αυτών των δύο, να σου βγάλει RGB?
Σεραφείμ, εσύ που τον ξέρεις καλύτερα, δεν υπάρχει κανονικά επιλογή στα μενού για RGB?
*A/V In/Out TV SCART Video output (CVBS,RGB) · Audio output (L,R)
*VCR SCART A/V output (CVBS, L/R)A/V input (CVBS, RGB, L/R)
*Video RCA/ Cinch, Video output (CVBS)Component output (YPbPr)HDMI (High Definition Multimedia Interface)S-Video
Ευχαριστούμε φίλε Σεραφείμ!
Κι´ όμως, στις προδιαγραφές του δέκτη και σε διάφορα περιοδικά που είχα διαβάσει πριν τον αγοράσω, έλεγε ότι δεν βγάζει σήμα RGB από το SCART, αλλά μόνο CVBS.
Καλημέρα. Έχω προσπαθήσει να βγάλω σήμα RGB από το SCSRT TV, αλλά βγαίνει CVBS. Eπίσης, δεν αναγνωρίζει αυτόματα το 16:9 των καναλιών, που μεταδίδουν κάποια ταινία ή άλλο πρόγραμμα σε αυτό το φορμάτ και πρέπει να το κάνω χειροκίνητα από το κοντρόλ της τηλεόρασης. Γνωρίζει κάποιος φίλος τι μπορεί να φταίει;
Το scart που χρησιμοποιείς είναι πλήρες?
Δηλαδή, αν τα καλώδια που ενώνουν τα pin μεταξύ τους, δεν αφήνουν pin χωρίς καλώδιο.
Είναι πλήρες και με άλλους δέκτες (DREAMBOX 7020 και HUMAX 2000 HD) το ίδιο SCART βγάζει RGB. Eπομένως είναι θέμα δέκτη και το περιοδικό που είχα διαβάσει μάλλον είχε δίκιο, ότι ο συγκεκριμένος δέκτης βγάζει μόνο CVBS και από τα δυο SCART. Ίσως το πιο νέο μοντέλο, αυτό με τη θύρα ethernet να βγάζει σήμα RGB, χωρίς να σημαίνει βέβαια, ότι το ethernet παίζει κάποιο ρόλο σε αυτό. Ευχαριστώ.
Oι 2 επιλογες για τα setting του scart στο av output menu ειναι :
1) RGB (YPPR OFF)
2) CVBS (YPPR ON)
Φίλε sateliter, το τελευταίο που μπορώ να σκεφτώ, είναι αν έχεις την τελευταία αναβάθμιση.
Αν έχεις την τελευταία, δεν μπορώ να σκεφτώ κάτι άλλο τώρα.
Φιλικά...
Το υπομενού "a/v output settings" είναι σαν αυτό που βλέπουμε στην εικόνα του 'john 78' παραπάνω;
