Technotrend S2-3200 HDTV-S2 incl. Remote
AlexT_
10,458
Technotrend S2-3200 HDTV-S2 incl. Remote (WinXP, MCE)
Η πολυαναμενόμενη για μένα και αρκετούς άλλους HDTV-S2 δορυφορική κάρτα χαμηλού κόστους, αναμένεται να κυκλοφορήσει στα γερμανικά διαδικτυακά καταστήματα στις 26/10/2006. Η αντίστοιχη της σε USB είναι διαθέσιμη.
Η PCI κοστίζει 129 και η USB 149 .
Στα γρήγορα:
The best value, the right features all in a PCI card. The model TT-budget S2-3200 represents a low-cost reception device for basic applications. It features a complete DVB satellite receiver to receive data broadcasts, digital TV as well as radio programs and provides high-speed internet access. The TT-budget S2-3200, was especially designed to meet the demands of the mass market end consumer for easy of operation and plug & play installation and is a way to access the internet at DVB-compliant high-speed at the best value available. The incoming DVB transport stream is delivered to the PCI bus at a speed of up to 72 Mbps. An optimized software filter driver manages data processing downstream by filtering. An MPEG2 / MPEG4 software decoder for TV and radio applications is included for reception of digital TV and radio broadcasts. The TV and radio applications include features such as automatic channel parsing and record/playback capabilities.Pay TV applications can be supported by an optional CI extension. More than one budget card can be installed in one PC to receive various channels simultaneously. An easy-to-use multilingual data management utility is provided to adjust channel and filter settings and to monitor incoming data. For third-party software developers an open API (application programming interface) is available.
Basics
• Low-cost PCI card for Free-TV and data application
• DVB® satellite receiver accordingly to EN 302 307
• Video and Audio decoding via software decoder
• Recording and Play back of TV/Radio programs
• Time shift support
• Teletext decoding by software
• Multicast Management support by NDIS driver
• MPEG2 Transport Stream support: ISO/IEC 13818-1
• DVB-Video/-Audio support: ISO/IEC 13818-2, -3
• DVB-Data support: EN 301 192
RF specification
• Frequency range: 950-2150 MHz
• QPSK demodulation accordingly to EN 302 307
• RF input level: -65 up to –25 dBm
• input connector: IEC F-type female
• LNB control: 14/18V, 22 kHz, Tone Burst, DiSEqC 1.0, max. 400 mA
For DVB-S
• SCPC/MCPC support up to 45 Msymbols/s
• QPSK with supported rates 1/2, 2/3, 3/4, 5/6, 6/7, 7/8
• Viterbi soft decoder rate ½
• outer Reed-Solomon decoder as per DVB-S system
• Up to 60 Mbps channel bit rate
Technical Specification TT-budget S2-3200
TechnoTrend AG © 2006 Page 2 of 2 1.0
For DVB-S2
• SCPC/MCPC support up to 30 Msymbols/s
• QPSK and 8PSK with supported rates
• 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
• LDPC and BCH decoder as per DVB-S2 requirements
• Digital Nyquist root filter with 0.20, 0.25, 0.35 roll-off factors
• Up to 90 Mbps channel bit rate
Advanced Functionality
• HDTV support; AC3 5.1 Software decoder
• TV, Radio and data services on notebooks or PC via USB 2.0 interface
• Representation, Record (incl. Timer) and Playback of TV and Radio services
• Operation System support: Windows XP
• Time shift features and record timer
• Extended EPG functionality
• Teletext support
• Automatic Channel Setup using IP multicast group address
• IP-Unicast Transport using dynamic IP address to MAC address mapping
• Support MAC Address Filtering
• Use of up to 255 PID filters
• Download MPEG-2 PES speed up to 90 Mbit/s
Minimum PC requirements
• Pentium III 1GHz
• Supported Operating System: Windows 2000, XP™
• DirectX 9 or higher
• Sound card
• CD-Rom (Driver and Software installation)
For HDTV (1080i / MPEG4 (AVC/H.264) )
3.4 GHz P4 (Single Core with Hyperthreading) or
2.2 GHz AMD 3500+ or
Dual Core P4 D820 / D830 or
Dual Core AMD X2 3800+
with graphics card: ATI X1600/X1800 or NVidia 6600GT/7600GT
Accessoires
• Receiver and CI PCI board (CI is optional) each ca. 120 x 106 x 18 [mm]
• 1 connection flat ribbon cable to link receiver and CI board (optional accessoires)
• Master CD-ROM with driver and application software
• License for MPEG2 and MPEG4 (AVC/H.264) - Software
decoder
• Optional Common Interface extension for Pay-TV
Standard and Regulation Compliance
• DVB® satellite standard EN 302 307
• MPEG2 Transport Stream support to ISO/IEC 13818-1
• DVB-Video/-Audio support to ISO/IEC 13818-2,-3
• Safety and EMC regulations: EN 60950, EN 55022 and EN 55024
This Product is expected to be on stock again on Thursday, 26.
October 2006
Larry
Μέλος Δ.Σ.
21,630
Αιμιλιε μολις ερθει στα χερια μας θα φαει χεριασμα τρελλο ηδη τρεις HTPcαδες ειναι stand by for
stay tuned
AlexT_
10,458
Το διεθνές περιοδικό TELE SATELLITE, τεύχος 10_11/2006 (και στην ελληνική έκδοση) έκανε δοκιμή την συγκεκριμένη κάρτα. Τα συμπεράσματα είναι πολύ θετικά.
Καταρχήν να αναφερθεί ότι η κάρτα κάνει software decoding.
Για την δοκιμή χρησιμοποιήθηκε επεξεργαστής Intel Pentium 4 στα 3.7 GHz
Σε ότι αφορά την λήψη SDTV έχει τυπική συμπεριφορά όπως όλες οι αντίστοιχες κάρτες και η κατανάλωση πόρων του υπολογιστή είναι μικρή.
Στην αποκωδικοποίηση HDTV καναλιών ο επεξεργαστής έφτασε στα όρια του. Οταν γίνεται λήψη τέτοιων καναλιών συνιστάται να μην τρέχουν κι άλλες εφαρμογές. Οπως αντιλαμβάνεστε θέλει δυνατό επεξεργαστή και ακόμα καλύτερα διπλού πυρήνα. Μια καλή κάρτα γραφικών επιβάλλεται.
Στα ευχάριστα συγκαταλέγεται η συνεργασία με το δημοφιλές ProgDVB καθώς και με το DVB Viewer. Σύμφωνα με το περιοδικό, έγινε λήψη HDTV καναλιών με το ProgDVB, παρά την έλλειψη υποστήριξης από το πρόγραμμα!!
Θοδωρής Κ.
25 June 2006
915
Βόρεια
Καλά τα νέα όντως και τώρα θα πέσει ανταγωνισμός και εύχομαι να δούμε και άλλες φθηνές κάρτες .
….Φθηνές ? Τι φθηνές δηλαδή βαλε και αλλαγή το PC ολόκληρο! Άντε πάλι το χέρι σ´αυτήν την έρμη τσέπη!
Emilot
32,823
Εξάρχεια
Παίδες αν έχει κάποιος κινητό πιάτο, ας δοκιμάσει να το κουνήσει με την κάρτουλα, να δούμε αν υποστηρίζει Diseqc!!
THanx!!!-bye-
AlexT_
10,458
Μετεφέρω αυτούσια την αναφορά περί Diseqc 1.0, 1.1 και 1.2 (μοτερ) απο το περιοδικό TELE SATELLITE:
"[FONT=&quot]Το ενσωματωμένο πρωτόκολλο DiSEqC 1.0 σας επιτρέπει να χρησιμοποιήσετε αυτήν την κάρτα με μέχρι τέσσερα μεμονωμένα LNB.
Το πρωτόκολλο DiSEqC 1.1, που θα σας επέτρεπε να ελέγξετε μέχρι 16 LNB, δυστυχώς δεν είναι διαθέσιμο.
Εάν διαθέτετε ένα μοτέρ DiSEqC μπορείτε να το χρησιμοποιήσετε, το ενσωματωμένο πρωτόκολλο DiSEqC 1.2 σας επιτρέπει να ενεργοποιήσετε επίσης ένα μοτέρ με αυτήν την κάρτα. Γενικά όμως, καλό θα ήταν να μην χρησιμοποιήσετε ένα μοτέρ με αυτή την κάρτα. Η τάση ελέγχου 14/18-volt για το LNB προέρχεται από την εσωτερική τάση τροφοδοσίας 5-volt της υποδοχής PCI. Το μοτέρ θα χρησιμοποιούσε αυτήν την τάση και θα μπορούσε να καταστρέψει την κάρτα.
"[/FONT]
Emilot
32,823
Εξάρχεια
ΟΥΑΟΥ!!!!
ΤΗΝ ΘΕΛΩ ΤΩΡΑΑΑΑΑ!!
Καλά με τα volt κπλ, τα λέγανε και με την Skystar 2, αλλα 3 χρόνια τώρα, δεν καταλαβε Χρηστό!!!
AlexT_
10,458
Κι εγώ την θέλω..
Στη Γερμανία έχει εξαντληθεί. Υπάρχει διαθέσιμη μόνο με CI, στα 154,90 και η αντίστοιχη σε USB στα 149.
AlexT_
10,458
Αντε να αυξάνονται οι DVB-S2 κάρτες..
Η παραπάνω κάρτα είναι ακριβούτσικη σε σχέση με την Technotrend. Κοστίζει 159 + την προσθήκη CI 44,90 = 203.90 . Η αντίστοιχη της Technotrend με CI κοστίζει μόλις 154,90 .
Και αυτή κάνει software αποκωδικοποίηση, αλλά το δυνατό χαρτί υπέρ της Technotrend, εκτός από την χαμηλή τιμή της, είναι η δοκιμασμένη συνεργασία της με το Progdvb με ότι αυτό σημαίνει σε "έξτρα δυνατότητες"
Γενικά πάντως θα περίμενε κανείς πληθωρική παρουσία DVB-S2 καρτών στην αγορά. Δυστυχώς όμως για την ώρα μετριούνται στα δάχτυλα του ενός χεριού.
viagras
20 June 2006
1,847
Εμιγγράντε
Απάντηση: Re: Technotrend S2-3200 HDTV-S2 incl. Remote
Μόλις τώρα είδα αυτό το λίνκ, το οποίο είναι η δοκιμή που αναφέρεις σε αρχείο .pdf.
