ΠΩΛΗΣΗ Τελικος Rotel 1075
Larry
Μέλος Δ.Σ.
22,336
Πωλείται σε πολύ καλή κατάσταση χωρίς ποτέ να φτάσει σε υψηλές στάθμες ούτε να χρησιμοποιηθεί αντάξια των δυνατοτήτων του
Rotel RMB-1075
Features
THX-Ultra certification.
Large 1,500 VA Toroidal transformer.
Eight 10,000 µF British-made Slit Foil capacitors.
20 high-current output devices, 4 per channel.
Gold plated RCA and DB-25 input connectors.
Separate 12 volt “trigger ” input and output jacks.
Specifications
Frequency Response: 15Hz - 100kHz +0.5dB, -3dB
DIN Power Output (1 kHz, 1%): 5x200 watts per channel at 4 ohms
Five-Channels rated at 120 Watts per channel at 8 ohms
Five-Channels rated at 200 Watts per channel at 4 ohms
Total Harmonic Distortion (20 Hz - 20 kHz, 8 ohms): 0.03% maximum
Damping Factor (20 - 20,000 Hz, 8 ohms): 180
Signal to Noise Ratio (IHF A network): 116dB
Input Impedance/Sensitivity: 1.0 V / 33 kOhms
Power Requirements: 115 volts, 60 Hz (U.S. version), 230 Volts, 50 Hz (European version)
Power Consumption: 800 Watts
TIMH 700
