- 5 September 2007
- 1,405
TF7700HSCI σύντομα PVR Ready!!!
Όσοι έχετε στην κατοχή σας τον HD δέκτη της Topfield TF7700HSCI, ετοιμαστείτε έρχεται νέο λογισμικό στο τέλος Ιανουαρίου που κάνει τον δέκτη PVR Ready(It will be updated by the end of this month)…Για περισσότερα εδώ:
http://www.topfield.co.kr/
USB PVR Ready
Fully DVB-S/DVB-S2(H.264) HD compliant
2 Common Interfaces for CONAX, CRYPTOWORKS, IRDETO, NAGRAVISION, SECA & VIACCESS
DiSEqC 1.0, 1.1, 1.2 and USALS(DiSEqC 1.3)
5000 services (TV and Radio) programmable
Multilingual audio support
Multilingual menu text support
Service list editing
Favorite service list editing
True-color On-Screen Display (OSD)
Electronic Program Guide (EPG) for on screen service information
Subtitle supported
Teletext supported by VBI insertion and software emulation
Parental lock facility by service and program event
Firmware upgrade by USB2.0
Firmware and Data transfer from receiver to receiver
S/PDIF for digital audio or Dolby AC-3 bitstream output
USB 2.0 supported for fast PC interface
MP3 decoding
VFD Display for service information
Component (YPbPr) output
Tuner & Channel Decoder
Input/Loop through Connector F-type, IEC 169-24, Female
Frequency Range 950 ~ 2150MHz
LNB Power & Polarisation
Vertical : +13.5VDC
Horizontal: +18VDC
Current : Max.500mA with Overload Protection
22KHz Tone
Frequency : 22ϴΎ1KHz
Amplitude : 0.65ϴΎ0.2V
Demodulation QPSK
Input Symbol Rate 1?shy;45 Msps
Code Rate 1/2, 2/3, 3/4, 5/6 and 7/8
Transport Stream A/V Decoding
Aspect Ratio 4:3, 16:9
Video Resolution 576i, 576p, 720p, 1080i
Main System
Main Processor ST40
A/V & Data In/Out
HDMI HD Video/Audio Output
TV Scart Video CVBS/S-VIDEO/RGB/YPbPr, Audio L/R output
VCR SCART Video CVBS output
Audio L/R output
Video CVBS/S-VIDEO/RGB/YPbPr input for bypass
Audio L/R input for bypass
S-Video Video S-VIDEO output
Component YPbPr output
RCA A/V Video CVBS output
Audio L/R output
RS-232C 9 pin D-sub type
Transfer rate : max. 115.2Kbps
USB USB2.0 Host
Conditional Access Interface
PCMCIA 2 slots
DVB Common Interface standard
Front Panel
Keys 5 Keys (CH-/+, VOL -/+,STANDBY)
VFD Service information or Time display
RCU 37 Keys
Power Supply
Input Voltage 90 ~ 250VAC, 50/60Hz
Type SMPS
Power Consumption Running : Max. 37W, Standby : 8W
Protection
Separate internal fuse.
The input shall have lightning protection
Physical Specification(340mm Model)
Size(W x H x D) 430 x 60 x 265 mm
Weight(net) 2.88 kg
USB PVR Ready
Subtitle supported
MP3 decoding
Vertical : +13.5VDC
Horizontal: +18VDC
22KHz Tone
Demodulation QPSK
Main System
Main Processor ST40
A/V & Data In/Out
Audio L/R output
Audio L/R output
USB USB2.0 Host
PCMCIA 2 slots
Front Panel
RCU 37 Keys
Power Supply
Type SMPS
Protection
Weight(net) 2.88 kg
