The Gemini Project 3.00
AlexT_
10,461
Νέο Image Gemini Project 3.00 για όλους τους τύπους Dreambox απο το Gemini Team! (πλην του 7025)
Ενδεικτικά τα χαρακτηριστικά για τον 7020s:
Gemini v3.00:
Technical Infos:
* Enigma of: 21.06.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini news in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside,
mountpoint set to "/mnt/usb" and at least 3GB disk space)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000 )
* cifs-1.42b
New:
* The image does now contain a useraddon.xml in /etc ml for 7020, /var/tuxbox/config for 500 to 7000 to enter an own addon server
which will be additionally displayed in BluePanel -> Addons -> Download. The file actually contains a example.
* multisocket second camd socket (cam1.socket) switchable.
Fix:
* New drivers rel1.10 (=7000)
* Attend CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread.
Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16MB) should be present if several processes running in background.
Download via Database
Thanks a lot and have fun
Your Gemini-Team
Support: www.i-have-a-dreambox.com
Αυτά τα δύο θα ήθελα να δοκιμάσω.
Ο απλος χρηστης (σαν εμενα) δεν νομιζω οτι θα δει καποια διαφορα. Αλλα απο συνηθεια αναβαθμιζομαι παντα, αν και ισως θα επρεπε να ακολουθω το (αν δουλευει μην το πειραζεις). Παντως το εβαλα απο εχτες και δεν ειδα κατι δραματικο που να αξιζει την αναβαθμιση. Εκτος αν εχετε σκοπο να χρησιμοποιησετε αυτα που λεει ο Αλεξης πιο πανω
H σημαντική αλλαγή είναι πως μπορείς να προσθέσεις και άλλον addon server ο οποίος θα εμφανίζεται στο control panel και από εκεί να γίνεται η διαχείριση του.
(Οπως συμβαίνει και στο Pli image.)
Με τον τρόπο αυτό μπορείς να κατεβάζει κανείς addons και απο άλλους servers.
π.χ. μπορεί να προστεθεί η δυνατότητα online download ελληνικών υποτίτλων συμβατών με το format που αναγνωρίζει ο Dream δηλαδή .dtc
Σημαντική είναι η προσθήκη επίκαιρων drivers για τον 7020 και η εναρμόνιση με τους drivers που χρησιμοποιεί το νεο firmware 1.10 του Dreambox 7000 για την απροβλημάτιστη χρήση σε usb stick και CF.
Για όσους έχουν τον 7000 είναι must. Και μόνο οι drivers φτάνουν. Τέρμα τα κολλήματα (σχεδόν) και πιο γρήγορο shutdown.:firstprize:
Απάντηση: Re: The Gemini Project 3.00
skek, πρώτα απ' όλα καλώς ήρθες στο Avclub -bye-, κατά δεύτερο μου δημιούργησες μερικές απορίες:
- που το ξετρύπωσες το Gemini v 3.00? Η επίκαιρη έκδοση είναι πλέον η 3.60
- Σκέτος χείμαρρος στο πρώτο σου μήνυμα! Το κρυπτογραφημένο σου μήνυμα θέλει να μας πει κάτι??
Καλή συνέχεια..
