The Gemini2 Project 4.10 DM800
leo06
14 October 2007
7,017
Πάτρα
Gemini2 v4.1
DM7025 = Enigma from 06.02.2009
DM800 and DM8000 = Enigma from 07.02.2009
Most Functions are described in our Wiki.
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP (DM7025)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED -> File Manager
* RED - Record
* GREEN - Quickbutton / Subservices
* Yellow - Timeshift (not for DM8000)
Extras:
* Own Addon-Server via internet.
* Cryptinfos of the Stations. Assign different Camds to Stations/Providers (AutoCam).
* Manage many Daemons / Server (BP - Services/Daemons)
* Visual improvements such as HD-Skin, icons or additional adjustments to the station list
* Manager for formatting, setting up or integration of devices (BP-> Device Manager)
* additional EPG functions, such as Autosave, Refresh, or connect different EPG formats
* Own Addons e.g. Dreamnetcast, jukebox, calendar, e-mail or eTorrent to name just a few
* Quick button (select the function of the green button via the menu)
* detailed information about your Dreambox (Menu-> information)
* File Manager, it is possible to handle all formats, regardless of whether images, sound, film material, playlists, Torrents, scripts or DVDs (BP-> File Manager)
Many other functions, such as "the GP2 Controlr" Rezapp or the many options can in IHAD board or our Wiki to be read.
New:
* File-Manager extended (Information, display and favourites). It´s now eaysier to achieve, simply press BLUE-RED
* In the channel list, the distance between the stations and the actual EPG event can be changed by yourself (BP-> Settings-> General)
* At Dreamnetcast and the jukebox you can chose the background
* Menu´s extra/settings seperated. BP has partly new construction (Addons are now at BP-> Settings to find)
* Discrete OFF(Standby) by shift-0, ON by shift-1, OFF (Deep Standby) by shift-2 (DM8000 not with original Remotecontrol)
Fix + Update:
* Formatting the Harddisk
* Dreamnetcast, Jukebox
* see CVS
Known problems:
* Bootpictures
* fast changing of tracks in the jukebox when covers from internet is activated
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
http://www.i-have-a-dreambox.com
download http://www.i-have-a-dreambox.com/wbb2/database_arc.php
Error
You want to download the following file: http://rapidshare.com/files/195586552/gemini2-410-dm800-200902071831.nfi.zip | 36255 KB
We regret that currently we have no available slots for free users. Unfortunately you will have to wait 2 minutes, this will allow us to continue to provide our service to our Premium users. Afterwards it will be checked again if you can access the file. If you do not want to wait that long, become Premium member:violent-smiley-030::violent-smiley-030::violent-smiley-030:
Απάντηση: Re: The Gemini2 Project 4.10 DM800
οχι ακομη ειμαι ευχαριστημενος με το black hole 07 οποτε δεν προβλεπετε αμεση εγκατασταση,ισως μονο για να το δοκιμασω
Συμφωνώ με την ενωτερότητα του nabilo έναντι του gemini, όμως δυστυχώς έχει μείνει πίσω σε drivers κλπ. Μία λύση ασφαλώς είναι η εγκατάσταση με το χέρι, αλλά δεν είναι και το πιο ορθολογιστικό.
Θα έλεγα ότι μάλλον πρέπει να περιμένουμε σύντομα νέα διανομή από τη nabilo team για να φέρει τα πράγματα "στα ίσα".
Εγκαθιστώ τώρα σε multiboot το 4.1
Αποτελέσματα με νεώτερο...
Re: Απάντηση: Re: The Gemini2 Project 4.10 DM800
Πες μας εντυπωσεις...το vlc απο το pc προς το DM υπαρχει σαν plugin στον 4.1?Το Nabilo 0.7 εχει προβληματα κολαει ενω το 0.6 ηταν πολυ καλυτερο στο vlc
Απάντηση: Re: Απάντηση: Re: The Gemini2 Project 4.10 DM800
Μέχρι στιγμής όλα ΟΚ.
Δείχνει σταθερό. Εναλλαγές καναλιών γρήγορες και χωρίς κολλήματα.
Το Linksys wireless stick συνεχίζει να δουλεύει απροβλημάτιστα.
Web interface ΟΚ καθώς και streaming των καναλιών. Συνεχίζει πάντως να μου λείπει τρομερά το web interface του enigma1...
Εγκατέστησα όλα τα "χρειαζούμενα". Δεν συνάντησα πρόβλημα.
Το vlc φυσικά και υπάρχει. Γιατί να μην υπήρχε; Το δοκίμασα και δουλεύει επίσης ΟΚ.
Δοκιμή με ένα mkv και υπότιτλους από το σκληρό επίσης επιτυχής.
Τι να πω... Πρώτη εντύπωση ικανοποιητική. Μου ξαναδίνει την εμπιστοσύνη προς το gemini που είχα χάσει. Έχω την εντύπωση ότι μπαίνουμε σε μια εποχή που τα images ωριμάζουν αρκετά μέσα από τον "ανταγωνισμό" τους. Και αυτό ασφαλώς είναι προς το συμφέρον μας ως χρήστες. Σύντομα νομίζω (αν δε συμβαίνει ήδη) θα επιλέγουμε image με αυστηρά προσωπικά κριτήρια καθώς σε δυνατότητες και σταθερότητα θα είναι όλα στο ίδιο επίπεδο...
παιδια το περασα ολα καλα μεχρι τωρα αργοτερα θα σας πω και αλλα
Στo Downloads Manager σου εχει επιλογη για να κατεβασεις το vlcf?Αν ναι να το εγκαταστησω και γρηγορα μαλιστα...
Re: Απάντηση: Re: Απάντηση: Re: The Gemini2 Project 4.10 DM800
Web interface ΟΚ καθώς και streaming των καναλιών. Συνεχίζει άντως να μου λείπει τρομερά το web interface του enigma1...
+100 experimenetal 07.02.09 sti flash
sto usb
newnigma 2.3.1
blackhole 0.7
gemini4.0.1 ολα μια χαρα επαθα πλακα μπραβο τους :grinning-smiley-043
πανε μεου plugin και μετα κατεβασμα plugin και μετα στα extensions εκει ειναι για κατεβασμα-bye-
Αυριο αμα ειναι θα το εγκαταστησω και εγω.Εχω κανει το λαθος και δεν εχω μαθει ακομα πως μπορω να εγκαταστησω ενα σταθερο image και μετα να αλλαζω μεσω usb αλλα images και ετσι πρεπει να κάνω καθαρη εγκατασταση απο την αρχη.
για πιο ευκολία χρησιμοποιούμε τo putty ανοίγουμε telnet και δίνουμε.
mount /boot -ο remount,rw
rm /boot/*
reboot
μπαίνουμε στον router μας και βλέπουμε τη ip έχει πάρει ο dream τώρα που μπήκε sleep mode
βάζουμε την ip του dream στον browser μας και φλασαρουμε τo νέο μας image,στην περίπτωση μας τo τελευταίο oozoon lean.
αφού περάσουμε τo νέο μας image και είναι κομπλέ με κανάλια ρυθμίσεις μέσα από τo oozoon πάμε plugins και κατεβάζουμε τo barry allen
.κάνουμε τις ρυθμίσεις μας στο πληγήν και κατά προτίμηση τo ρυθμίζουμε να βάζει τα image στην usb και όχι στον σκληρό ώστε να μην δουλεύει ο σκληρός συνεχεια.
αφού τελειώσουμε του περνάμε τα image που θέλουμε.οποιος έχει απορίες πως περνάμε τα images με τo barry allen ας τo ρωτήσει εδώ να βοηθήσουμε.
rm /boot/*
reboot
Η παραπάνω μέθοδος είναι μεν σωστή (από απόψεως unix) όμως πρακτικά δεν θα τη συνιστούσα.
Με τις παραπάνω εντολές το dreambox μπαίνει σε Stop Mode (όχι σε sleep mode όπως γράφεις εκ παραδρομής φαντάζομαι) αλλά είναι αδύνατον να βγεις μετά από αυτό με ένα απλό On-Off. Έτσι αν κάτι δεν πάει καλά, είτε στις εντολές είτε στο φλασάρισμα τότε η επαναφορά του image με τη σειριακή είναι μονόδρομος.
Η κλασική μέθοδος με τη διαδικασία Power Off και μετά Power ON με το κουμπί πατημένο είναι ασφαλέστερη. Όσες φορές και να μπεις σε Stop Mode, με επανεκκίνηση είσαι ΟΚ.
Οπότε νομίζω ότι η πρώτη μέθοδος δεν αξίζει το ρίσκο.
