The Gemini2 Project 4.30 DM800
leo06
14 October 2007
6,993
Πάτρα
Gemini2 v4.3
Enigma vom 12.06.2009
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions, like "the GP2 Controlr", Rezapp or the other settings can be found at the IhaD-Board or our Wiki.
New:
* Jukebook updated -> search for ID3-Tag or file name
* folder of BSOD-Logs can be edited (BP -> Settings -> General)
* brightness of the Power-LED (DM8000) can be adjusted (BP -> Settings -> General)
* multiple units can be released in the network with NFS-Server
* Skin of Samba, Crond and NFS standardized
* static Webinterface for mobile devices => /mobile/
* Online-Test can be configured (Server and Intervall) (BP -> Services)
Fixes + Updates:
* many fixes in case with udev (thx to all user that helped us)
* USB-Stick with partitions should be listed now correctly.
* see CVS
Important:
* if you want to use the nfs-server you must install the fix from the BP-Addon-Server
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
Download via Database
Thank you and have fun
Your Gemini-Team
http://www.i-have-a-dreambox.com
download http://www.i-have-a-dreambox.com/wbb2/database.php
Καμια διαφορα?Που παρατηρησατε εσθητη σε σχεση με το προηγουμενο!
Δεν έχει κάτι το ενδιαφέρον απλά η ομάδα δεν μας τα λέει καλά τώρα τελευταία.
Αν και πρεπει νομιζω να ειναι η πρωτη στον χωρο!!!
Εγω το λεω και θα το λεω nabilo-newnigma δεν βολεβομαι με τιποτα αλλο και τωρα που λειτουργω πολυ τον σκληρο βλεπω οτι οι εγγραφες φευγουν σφερα απο την στιγμη που πατησω το κουμπι!!-bye-
Εχω κάποια "θεματάκια" με την έκδοση αυτή του Gemini.
Πρώτον, το EPG στη Nova μια δουλεύει, μια όχι. Δηλαδή... σε κάποια κανάλια δίπλα εμφανίζεται, σε κάποια άλλη όχι. Κάνω ενα restart, παίζει ΟΚ, μετά απο λίγο σε κάποια κανάλια χάνεται πάλι. Τι παίζει? Μπορώ να κάνω κάτι γι'αυτό?
Δεύτερον, τρώει κολλήματα με τα cams και συγκεκριμένα με το mgcamd. Οταν μπαίνει ο δέκτης σε κατάσταση αναμονής και μετά ξαναανοίγει, το cam 9 στις 10 δεν δουλεύει, πρέπει χειροκίνητα να πατήσω "start-stop cam" για να πάρει μπρος.
Τρίτον, υπάρχει τρόπος όταν κάνω αναπαραγωγή των εγγραφών που έχω στον σκληρό, να βγάζει κάτω μια μπάρα ωστε να βλέπω σε ποιό σημείο βρίσκομαι?
Τέταρτον (λίγο offtopic) Μπορώ μέσω barry allen να βάλω άλλα image στον σκληρό? Πρέπει οπωσδήποτε να είναι σε usb-stick?
Ευχαριστώ.
Ευχαριστώ.
4ον: Μπορείς και στον σκληρό αλλά θα δουλεύει...υπερωρίες χωρίς λόγο και δεν συνιστάται για την μακροζωία του
Τα 1-2 δεν τα παρατήρησα (στο 4.30 στον 8000) με το 3 δεν έχω ασχοληθεί ιδιαίτερα οπότε δεν ξέρω
Εγω εχω την 1GB εκδοση αυτου και με εχει βγαλει παληκαρι εβγαλα και το πλαστικο απο πανω για να ψυχετε καλυτερα και ολα ok καθε μερα μερα νυχτα ανοιχτο και τον σκληρο τον εχω βαλει μεσα απο το newnigma αμα δεν τον χρεισημοποιω μεσα σε 10 λεπτα να κληνει!!
Το link:
http://www.e-shop.gr/show_per.phtml?id=PER.569154
εγώ έχω βάλει barry allen στον δίσκο με ένα image και έχω timeout 5 λεπτά στον δίσκο και κλείνει. Δεν λειτουργεί συνέχεια.
Ναι αλλα το image πως λειτουργει γιατι λογικα οταν ειναι standby και διχνει το clock/ΗΜ λογικα πρεπει να περνει καποια cabs απο το image!
