The Gemini2 Project 4.60 DM800
leo06
14 October 2007
6,968
Πάτρα
Gemini2 v4.6
Enigma from 24.12.2009
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions, like "the GP2 Controlr", Rezapp or the other settings can be found at the IhaD-Board or our Wiki.
New:
* Kernel prepared for Multiboot
* CryptSymbols can be displayed as images now (for example look inside the xkin.xml)
* The Jukebox can handle Audio-CDs now (for DM800 and DM7025 you have to install further 2 LIBS). Please load the driver for CDFS (BP->Settings->Kernel-Modules)
* The Jukebox can show 3 covers at the same time now, which are cached too (settings in the Jukebox menu)
* We saved about 20 screens at the skins (Info at BPskin.py)
* Small InfoScreen in Menu->Info->Gemini-Config about the settings Gemini saves and manages. The config file can be saved immediately (ie for Backup)
* TPMD (TPM-Daemon by DMM) can be deactevated by BP->Daemons
* USB devices will be mounted by their names now
* NTFS-Filesystem (Windows) can be mounted as Read-Write (This has to be installed from BP->Settings->Extensions->GeminiServer->Plugins
* Fan- and Temperaturesensors added to the Hardwareoverview (Menu-Info-Hardware)
Fixes + Updates:
* Jukebox, Dreamnetcast
* Skin
* Network Information (Menu->Info->Hardware)
* see CVS
Important:
* Just use skins, which are adaptet for this Version, otherwise Enigma won't boot anymore!
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
Download via Database
Thank you and have fun
Your Gemini-Team
http://www.i-have-a-dreambox.com/wbb2/database.php
pff Καλα που δεν το περασα (παιδια γυρισα στα παλια ο δεκτης αψογως)oozoon στην flash και με BA nabilo και newnigma!-bye-
Εγω το εχω βαλει απο την πρωτη μερα που βγηκε και παιζει θαυμασια.Πολυ καλο και το read/write στο εξωτερικο σκληρο που εχω
Autoresolution not working at all, GUI dmm-HD or Kerni1 is very slow in navigation for no reason, smbfs tranfer rate is at 5Mb/s max when it used to be on averrage 8Mb/s(100Mbps/8bits=12,5Mb/s plus any overheads 11Mb/s).
Wishlist: DTS for mkv.
Το autoresolution μια χαρά λειτουργεί σε μένα. Για τα άλλα δεν γνωρίζω μιας και τις μεταφορές τις κάνω με ftp και χρησιμοποιώ άλλο skin.
dts dont work on dm800 hardware problem .
on dm8000 work fine !!
