IRDETO CAS embedded
Fully DVB compliant
5000 Service TV & radio programmable
Multilingual audio/ menu text supported
Favourite/Service list editing
DiSEqC 1.0, 1.1, 1.2 and USALS(DiSEqC 1.3) supported
Electronic Program Guide (EPG) supported
Parental lock facility by service and program event
Subtitle/Teletext supported
Firmware upgrade by Over-The-Air
DVB Compliant A/V Decoding
Aspect Ratio 4:3, 16:9
Video Resolution 720 X 576
RCU 42Keys
A/V & Data In/Out
RCA A/V Video (CVBS), Audio (L/R) output
RS-232C 9 pin D-sub type, Transfer rate : max. 115.2Kbps
Power Supply
Input Voltage 90 ~ 250VAC, 50/60Hz
Power Comsumption Max. 24W
Protection Separate internal fuse
Size(W x H x D) 260 x 46 x 190mm, Weight(Net) 1.2Kg
Το νέο μοντέλο της Topfield διαθέτει IRDETO
είναι ετοιμοπαράδοτο και
διατείθεται στην τιμή των 99,00 από το dektadiko.gr
