Vidikron Vision Model 80
Browser
10,573
Ultra High Resolution D-ILA™ Technology for Pristine Video Images
3-Chip D-ILA Configuration with Native 16:9 Aspect Ratio
1920 x 1080 Native Resolution — Over 6 Million Pixels
Vidikron’s Exclusive Imagix™ Video Processing with Separate Controller/Processor for Outstanding Image Fidelity
1050 ANSI Lumens /CSMS™
Light Output of 18.1 ft-Lamberts
2100:1 Contrast Ratio
Discrete Aspect Ratio and Source Selection
DVI Input with HDCP
Discrete IR and RS-232 Control
Vision Model 80 Specifications
Projection Type:
D-ILA, 3-chip, 0.82 in. diagonal
Native Resolution:
1920 x 1080 (16:9)
Aspect Ratio:
4:3, Letterbox, 16:9 Anamorphic
Video Standards:
NTSC, PAL
DTV Compatibility:
480p, 720p, 1080i, 1080p
Picture Size: (16:9 screen)
Recommended Width: 72–96 in.
Maximum Width: 240 in.
Light output:
CSMS* Specifications:
Home Theater Calibration: 491 ANSI Lumens;
18.10 Foot-Lamberts (fL); 1050 ANSI Lumens
Contrast Ratio:
2100:1 ANSI
Lamp:
250 W UHP
Estimated Lamp Life:
2000 hours @ 6500º Kelvin
Inputs:
(1) DVI w/ HDCP,
(1) RS-232
Power Requirements:
100–240V AC, 350W
Operating Environment:
40°–95° F, (5°–35° C)
Dimensions (w/o feet):
Width: 18 in. (457.2 mm)
Depth: 20 1/8 in. (511.18 mm)
Height: 6 in. (152.4 mm)
Weight: 40 lbs. (18.14 kg)
Regulatory Approvals:
FCC, CE, C-Tick
Limited Warranty:
Projector: (2) Two year parts and labor from the date of delivery to the end user. Lamp Warranty: (6) six months or 1000 hours.
VDP-80™ Video Controller/
Processor
VDP-80 Specifications
Video Standards:
NTSC, PAL
Output Resolution:
720p or 1080p
Outputs:
(1) HD – R (Pr), G (Y), B (Pb), H, V, (1) DVI w/HDCP
Analog Inputs:
Analog inputs can be configured in memory for various combinations.
A typical example would be:
(1) Composite; (1) S-Video;
(2) Component; (2) RGB; (2) SDI
Digital Inputs:
(2) DVI w/HDCP
Control Options:
Discrete infrared remote; (1) RS-232
Power Requirements:
5V DC via supplied 100 – 240 V AC (auto sensing) 50/60 Hz, 30 W AC/DC adapter
41 – 95 F, (5 – 35 C)
Dimensions:
Width: 17 7/16 in. (442.92 mm)
Depth: 11 3/8 in. (288.92 mm)
Height: 3 1/2 in. (88.90 mm)
Weight: 15 lbs. (6.8 kg)
FCC, CE, C-Tick
Limited Warranty:
(2) years parts and labor from the date of delivery to the end user
All specifications subject to change without notice. Optional wall mount bracket and tabletop stand are available.
http://www.vidikron.com/vm80.html
Κι ομως Λευτερη, το μοντελο αυτο, οπως κι αλλα της εταιριας δεν ειναι και πολυ καινουργια.......
Δειτε εδω που εχει ολη τη σειρα με τους προβολεις της vidikron...
http://www.vidikron.com/vision.html
Εντυπωση μου κανει οτι ακομα και οι νεοι 3chip dlp 1080, στα specs αναφερουν πανελ HD2+........!!!!
Καλη η Vidikron και ίσως από τις κορυφαίες εταιρείες στα επαγγελματικά μηχανήματα, αλλά οι consumer προβολείς είναι στα αζήτητα στην ελληνική αγορά.
