Main Features:
- The latest 802.11a / b / g / n / ac WiFi standard: more reliable streaming for your home computers and mobile devices
- Simultaneous dual band 2.4GHz and 5.0GHz networks, it can be up to 2600Mbps
- Four external antennas for faster wireless performance at greater distances
- Manage your network settings easily with the Xiaomi MiWiFi App
- Its appearance is beautiful and elegant, and it becomes smaller and lighter
- Τιμή 102 στο Gearbest
Specification
[TABLE="width: 1149"]
[TR]
[TH="align: center"]Product Detail[/TH]
[TD]Interface: 2.5MM DC Jack,LAN,USB 3.0,WAN
Router Connectivity Type: Wireless
Transmission Rate: 2600Mbps
Speed of Ethernet Port: 1000Mbps
Network Protocols: IEEE 802.11a,IEEE 802.11ac,IEEE 802.11b,IEEE 802.11g,IEEE 802.11n
Wireless Standard: Wireless AC
Wireless Security: WEP,WPA,WPA2-PSK
WiFi Distance : 200 square meters
Supports System: Linux,Mac OS,Win 2000,Win vista,Win XP,Windows 7,Windows 8,Windows 8.1
LAN Ports: 3 ports
Max. LAN Data Rate: 1000Mbps
Freq: 100Hz - 16KHz
DC Port: 5.5 x 2.5
Quantity of Antenna: 4
Working Voltage: 100V-240V
Language: Chinese
Firewall Settings: Support[/TD]
[/TR]
[TR]
[TH="align: center"]Dimensions and Weight[/TH]
[TD]Product weight: 1.030 kg
Package weight: 1.644 kg
Product size: 19.00 x 13.00 x 6.50 cm / 7.48 x 5.12 x 2.56 inches
Package size: 33.50 x 24.00 x 7.50 cm / 13.19 x 9.45 x 2.95 inches[/TD]
[/TR]
[TR]
[TH="align: center"]Packing List[/TH]
[TD]1 x Original Xiaomi Mi R3P Router
1 x Power Adapter
1 x Chinese Manual[/TD]
[/TR]
[/TABLE]
(Sent from Nexus 6P)
