Xiaomi Mi Smart Temperature and Humidity Sensor
airb
25 May 2008
16,280
Λιβαδειά
Main Features:
  • It can real-time detect the temperature and humidity condition
  • It will automatic alarm if the temperature and humidity is abnormal
  • You can easy control the temperature and humidity change by viewing the data according to historical records
  • €APP control: More convenient to use
  • €Temperature measuring accuracy is -0.3 - 0.3 degree
  • €Humidity measuring accuracy is -3 - 3 percent
[TABLE="class: grid, width: 500"]
[TR]
[TD]Working Temperature: -20 - 60 Degree
Working Humidity: 0 - 100[/TD]
[/TR]
[TR]
[TD]Product weight: 0.085 kg
Package weight: 0.430 kg
Product size (L x W x H): 9.00 x 9.00 x 3.00 cm / 3.54 x 3.54 x 1.18 inches
Package size (L x W x H): 12.00 x 12.00 x 6.00 cm / 4.72 x 4.72 x 2.36 inches[/TD]
[/TR]
[TR]
[TD]Package Contents: 1 x Xiaomi Temperature and Humidity Sensor[/TD]
[/TR]
[/TABLE]
Τιμή:
(Sent from Nexus 6)
