Xiaomi Mi TV 4A
auteur
Banned
12 March 2009
9,072
Τι γνώμη έχετε για τις Xiaomi Mi TV 4A
αξίζουν; οι τιμές ειναι ενδεικτικές, με κουπόνια βγαίνουν αρκετά φθηνότερα πχ η 43" βγαινει 340 +11 μεταφρορικά χωρίς κίνδυνο τελωνείου.
Original Xiaomi Mi TV 4
- BLACK49 inch Full HD Screen + 4K 3840 x 2160 Pixel + HDR + Amlogic T968 CPU
748.43
Xiaomi Mi TV 4 series of TVs have "Patch Wall", a UI layer on top of the Android OS that's based on deep learning AI technology. It can show content based on recommendations. These also have Dolby and DTS Audio. Introduced multi-purpose Mi Remote Control, which also has infrared in addition to Bluetooth to work with most appliances such as setup box. It has Mi Touch that replaces traditional navigation buttons so you can use gestures to control your TV.
Main Features:
● Has 3840 x 2160 pixels resolution with 178-degree viewing angles.
● Comes with LG panels.
● Include 1.8GHz quad-core Cortex-A53 Amlogic T968 processor with Mali-T830 MP2 GPU clocked at 750MHz.
● Comes with 2GB DDR4 dual-channel RAM and 8GB internal storage.
● Has 6W x 2 speakers and supports Dolby Virtual surround sound, Bass Boost and DTS.
● Connectivity features like WiFi 802.11 a / b / g / n, dual band ( 2.4 + 5GHz ), Bluetooth V4.2 LE, two HDMI 2.0 ports, one USB 3.0 and one Ethernet port.
● 49-inch display with 178-degree viewing angle, 6ms ( LG ) dynamic response, 1200 : 1 ( LG ) contrast ratio.
● Supports H.264 4K at 30 fps, H.265 4K at 60 fps.
Specification
[TABLE="width: 1374"]
[TR]
[TH="align: center"]General[/TH]
[TD]Brand: Xiaomi[/TD]
[/TR]
[TR]
[TH="align: center"]Product Details[/TH]
[TD]Display size: 49 inch
Display Resolution Maximum: 3840 x 2160[/TD]
[/TR]
[TR]
[TH="align: center"]Dimension and Weight[/TH]
[TD]Product weight: 13.8000 kg
Package weight: 20.0500 kg
Product size (L x W x H): 109.45 x 70.65 x 5.70 cm / 43.09 x 27.81 x 2.24 inches
Package size (L x W x H): 115.00 x 80.00 x 15.00 cm / 45.28 x 31.5 x 5.91 inches[/TD]
[/TR]
[TR]
[TH="align: center"]Package Contents[/TH]
[TD]Package Contents: 1 x Original Xiaomi Mi TV[/TD]
[/TR]
[/TABLE]
Original Xiaomi Mi TV 4A
- BLACK 43 inch Full HD Screen + Amlogic T962 CPU + Dual Band WiFi +1080P
432.19
Xiaomi Mi TV 4A series of TVs have "Patch Wall", a UI layer on top of the Android OS that's based on deep learning AI technology. It can show content based on recommendations. These also have Dolby and DTS Audio. Introduced multi-purpose Mi Remote Control, which also has infrared in addition to Bluetooth to work with most appliances such as setup box. It has Mi Touch that replaces traditional navigation buttons so you can use gestures to control your TV. The new Mi Bluetooth remote also has speech recognition that uses Sogou ASR speech recognition technology that promises 97 percent accuracy.
Main Features:
● Has 1920 x 1080 pixels resolution with 178-degree viewing angles.
● Comes with Samsung / LG / AUO panels.
● Include 1.5GHz quad-core Cortex-A53 Amlogic T962 processor with Mali-450 MP5 GPU clocked at 750MHz.
● The artificial intelligence voice edition will sport 32GB eMMC 5.1 storage.
● Connectivity features like WiFi 802.11 a / b / g / n / ac, dual band ( 2.4 + 5GHz ), Bluetooth V4.2 LE, Mi port, two HDMI 2.0 ports, two USB 2.0 and one Ethernet port.
● 43-inch ( 1920 x 1080 pixels ) Full HD display with 178-degree viewing angle, 6ms ( LG ) / 6.5ms ( AUO ) dynamic response, 1200 : 1 ( LG ) / 3000 : 1 ( AUO ) contrast ratio.
● Supports HDR 10 and HLG, H.265 4K at 60fps, H.264 4K at 30 fps, H.265 1080P at 60 fps, H.263 1080P at 30 fps.
Specification:
Screen: FHD
Resolution: 1920 x 1080
3D: not support
Backlight: LED
Viewing angle: 178 degree
Dynamic response: 6ms ( LG ) / 6.5ms ( AUO )
Contrast ratio: 1200 : 1 ( LG ) / 3000 : 1 ( AUO )
Refresh rate: 60Hz
CPU: Amlogic T962 ( Cortex A53 Quad-core 1.5GHz )
GPU: Mali-450 MP5 750MHz
HDR: HDR 10, HLG ( Hybrid Log-Gamma )
RAM: 2GB DDR4
ROM: 8GB eMMC 5.1
WiFi: 2.4 + 5GHz, 802.11 a / b /g / n / ac
Bluetooth: Bluetooth 4.2
HDMI: HDMI 2.0b x 2
Specification
[TR]
[/TR]
[TR]
[TD]Display size: 43 inch
Display Technology: LED-backlit
Display Resolution Maximum: 1920 x 1080
Interface: Ethernet,HDMI,USB 2.0
Horizontal View Angle: 178 Degree
Monitor Contrast Ratio: 3000:1
Refresh Rate: 60Hz[/TD]
[/TR]
[TR]
[TD]Product weight: 8.0000 kg
Package weight: 17.5000 kg
Product size (L x W x H): 96.59 x 57.03 x 7.42 cm / 38.03 x 22.45 x 2.92 inches
Package size (L x W x H): 113.50 x 71.50 x 21.00 cm / 44.68 x 28.15 x 8.27 inches[/TD]
[/TR]
[TR]
[TD]Package Contents: 1 x Original Xiaomi Mi TV, 1 x Remote Controller, 1 x Adapter[/TD]
[/TR]
[/TABLE]
Tips: the default language is Chinese. It can be changed to English after downloading the APP attached.
Xiaomi Mi TV 4A - BLACK
32 inch HD Screen + Amlogic 962-SX CPU
214.30
Main Features:
● Has 1366 x 768 pixels resolution with 178-degree viewing angles.
● Include 1.5GHz Quad-core Cortex-A53 Amlogic 962-SX processor with Mali-450 MP3 GPU clocked at 750MHz.
● Comes with 1GB RAM and 4GB internal storage.
● Has 5W x 2 speakers and supports Dolby Virtual surround sound, Bass Boost and DTS.
● Support display Chinese
Tips: The default language is Chinese. It can be changed to other languages after downloading the APP attached.
Specification
General
Brand: Xiaomi
Product Details
Display size: 32 inch
Display Resolution Maximum: 1366 x 768
Product weight: 4.0000 kg
Package weight: 5.5000 kg
Product size (L x W x H): 73.30 x 47.80 x 18.00 cm / 28.86 x 18.82 x 7.09 inches
Package size (L x W x H): 80.00 x 55.00 x 25.00 cm / 31.5 x 21.65 x 9.84 inches
Package Contents
Package Contents: 1 x Original Xiaomi Mi TV 4A
