YAMAHA RX-V2500
sakisxas
7 September 2006
5,384
C:\Greece\Komotini
ΠΩΛΕΙΤΑΙ Ο ΡΑΔΙΟΕΝΙΣΧΥΤΗΣ RX-V2500 ΤΗΣ YAMAHA ΣΕ ΥΠΕΡΑΡΙΣΤΗ ΕΜΦΑΝΙΑΣΙΑΚΗ ΚΑΙ ΛΕΙΤΟΥΡΓΙΚΗ ΚΑΤΑΣΤΑΣΗ,ΦΥΣΙΚΑ ΣΤΟ ΚΟΥΤΙ ΤΟΥ ΚΑΙ ΟΛΑ ΤΟΥ ΤΑ ΠΑΡΕΛΚΟΜΕΝΑ ΣΕ ΧΡΩΜΑ ΤΙΤΑΝ.ΔΕΙΤΕ ΠΑΡΑΚΑΤΩ ΤΕΧΝΙΚΑ ΧΑΡΑΚΤΗΡΙΣΤΙΚΑ ΤΟY:Yamaha RX-V2500 7.1 Channels Receiver: Product Features
Read 4 reviews | Write a review at Epinions.com
High sound quality, superior performance and surround realism are the result of the advanced technology that is part of the RX-V2500 digital home theater receiver. Features for convenient operation include extensive menus, front panel video Aux optical input terminal and a direct access remote control. This top-class receiver also provides a variety of features for setting up a multi-room custom installation.
Product Details
Key Features
Type
Receiver
Number of Channels
7.1 Channels
Surround Mode Power 7x130 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.04%
Surround Sound
Dolby Digital® • DTS® • DTS ES® • THX EX® • Dolby Pro Logic II • DTS Neo:6 • Dolby Pro Logic • DTS 96/24
THX Certification Select
Inputs / Outputs
Rear Input Connectors
RCA (2 Audio Channels) x 9 • Digital Coaxial x 3 • Digital Optical x 4 • Composite (Video) x 5 • S-Video x 5 • Component x 3
Rear Output Connectors
RCA (2 Audio Channels) x 6 • Digital Optical x 2 • Composite (Video) x 4 • S-Video x 4 • Component x 1
Front A/V Connections Composite x 1 • Couple RCA Jack x 1 • Headphones x 1 • Optical x 1 • S-Video x 1
PC Interface
RS-232
Surround Analog Inputs 5.1 Channels x 1
Preamp Outputs 7.1 Channels
Convenience
Number of Zones 3
Speaker Impedance
4 Ohm • 6 Ohm • 8 Ohm
Speaker Selection
A+B or A/B
Tuner Presets 40 Channels
Tone Controls Bass & Treble
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Illuminated Remote Illuminated
Design Keypad
Dimensions
Width 17.13 in.
Depth 17.06 in.
Height 6.75 in.
Weight 34.2 lb.
Miscellaneous
Included Accessories AAA Batteries x 4 • AM Loop Antenna • FM Wire Antenna • Power Cord • Remote Control
Power Consumption 500 Watt
MPN RX-V2500
ΤΙΜΗ 550 ΕΥΡΩ.
ΝΑΙ ΕΙΝΑΙ ΤΟ ΙΔΙΟ ΧΡΩΜΑ ΚΑΙ ΣΤΙΣ 3 ΦΩΤΟ.ΕΙΝΑΙ ΤΟ ΤΙΤΑΝ.ΑΠΛΑ ΛΟΓΩ ΦΩΤΙΣΜΟΥ ΦΑΙΝΕΤΑΙ ΕΤΣΙ
Ναι,ειναι ακομα διαθεσιμος.Απλώς επειδη λειπω σε διακοπες,μπηκα απο Νετκαφε και ειδα την ερώτησή σου.Επιστρέφω τη Δευτερα και πιστευω να τα πούμε τότε πιο αναλυτικα.Ευχαριστώ παντως
τοτε καλυτερα να στελνεις την εικονα σου κατευθειαν στο μεσο προβολης.
Οποιαδηποτε "σταση" του σηματος δεν θαχει ευεργετικες συνεπειες.
Εγώ αυτό που ξέρω είναι ότι τον ψώνισα τον ενισχυτή!
Άντε να έρθει να παίξω μαζί του!
