Yamaha RX-V640 RDS
CENTRAL
30 June 2006
1,819
ATHENS
The Yamaha RX-V640 RDS delivers an impressive array of advanced options - especially considering this receiver's low price. A beefy 6 x 85 watt amplifier is coupled to an advanced decoder which delivers the latest digital home cinema formats, all sourced from a plentiful array of connections including component, S and composite video. Additionally, all composite video signals are upsampled to S-Video for easy screen connectivity and switching whilst the amp also offers an additional video and audio input (including optical digital) at the front.
YAMAHA RX-V640RDS AV RECEIVER SPECIFICATIONS
Power output:
85 watts x 6 (8 ohms RMS)
Decoders: Dolby Digital, Dolby Digital EX, DTS, Dolby Pro Logic II, DTS ES Discrete 6.1, DTS Neo:6, DTS-ES Matrix 6.1
DSP modes:
32 bit DSP Processing, 24 surround programmes (44 variations) including Silent Cinema and Night Listening mode, 5 band centre channel graphic equaliser
Video inputs & outputs:
2 x video inputs (with component, composite, S-Video and audio in)
2 x video loops (with composite, S-Video & stereo audio in and out)
1 x front video in (with S-Video, composite video and stereo audio)
Component video out HDTV (720p/1080i) compatible
Composite video monitor output, S-Video monitor out
AV record out selector, video format conversion built-in
Audio inputs: 3 x optical and 1 x coaxial digital inputs, CD, tape loop, 6 channel input, 6.1 channel pre-outputs, front-mounted optical input
Speaker outputs:
Two pairs of independently switchable stereo speaker outputs, rear stereo, rear centre, front centre - all binding posts which can be simply modified to accept 4mm banana plugs
Audio outputs:
Subwoofer pre output, 6.3mm (1/4") headphone socket on the front, optical digital output
Tuner: FM/AM reception, 40 presets, auto/manual tuning. RDS reception including PS, PTY, RT, ST, EON
Remote control: Yes, with preset options for other AV components
On screen display?
No
Dimensions WxHxD / Weight: 435 x 171 x 390mm / 13 kg
Supplied accessories: Remote control, batteries, FM and AM antennas
Colour: Black or silver
Extra: 96kHz/24 bit D>A Conversion, wideband frequency response - up to 100kHz - for SACD or DVD Audio compatibility.
Λόγω αναβάθμισης πωλείται σε άριστη κατάσταση ο Yamaha RX-V640.
Τιμή: 230
Αφορά αγγελία φίλου εκτός forum
Επικοινωνία: 6944479911 - ΓΙΩΡΓΟΣ
