- 30 April 2021
- 308
| Model | Neo X |
| Shell Material | Aviation aluminum alloy |
| Front Display | 5-inch OLED HD touch screen |
| OS | Android 9.0 |
| CPU | Realtek RTD1619 ARM Cortex-A55 Hexa-core |
| GPU | ARM Mali-G51 MP3 |
| RAM | 2GB DDR4 |
| Internal Storage | 16GB eMMC |
| DAC | ESS 9038Pro |
| Bluetooth | BT 4.2 |
| Wi-Fi | 2.4G+5G dual-band WiFi, 802.11 a/b/g/n/AC 2R2T MIMO 867Mbps |
| Ethernet | 1 * RJ-45 Ethernet Jack (10/100/1000Mbps) |
| HDMI Output | 2.0a (4K@60fps/12Bit/HDR/BT2020/YCbCr 4:4:4 output) support audio passthrough |
| Video Decoding | 4K@60p HEVC/H.265 12 Bit HDR10, HDR10+, Dolby vision |
| Audio Decoding | Support true-hd HD audio passthrough, stereo PCM decoding; Built-in DAC audio decoding: support up to stereo DSD512 24Bit, PCM 768KHz 32Bit, MQA |
| Bluetooth Audio Input | CSR8675 flagship Bluetooth audio module supports mainstream lossless audio protocols such as SBC/AAC |
| USB Audio Input | USB audio compatible system: Windows(7,10), Mac, Android Support up to stereo DSD512 24Bit, PCM 768KHz 32Bit, MQA |
| Digital Audio Input | 1 * USB DAC IN 1 * AES/EBU input 1 * Coaxial input |
| Digital Audio Output | 1 * Optical output 1 * Coaxial output |
| Analog Audio Output | Preamplifier output: 1 * XLR (balanced) 1 * RCA Headphone amplifier output: 1 * 4.4mm balanced 1 * 6.35mm single end |
| Headphone Impedance | 16-300Ω (low-gain mode: 16-32Ω/ high-gain mode: 32-300Ω) |
| USB Ports | 1 * USB 3.0 2 * USB 2.0 |
| SATA | 1 * SATA 3.0 3.5″ HDD Bay (HDD is not included) |
| Control Ports | 1 * IR IN 1 * RS-232 TRIGGER (12V) IN/OUT TCP/IP control (WOL) |
| Power Supply | AC 110-240V 50/60Hz (dual linear power supply) |
| Dimension (L x W x H) | 395 x 291 x 110 mm |
| Packing List | 1 * Remote control 1 * Power cable 3 * Antennas 1 * Product manual |
