Πωλείται η κεφαλή ZYX100RH II (η χαμηλοέξοδη έκδοση 0.24 mv) σε κατάσταση σφραγισμένη(sealed)
τιμή 750 euros
Μιλάτε απ' ευθείας με τον ιδιοκτήτη Ανδρέα Πολλάκη στο 2292027651 η στείλτε πμ σ' εμένα... ευχαριστώ...
ZYX R-100 Yatra MKII Features
“Real Stereo” generator system
Pure damper material, long-life rubber with no powder filler
Air-response damper mechanism
6-nines pure copper wiring in coils
Eddy current-free cartridge body
Solid boron cantilever
Micro-ridge stylus, long lifespan and wide frequency range
ZYX R-100 Yatra MKII Technical Data
Type: moving-coil (dynamic), "Real Stereo" generator system
Output voltage at 3.54cm/sec., 1kHz: 0.24mV
Frequency response 10Hz-80kHz
Channel separation: > 30dB (1kHz)
Channel balance: < 0.5dB (1kHz)
Recommended tracking force: 2g
Tracking force range 1.7-2.5g
Horizontal compliance: 15x10-6cm/dyne (vertical: 12x10-6cm/dyne)
Trackability: > 80um/2g
Internal impedance: 4 ohms
Recommended load impedance: > 100 ohms
Cantilever: boron, 0.3mm dia.
Stylus: micro-ridge, .07mm sq
Output terminals: 1.25mm dia., gold-plated
Weight: 5g
τιμή 750 euros
Weight: 5g
