8Κ Super Hi-Vision
tmjuju
Administration Team
21 January 2007
21,651
Re: 8Κ
LG To Show Off New 55-Inch 8K Display at CES
One of the most in-your-face buzzwords of the past year has been "4K," and there's little doubt that the forthcoming CES show in early January will bring it back in full force. As it stands today, 4K really isn't that rare, or expensive. You can even get 4K PC monitors for an attractive price. There does remain one issue, however; a lack of 4K content. We're beginning to see things improve, but it's still slow going. Given that, you might imagine that display vendors would hold off on trying to push that resolution envelope further – but you just can't stop hardware vendors from pushing the envelope. Earlier this year, both Apple and Dell unveiled "5K" displays that nearly doubled the number of pixels of 4K displays. 4K already brutalizes top-end graphics cards and lacks widely available video content, and yet here we are looking at the prospect of 5K. Many jaws dropped when 4K was first announced, and likewise with 5K. Now? Well, yes, 8K is on its way. We have LG to thank for that. At CES, the company will be showing-off a 55-inch display that boasts a staggering 33 million pixels — derived from a resolution of 7680x4320. It might not be immediately clear, but that's far more pixels than 4K, which suggests this whole "K" system of measuring resolutions is a little odd. On paper, you might imagine that 8K has twice the pixels of 4K, but instead, it's 4x.
http://hardware.slashdot.org/story/14/12/12/0248221/lg-to-show-off-new-55-inch-8k-display-at-ces
xavito
29 October 2008
8,983
Re: 8Κ
[latticesemi.com]...Silicon Image Introduces World's First superMHL/HDMI 2.0 Port Processor-the SiI9779- for Next Generation Home Theater Devices...http://www.latticesemi.com/en/About/Newsroom/PressReleases/2015/201503WorldsFirstSuperMHLHDMI20PortProcessor.aspx
The SiI9779 port processor supports:
One superMHL input and three HDMI 2.0 inputs for display applications
One superMHL output for source applications such as STBs
8K 60fps video resolution as outlined in the superMHL specification
New, reversible 32-pin superMHL connector
USB Type-C with MHL Alt Mode
High Dynamic Range (HDR), Deep Color, BT.2020
Object audio – Dolby Atmos, DTS:X, 3D audio, audio-only mode
High bit-rate audio extraction
HDCP 2.2 premium content protection
[av.watch.impress.co.jp]...The transmission of 8K with a single cable. "SuperMHL" corresponding chip development...http://av.watch.impress.co.jp/docs/news/20150317_693090.html
μετάφραση google jp to en
algedan
9 October 2008
1,595
Re: 8Κ
μετάδοση 8Κ στο κοινό (Ιαπωνία), να δούμε αν το 4Κ είναι για το 8Κ ότι το 1280Χ720 με το 1920Χ1080 και αν θα περάσει γρήγορα!
Αν δείτε όμως στην 2η παράγραφο το ρυθμό μετάδοσης δεν το βλέπω για μέσω ιντερνετ, τουλάχιστον στην Ελλάδα :flipout:
http://www.digitaltvinfo.gr/news/news-hdtv/item/14752-epideiksi-metadoseon-8k-sto-koino-apo-tin-nhk
algedan
9 October 2008
1,595
Re: 8Κ
το ξεφτίλισαν! 10Κ οθόνη
http://www.digitaltvinfo.gr/news/news-hdtv/item/14866-tora-kai-othones-10k
βέβαια δεν ξέρω πότε θα υπάρξει, αν υπάρξει, υλικό για 10Κ αλλά μόνο και μόνο όταν διαβάζεις τέτοια πράγματα λές το 4Κ ξεπερασμένο. Προσωπικά έχω εδώ και 10 μήνες fullHD τηλεόραση και μάλλον όταν τα τινάξει (ελπίζω να αργήσει φτου φτου στον κόρφο :flipout: ) να πάω κατευθείαν σε 8Κ. Λέω ξεπερασμένο γιατί ήδη προγραμματίζεται υλικό 8Κ και μυρίζομαι κατάσταση όπως τότε με τα 720HD και 1080FHD.
sotos65
25 August 2007
10,620
Χανιά
Απάντηση: 8Κ
Θέλει τουλάχιστον VDSL 50Mbps, παίζει σε chrome χωρίς ιδιαίτερο πρόβλημα (κάποια μικρο glitch σε ορισμένα σημεία) αλλά ξεπερνά κάποιες φορές τα 40τόσα Mbps.
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
Απάντηση: 8Κ
Samsung, TCL, Hisense & Panasonic form 8K Association
...TV makers Hisense, Panasonic, Samsung, and TCL have formed the 8K Association, or 8KA, together with panel manufacturer AUO. Samsung Display is in the process of joining...
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1547158672
paksat
20 September 2011
1,224
Σάμος
Re: 8Κ
H 8K Association (επαγγελματική ένωση εταιρειών για την προώθηση του 8Κ) ανακοίνωσε τεχνικές προδιαγραφές για τις αντίστοιχες τηλεοπτικές συσκευές 8Κ, όπως:
Resolution: 7680 x 4320 pixels
Input Frame Rate: 24p, 30p and 60p frames per second
Display Luminance: More than 600 nits peak Luminance
Codec: HEVC
Interface: HDMI 2.1
Additional performance and interface specifications (available to members)
Περισσότερα στο:
https://8kassociation.com/8k-association-announces-performance-specification-for-consumer-tvs/
papasouzakias
13 May 2009
4,523
Re: 8Κ
Οι τηλεοράσεις 8K της Samsung δεν είναι αληθινές 8Κ
Οι τηλεοράσεις της Samsung χρησιμοποιούν τη τεχνική sub-pixel rendering για τη βελτίωση των γωνιών θέασης και τη μείωση των αντανακλάσεων.
Η τεχνική όμως αυτή έχει ως μειονέκτημα μειωμένη πραγματική ανάλυση που επηρεάζει τη λεπτομέρεια στην εικόνα.
Το αποτέλεσμα φαίνεται στις παρακάτω φωτογραφίες από την Samsung Q900R 8K LCD.
Notice how shadows and areas around the hairline pixellate. Here, the effective resolution is lower than 8K.
In the other example, you can see how it works. Pixels are controlled in clusters of four. With this shade of green, only one pixel is lit, while the three other pixels are either dimmed down or turned off. In the worst case scenario, you get 4K resolution but this will require special test patterns. With real content, you are more likely to see effective resolution somewhere between 4K and 8K.
Τα ίδια ισxύουν και για τις 4K τηλεοράσεις που χρησιμοποιούν την ίδια τεχνική sub-pixel rendering όπως η Samsung Q90 R.
As you may have guessed, sub-pixel rending does have drawbacks, with the main one being lower effective resolution when the wide viewing angle system is active. When examining the pixel structure more closely, we found that the LCD panel has a gate pattern that negatively affects picture details.
The photo to the right illustrates the same picture section from Samsung Q90R and Sony A9F, revealing that you some of the finer details (i.e. the pupil) in the picture are lost, and that color gradients or contrast transitions (around the hair) appear with dithering artefacts.
Στις 8Κ το φαινόμενο της μειωμένης πραγματικής ανάλυσης είναι πιο έντονο και πιο εμφανές για τον θεατή γιατί οι τηλεοράσεις έχουν μεγαλύτερα μεγέθη και ο θεατής καθεται πιο κοντά στην τηλεόραση
Για το λόγο αυτό η International Committee for Display Metrology (ICDM) έχει ανακοινώσει τα διεθνή πρότυπα για τη πιστοποίηση μια τηλεόρασης ως πραγματικής 8Κ.
"For a “real 8K” experience, pixels must be easily distinguishable from one another. According to the ICDM, Contrast Modulation (CM), which measures precisely if neighbouring pixels are distinguishable from one another- is the relevant way to measure and describe display resolution.
For any TV display to deliver the resolution indicated by its pixel count, the ICDM requires the minimum CM value to exceed a threshold of 25% for images and 50% for text. An 8K TV with a CM value that is lower than these required thresholds does not deliver real 8K, even though the TV may in fact have the sufficient number (7,680 x 4,320) of pixels"
Using as few as one-in-four pixels for 25% brightness will result in having lower CM values. Turning off pixels versus dimming them is a much lower-cost way to lower brightness at the expense of detail, HDR and colour. The customer is not getting a true 8K image nor brightness.
Samsung's Q900R is using one-in-four pixels producing a fly-screen effect. When you know what to look for the flyscreen effect – pixelation – becomes obvious as a much softer focus in dimmer areas and a loss of HDR detail.
Οne in four pixels turned off – notice fly screen effect in Samsung Q900R 8K
All pixels on using active dimming to 25% in LG 8K Nano panel
The left picture illustrates the quality if pixels are dimmed. The right illustrates the ‘holes’ if they are turned off leading to lower resolution
Για το λόγο αυτό η TCL ανακοίνωσε πως οι TCL 75X10 QLED 8K τηλεοράσεις της είναι πραγματικές 8Κ αφού έχουν πιστοποίηση από Κινεζικό Οργανισμό πιστοποίησης ενώ η LG ανακοίνωσε πως οι δικές της 8Κ τηλεοράσεις ξεπερνάνε το όριο του 25% που έχει θέσει η ICDM αφού φτάνουν το 90%.
www.flatpanelshd.com/review.php?subaction=showfull&id=1557215154
www.flatpanelshd.com/news.php?subaction=showfull&id=1567494878
www.gadgetguy.com.au/lg-warns-of-real-8k-versus-fake-8k-tvs-how-to-tell
35,671
Απάντηση: 8Κ
Το όλο θέμα με τα πιξελάκια είναι για τεράστια γέλια. Οι δε προϋποθέσεις που θέτουν οι ανεξάρτητοι (μη θέσω...) οργανισμοί για τις πιστοποιήσεις είναι για να γελάνε και οι αρκούδες. Τις ίδιες αηδίες έκαναν και με το 2020.
papasouzakias
13 May 2009
4,523
Re: 8Κ
Samsung, LG spar over picture quality of 8K TVs
LG once again accused Samsung of exaggerated, misleading marketing of its 2019 QLED 8K TVs and demanded more details
LG currently suspects that Samsung’s new application of viewing angle compensation film to 2019 models must have compromised their CM levels.
Samsung’s 8K TVs made in 2018 had sufficed the CM levels at a stellar record of 90 percent.
“We assume there must have been a trade-off (of better viewing angle for lesser CM), but that should not lower the TV’s resolution below what it purports to be,” Nam said
LG explains Samsung QLED 8K TVs' sudden fall in CM levels from 90% in 2018 to 15% in 2019 (Lim Jeong-yeo/The Korea Herald)
restmb_idxmake.php
Intertek and VDE report
CM, or contrast modulation, is the level of distinction between the luminance of white and the luminance of black on a screen.
The higher the CM the clearer the distinction between white and black, therefore producing sharper images.
ICDM set the threshold for CM levels for text-displaying screens at 50 percent and image-displaying screens at 25 percent.
In 2012, the ICDM said that contrast modulation is “the best way to describe display resolution” and made it mandatory for companies to report it.
Varying degrees of contrast modulation (ICDM)
LG Electronics compares Samsung QLED 8K TV and LG NanoCell 8K TV's CM levels. Samsung 75Q950 on the left, LG 75SM99 on the right
restmb_idxmake.php
Samsung on the left, LG on the right
This year, Samsung QLED 8K TV and LG OLED 4K TV were compared side by side to compare the picture quality.
In particular, in Samsung TVs “The stars are hard to see because of the limitations of the backlight
QLED TV is an LCD TV with a film added
At the 'Display Technology Briefing' held at LG Twin Tower in Yeouido, Seoul on the 17th, Ho-Jun Nam, head of HE Research Institute of LG Electronics, explains the difference between OLED TV and quantum dot film applied to QLED TVs
LG Electronics also exhibited parts of a disassembled Samsung TV. To emphasize that QLED TVs are not self-luminous TVs, but LCD TVs with quantum dot (QD) film
LG electronics disassembled Samsung's QLED TV and used a backlit LCD panel (left) and added QD film to highlight that it is not a true QLED (self-luminous) panel through an exhibition (right).
More information in the following links:
https://translate.google.com/transl...oul.co.kr/news/newsView.php?id=20190917500092
http://www.koreaherald.com/amp/view.php?ud=20190917000767
http://www.koreaherald.com/view.php?ud=20190919000841
http://www.koreaherald.com/view.php?ud=20190908000079
https://www.valuewalk.com/2019/09/samsung-lg-clash-8k-tvs/
