AZBox Elite/Premium, part II
Νίκος Σχ.
12 July 2006
4,221
πρώτο bug από το 3281 , βλέπεις μία ταινία στον player και δεν σε αφήνει να δεις άλλη εκτός άμα κάνεις reset ( συνεχόμενα το κουμπί που κλείνει )
nakata
11 June 2007
2,231
var/etc/home
εχει αναφερθει στην azbox
οταν βαλεις υποτιτλους κολαει και δεν βλεπει τα mkv αρχεια πλεον αλλα μονο τα .srt εκτος και κανεις reboot
rocker70
8 April 2009
331
Καποιος απο την εκλεκτη παρεα μπορει να κανει μια μεταφραση στο κειμενο αυτο απο το νουμερο 3 και κατω ...γιατι δεν βγαζω ακρη?
Tutorial : CCcam 2.1.1 for AzBox HD
1. Download and extract on Your PC archive Cccam 2.1.1 AzBox HD.rar
http://www.mediafire.com/?mn2jv24zmtz
2. Connect on Your AzBox HD by FTP manager ( You can get one free File Zilla on :
https://www.ohloh.net/projects/filezilla/download?filename=FileZilla_3.2.6.1_win32-setup.exe ).
3. Enter the /EMU directory and transfer there directory lib which is located in extracted archive on Your PC. When transfer is finished select all files and give CHMOD 755 to them.
4. Now, enter the OpenXCAS folder on AzBox HD receiver, so You will have /EMU/OpenXCAS , and transfer there two files : module.seq and openxcas.conf which are located in OpenXCAS folder of extracted archive. Give CHMOD 755 to that two files.
5. Now transfer in /EMU/OpenXCAS folder named as dvbapiCAS which is located in OpenXCAs directory of extracted archive. Enter in that directory, so You will have /EMU/OpenXCAS/dvbapiCAS and give CHMOD 755 to 3 files : dvbapi.sh , dvbapi_module and openxcas.conf .
6. Do not forget to add Your C or N lines to CCcam.cfg file which is located inside of /EMU/lib directory.
7. After You start dvbapiCAS from Plug-ins -> OpenXCAS -> Camd activation & priority , You can test if CCcam is running by entering this in Your Web browser : http://azboxhdip:16001 , in my Case, my AzBox HD in my LAN has IP adress 192.168.1.65, so I am entering http://192.168.1.65:16001 .
That is all for now, with this You have CCcam 2.1.1 Client and Server Installed on Your AzBox HD device
http://www.AzBoxWorld.com
rocker70
8 April 2009
331
Εστω αν δεν υπαρχει μεταφραση λογω χρονου που καταλαβαινω οτι ειναι πολιτιμος για ολους μας?!?! Υπαρχει κατι αντιστοιχο στα ελληνικα για καποιους απο εμας που δεν ειναι λατρεις της αγγλικης γλωσσας?
Ευχαριστω!!!
AlexT_
10,452
Απάντηση: Re: AZBox Elite/Premium, part II
Κατεβάζεις και αποσυμπιέζεις το αρχείο.
Συνδέεσαι με FTP με τον δέκτη (προαιρετικά με το προτεινόμενο Filezila)
Μετέφερε τον φάκελο lib στο directory /EMU και δώσε δικαιώματα 755 σε όλα τα περιεχόμενα αρχεία (του lib)
Μετέφερε στη διαδρομή EMU/OpenXCAS τα δύο αρχεία module.seq and openxcas.conf και δώσε τους δικαιώματα 755
Μετέφερε τον φάκελο dvbapiCAS στο /EMU/OpenXCAS και δώσε δικαιώματα 755 στα τρία περιεχόμενα αρχεία. (dvbapi.sh , dvbapi_module and openxcas.conf)
Σέταρε το cccam.cfg
7. After You start dvbapiCAS from Plug-ins -> OpenXCAS -> Camd activation & priority.
Ενεργοποίησε το dvbapiCAS μέσα από τα plugins
(Plug-ins -> OpenXCAS -> Camd activation & priority)
H λειτουργία του cccam ελέγχεται μέσω browser εισάγοντας: ip του azbox:16001
rocker70
8 April 2009
331
Ευχαριστω Alex για τον χρονο που δαπανησες!!!Και κατι τελευταιο ???οταν λεει "και δώσε δικαιώματα 755 "Πως το επυτυχανω αυτο?
Ευχαριστω και παλι!!!
leo06
14 October 2007
6,732
Πάτρα
δεξι κλικ- δηκαιωματα αρχειου
AlexT_
10,452
Και κατι τελευταιο "Σέταρε το cccam.cfg"ΠΟΥ ΘΑ ΠΕΙ?"
Εγώ θα σε ρωτήσω κάτι άλλο. Τι ακριβώς θέλεις να κάνεις και παιδεύεσαι να στήσεις το cccam? Πως ακριβώς θα το χρησιμοποιήσεις?
teomad
Banned
5 July 2008
1,980
Πως τα βαζεις τα εκανα copy αλλα τιποτα? -bye-
το βρικα στο δικτιο μου αραισε και ειπα να το ανεβασω
σιγουρα καποια παιδια που εχουν τον δεκτη κατι θα μας πουν :eek:perator:
george664
11 May 2007
1,449
ΡΕΘΥΜΝΟ
Παρακαλω ηθελα να μαθω ποιο cccam εχει ο δεκτης το κατβασα απο το σερβερ του alsat forum Διοτι θελω να εχει ο 2.1.1Διαφορετικα πως θα το εγκαταστισω?
nakata
11 June 2007
2,231
var/etc/home
εχουμε και λεμε
κατεβασε αυτο το αρχειο
http://rapidshare.com/files/282217155/skin.rar καντο unrar και μετα με ενα ftp προγραμμα ριξτο στο tmp συνδεσου με τον δεκτη μεσω telnet και δωσε την εντολη chmod 755 /tmp/skin/install πατα enter και δωσε την εντολη /tmp/skin/install ξαναπατα enter μετα πηγαινε στις ρυθμίσεις / System Information/font setup και επελεξε το sony.ttf πατα οκ και θα παρεις το μυνημα οτι η νεα γραμματοσειρα θα ενεργοποιηθει μετα απο την επανεκινηση του δεκτη, ξαναξεκινα τον δεκτη και εισαι ετοιμος σε περιπτωση που δεν σου αρεσει η γραμματοσειρα μπορεις να την αλλαξεις με μια απο τις http://rapidshare.com/files/282833564/jamanta_fonts.zip η με οποιαδηποτε γραμματοσειρα προτιμας
rocker70
8 April 2009
331
Να δωσουμε εντολλη σε ποια αρχεια ομως?Λεγοντας να δωσουμε εντολη ενοεις δηλαδη δικαωματα .Αν καταλαβα καλα να δωσουμε δικαιωματα στο αρχειο install?
Ευχαριστω!!!
nakata
11 June 2007
2,231
var/etc/home
Ευχαριστω!!!
Στα windows xp πας στην /Εναρξη/εκτελεση και γραφεις telnet αφηνεις κενο και γραφεις την ip του δεκτη σου και πατας εντερ ανοιγει ενα παραθυρο οπου σου ζηταει user και pass τα δινεις και αφου συνδεθει με τον δεκτη σου κανε copy-paste τις εντολες με την σειρα που τις γραφω και πατα εντερ καθε φορα
