- 28 November 2011
- 3,129
Δυναμική εμφάνιση και απο την Dell στο Λας Βεγκας με 2 φρέσκες προτάσεις στο χωρο των 2 σε 1.
Πρωτο μοντελο το Dell Latitude 11 5000 series στις 10.8 ίντσες με πλούσιο εξοπλισμο και χαρακτηριστικά.
Συγκεκριμενα.
http://liliputing.com/2016/01/dell-...5000-series-2-in-1-with-core-m-and-usb-c.html
The tablet is powered by an Intel Core M Skylake processor and features a 1920 x 1080 pixel touchscreen display as well as an active digitizer which allows you to use an optional pen.
Dell will offer at least two different keyboard options, both of which feature backlit keys.
The Dell Latitude 11 5000 Series 2-in-1 will be avialable with up to an Intel Core M5-6Y57 processor, up to 8GB of RAM, and up to 512GB of solid state storage, but an entry-level model will likely ship with a Core M3 chip, 4GB of RAM, and 128GB of storage.
Other features include 802.11ac WiFI, Bluetooth 4.1, an 8MP rear camera, a 5MP front camera, stereo speakers, and a 35 Whr field replaceable battery.
The tablet has a full-sized USB 3.0 port and a USB 3.0 type C port which you can use to connect a wide range of peripherals using an optional Dell Dock (or a different docking solution or adapter cable). There’s also a microSDXC card reader, a micro HDMI port, and a micro SIM card slot if you opt for a model with cellular capabilities.
Το δευτερο μοντελο ειναι στις 12.5 ίντσες και αυτο με πλούσιο εξοπλισμο.
http://liliputing.com/2016/01/dells...et-thunderbolt-3-and-optional-4k-display.html
Like the cheaper Latitude 12 5000 Series 2-in-1, the new Dell Latitude 12 700 Series 2-in-1 is a 12.5 inch tablet that features an Intel Core M Skylake processor and which supports at least two different keyboard docks.
But this is a premium model with a few features lacking from the 5000 Series, including support for up to a Core M7 processor, two Thunderbolt 3 (USB 3.1 Type C) ports, and an optional 4K pixel display.
The Dell Latitude 12 5000 Series launches today for $849 and up.
Entry-level specs for this model include a 1920 x 1080 pixel display, 128GB of storage, a Core m3-6Y30 processor, and 4GB of DDR3 1600 MHz RAM.
But you can also opt for:
Up to a Core m7-6Y75 processor
Up to 8GB of RAM
Up to a 3840 x 2160 pixel display
Up to 512GB of solid state storage
The tablet features 802.11ac WiFi, Bluetooth 4.1, a 30 Whr battery, and a microSDXC card reader. Dell will also offer models with optional mobile broadband features and there’s an optional active pen for writing or drawing.
Συγκεκριμενα.
Up to 8GB of RAM
