[Επίσημο] MacBook Pro M1 14"/16" @2021
takisot
Μέλος Δ.Σ.
27,851
Παλλήνη
Όπως αναμενόταν, όταν γίνει σωστά port ενας gaming τιτλος ωστε να εκμεταλλευτεί όπως πρέπει το νέο hardware των Μ1+ και το νεο MetalFX, τα αποτελέσματα ειναι εντυπωσιακά:
Now, Resident Evil Village has made me a believer. Gaming on Macs can be just as good as on the best gaming PCs or best gaming laptops, provided developers actually optimize their titles for Apple’s computers. [...]
Without MetalFX enabled, I saw frame rates hover in the low 100s while I walked around the main protagonist’s home (Ethan Winters) during the intro. Later, when the game shifted to a dark, snow-covered mountain, frame rates fluctuated more dramatically — dipping into the low 70s at worst. Still, those are very impressive numbers with MetalFX off.
Saying I was shocked when I enabled MetalFX is an understatement. In Ethan’s home, frame rates instantly jumped into the low 200s. They dropped to the 150s when I began walking around, but those are still very high frame rates. Frames dipped into the upper 80s when traversing the mountain, but I’m not complaining.
I should note that performance didn’t take a hit when I unplugged the Magsafe cable from the MacBook Pro. Typically, frame rates drop substantially on gaming laptops when you unplug, but that wasn’t the case here. And though I didn’t play for extended periods of time, I never once heard the MacBook Pro’s fans kick in, nor did the laptop ever get warm. Considering how some gaming notebooks start to sound like jet engines seconds after booting up a game, this is a huge win.
The most startling thing about playing Resident Evil Village on a MacBook Pro wasn’t actually performance. It was HDR. The MacBook Pro (16-inch) has one of Apple’s “XDR” displays, a mini-LED panel that’s better than any other gaming laptop display. That’s because mini-LEDs that can get this bright are still fairly uncommon in the world of gaming laptops. And in many ways, there’s no better game to play in HDR than Resident Evil Village.
Δεν είμαι gamer, αλλα ψηνομαι να το δοκιμασω, ετσι απο περιέργεια.
dimitris777
10 July 2008
1,007
Θεσσαλία
Το παρατήρησα και εγώ γιατί αυτό το "καπέλο" στην Ελλάδα...
Περισσότερος ΦΠΑ και λοιποί φόροι+κέρδος εταιρίας.
Ίσως κατέβουν λίγο ακόμη κατα την έλευση των Μ2, αν φυσικά θα υπάρχει απόθεμα.
Πολλοί λένε πως είναι το καλύτερο laptop που έχει βγάλει η apple ever!
Reactions: Kirikosgeorgas
ilias
9,145
Bratislava
Πολυ φοβαμαι πως εφαγα παπα... και εχασα 1500 ευρω, αλλα το καταστημα γενικα ειναι αξιοπιστο... Πηρα το base model 14/16gb/512 στα 1500 με φπα (οταν σε ολα τα αλλα καταστηματα παιζει στα 1850 ευρω).
Δεν ειδα πουθενα να γραφει οτι ειναι refurbished, return η εκθεσιακο.
Γενικα οι τιμες που εβγαλε αυτο το μαγαζι η ειναι λαθος, η ειναι κλεμενα η δεν ξερω τι να πω... θα δειξει, αν και οταν παραλαβω.
Looter
20 July 2008
1,623
Το site είναι στα Σλοβάκικα και το laptop έχει Σλοβάκικο πληκτρολόγιο. Στέλνουν Ελλάδα;
Εκτός αν είσαι Σλοβακία και ρωτάς εμάς αν ένα τοπικό site είναι αξιόπιστο 😂😂😂
ilias
9,145
Bratislava
Χαχαχαχα, Σλοβακια ειμαι... και αυτο που με ανησυχει ειναι αν περαστηκαν λαθος τιμες / εκπτωσεις και μου ακυρωσουν την παραγγελια, οχι οτι το καταστημα δεν ειναι αξιοπιστο... :cool:
takisot
Μέλος Δ.Σ.
27,851
Παλλήνη
Ηρθε το μακ, εξωτερικα δεν εχει καποια σημανση refurbished, η συσκευασια ειναι αθικτη, οποτε μαλλον ολα καλα.
Περισσοτερα οταν το ανοιξω
Αντε καλοριζικο! Τσεκαρε τον σειριακο του στην apple να δεις αν ειναι γνησιο, αν εχει εγγυηση κλπ
Reactions: ilias
ilias
9,145
Bratislava
Ευχαριστω παιδια για τα καλοριζικα... θα το δω κι εκει Τακη τι λεει για εγγυηση κτλ.
Λιγα λογια για την αγορα.... ηταν η πλεον αχρειαστη για μενα... εχω το ΜΒΡ 13 early 2015 με 8 γιγα και 1ΤΒ 3rd party δισκο. Για τη χρηση που κανω εδω και 7 χρονια που το εχω, ειναι υπερ αρκετο.
Το μονο θεμα του ειναι καποιες υπερθερμανσεις, λογω της αλλαγης δισκου και φυσικα η αυτονομια, που μετα απο 1164 φορτισεις, ειναι καπου στις 3 - 4 ωρες αναλογως της χρησης (με την οριτζιναλ μπαταρια που δειχνει ακομα status normal).
Ωστοσο, οταν προχθες ειδα το 14ρι σε τιμη 1500 ευρω (1.250 χωρις το φπα), πλησιαζε και του Βαλεντινου... ε... δεν αντισταθηκα και πολυ :)
Απο οσα προλαβα να δω, ειχε 2 φορτισεις στην μπαταρια, η εγγυηση λεει οτι ληγει Σεπτεμβριο του 2023, αρα υποθετω ειναι παραγωγης λιγων μηνων, ηρθε με μπαταρια κατω του 10%.
Το πληκτρολογιο εχει πιο μεγαλα κουμπια, με καλυτερη αισθηση, αλλα με χαλασε λιγο το οτι ειναι ολο μαυρο και δεν ξεχωριζουν τα κουμπια ευκολα απο το πανελ οπτικα.
Ηρθε με Μοντερει και κατεβασα το Βεντουρα. Εκανα clean install και θα βαλω τις λιγοστες 3rd party εφαρμογες μου μια μια. Εβαλα φυσικα το ιδιο IDcloud που ειχα ηδη για να συγχρονισει τα βασικα (μειλ, msgs, passwords κτλ).
Ο ογκος του, οταν το εβλεπα στα καταστηματα με τρομαζε... τωρα βεβαια που το... φορτωθηκα, μου φαινεται μια χαρα :)
Ωστοσο, για μενα προσωπικα, η καλυτερη αγορα θα ηταν το air M2, σε 16/512 midnight, λογω φορητοτητας, αλλα ας ειναι... θα ζησω και με το 14ρι :cool:
Α... επισης, το magsafe απο το 13ρι δεν ταιριαζει στο 14ρι...
ilias
9,145
Bratislava
Εδω αρχιζουν τα θεματα... κατι δεν κανω καλα και δεν βρισκει το serial number. Αν και βαζω την ημερομηνια αγορας απο το τιμολογιο, δεν το βρισκει. Ισως φταιει οτι ειναι απο retailer η αγορα και οχι επισημο apple καταστημα, οποτε ημερομηνια αγορας να ειναι οταν το πηρε ο καταστηματαρχης ? Θα το κοιταξω...
spcav
18 August 2006
16,598
Το SN φαίνεται να το βρίσκει (δεν έχει να κάνει άλλωστε με την η/μ αγοράς).
Αυτό που πας να κάνεις είναι update στην η/μ αγοράς για να έχει αντίστοιχη ισχύ η εγγύηση (γιατί η Apple μετραει την εναρξη της εγγυησης ή με μια ''δικη'' της η/μ (παραγωγης; ) ή με την η/μ ενεργοποιησης). Για να το κανεις πρεπει να κανεις upload την αποδειξη αγορας.
Σε κάθε περίπτωση πάντως, έχε υπόψιν ότι για τον 2ο χρόνο εγγύησης θα πρέπει να απευθυνθείς στο κατάστημα.
ilias
9,145
Bratislava
Χμ... ευχαριστω Συριε, αν και δεν βλεπω καπου στο σαιτ να μπορω να ανεβασω την αποδειξη... θα το δω με το καταστημα τι και πως, γιατι εδινε και δωρο 3μηνο στα services, tv, music κτλ και δεν βλεπω ουτε αυτα πως ενεργοποιουνται, οποτε θα περασω απο κει να μου πουνε.
Με γειες, εξαιρετικό μηχάνημα και σούπερ VFM τιμή! Όσο για το "αχρείαστη" αγορά, θα δεις τεράστιες διαφορές στην πορεία. Έτσι έλεγα κι εγώ ότι έκανα υπερβολή που άλλαξα ( μάλιστα από MBP 2018), και συνειδητοποιώ μια βδομάδα που το παίζω ότι οι διαφορές είναι αισθητές κυριολεκτικά παντού (ταχύτητα, οθόνη, μπαταρία, πληκτρολόγιο, θερμοκρασίες, θόρυβος, θύρες, μέχρι και.... φόρτιση!)
Reactions: takisot and ilias
ilias
9,145
Bratislava
Ευχαριστω Ιασωνα... οτι ειναι καλυτερο απο το παλιο, ειναι... τωρα αν αξιζε η αγορα του τωρα η πχ μετα απο 4-5 χρονια που ακομα θα κρατουσε το παλιο... ε, λεφτα υπαρχουν (λεμε τωρα).
Οσο για την ημερομηνια ληξης της εγγυησης που ηταν ενα 6μηνο πριν την αγορα, ειχε δικιο ο Συριος...
Πηγα στο καταστημα αγορας και δεν ηξεραν τι και πως, πρωτη φορα το ειδαν κτλ κτλ. Μου ειπαν να επικοινωνησω με τη απλ.
Πηρα στο τσατ, μιλισα με ενα τυπο κανα τεταρτο, του εστειλα φωτο απο την αποδειξη αγορας και το σηριαλ του λαπτοπ, ενημερωσε κατι υπευθυνους σχετικα με τα business agreements και μου εκλεισε τηλεφωνικο ραντεβου με το εμπορικο τους στην Ιρλανδια.
Με πηραν την συμφωνημενη ωρα, μιλισα με εναν Graig, που με εστειλε σε μια Maria και μετα απο ενα τεταρτακι, μου ειπε οτι ανανεωσε τη ληξη της εγγυησης και οτι δεν χρειαζεται να ανησυχω αν ειναι κλεμμενο, μεταχειρισμενο κτλ. απλα, ειπε οτι οι 3rd party retailers, ανεβαζουν στο σαιτ τα σηριαλ την ημερα αγορα τους και δεν τα ανανεωνουν -συνηθως- οταν τα μεταπουλανε.
Περνει 5 μερες να ανανεωθει μου ειπε στο σαιτ τους.
Τελος καλο, ολα καλα... (y)
