[Επίσημο] Xiaomi Redmi Note 5 / 5 Pro
airb
25 May 2008
15,169
Λιβαδειά
airb
25 May 2008
15,169
Λιβαδειά
Τεχνικά Χαρακτηριστικά
Redmi Note 5 ProRedmi Note 5
System OSAndroid 8.1 (Oreo) with MIUI 9.2Android 8.1 (Oreo) with MIUI 9.2
Display
5.99'' (15.2cm) (Diagonal)
18:9 full screen display
2160 x 1080 FHD+, 403 PPI
84% NTSC color gamut
Sunlight mode
Night mode
Reading mode
Color temperature adjustment
Standard mode
18:9 screen aspect ratio
2160 x 1080 FHD+ resolution, 403 PPI, 1000:1 contrast ratio
450 nits brightness
84% of NTSC color gamut
Sunlight display
Night display
Reading mode
Standard mode
ProcessorSnapdragon 636, Octa-coreSnapdragon 625, 1.8GHz max
Memory
4GB / 6GB
LPDDR4X
eMMC 5.0 flash storage
3GB / 4GB
LPDDR4X
Battery
4000mAh, lithium-ion polymer battery
5V/2A charging
QC2.0
4000mAh
5V/2A
Rear Camera
12MP primary sensor (1.25μm, f/2.2 aperture)
5MP secondary lens (1.12μm, f/2.0 aperture)
Single tone flash
PDAF
Enhanced low-light photography
HDR adjustments
Panorama
Burst mode
Face recognition
12MP, 1.25μm large pixel
5-element lens, Ζ’/2.2 aperture
Dual LED flash
PDAF
Low light enhancement
HDR
Panorama
Burst mode
Face recognition
Front Camera20MP sensor
1.0μm, f/2.2 aperture
Beautify 4.0
Selfie-light
Selfie timer
Face recognition
5MP front camera
Beautify 4.0
Selfie-light
Selfie countdown
Face recognition
Video
Recording
1080p video capture, 30 fps
720p video capture, 30 fps
Sensors
Electronic Compass, Accelerometer, Proximity,
Infrared, Ambient light, Gyroscope, Hall sensor
ConnectivityWi-Fi 802.11ac | WiFi Direct | WiFi Display
Bluetooth 5.0
WiFi 802.11ac | WiFi Direct | WiFi Display
Bluetooth 5.0
Dual SIM
Nano-SIM + Nano-SIM or Nano-SIM + micro SDNano-SIM + Nano-SIM or Nano-SIM + micro SD
GPS NavigationGPS, AGPS, GLONASS, BeiDou positioningGPS, AGPS, GLONASS, BeiDou positioning
Package
Redmi Note 5 Pro
Power adapter
USB 2.0 cable
Warranty card
User guide
SIM insertion tool
Ultra-Slim case
Redmi Note 5
Power adapter
USB cable
Warranty card, user guide
SIM insertion tool
Ultra-Slim case
SARHead: 1.188 W/Kg
Body: 0.334 W/Kg
Head: 1.188 W/Kg
Body: 0.334 W/Kg
Dimensions158.6 x 75.4 x 8.05 mm158.5 x 75.45 x 8.05 mm
Weight181 gr180 gr
airb
25 May 2008
15,169
Λιβαδειά
Έρχεται επίσημα στις 16 Μαρτίου
Αναμένεται σύντομα να διατεθεί και στην Κινεζική αγορά -μετά το λανσάρισμά του στην Ινδία αρχικά-.
Η ανακοίνωση έγινε από τον Product Manager της Xiaomi στα -πλαίσια του MWC 2018- και σύμφωνα
με τα όσα ανέφερε το λανσάρισμα θα ξεκινήσει στις 16 Μαρτίου!​
Η συσκευή έχει ήδη περάσει από την ΤΕΝΑΑ (Κινεζική Επιτροπή Πιστοποίησης) και σε αυτές βλέπουμε
το Redmi Note 5 Pro (της Ινδίας), να παίρνει πιστοποίηση ως Redmi Note 5 - για την αγορά της Κίνας
προφανώς. Σύμφωνα με την καταχώρηση, το Redmi Note 5 θα διαθέτει FHD+ οθόνη 5,99 ιντσών, το
Snapdragon 636 SoC + Adreno 509 GPU στα ενδότερα, μαζί με 4GB RAM + 64GB αποθηκευτικού
χώρου, ενώ δεν αποκλείεται να δούμε και ακόμα πιο ισχυρή έκδοση με 6GB RAM!
Όλα δείχνουν οτι θα είναι το πρώτο μοντέλο της εταιρίας που θα βασίζεται στο Android 8.1 Oreo, ενώ
θα έχει διπλή κάμερα στα 12MP+8MP (σύμφωνα με την ΤΕΝΑΑ) και μία ακόμα selfie κάμερα μπροστά
στα 8MP, ενώ θα συνοδεύεται από μπαταρία 3900 mAh.
[via]
