exaSound E22 MARK II
Gojakla
20 May 2009
5,856
Δεν την ξέρω την εταιρία, διάβαζα ολόγυρα διάφορα περί παπακίων και έπεσα πάνω του.
Το εψαχούλεψα λιγουλάκι και είδα να γράφουν όλοι οι γνωστοί/άγνωστοι πολύ καλά λόγια...
Καναδικής προελεύσεως και κατασκευής. Δεν έχει ακουμπήσει ασιάτης το εργαλείο...
Είπα να το μοιραστώ μαζί σας το λοιπόν.
Σπαρτιάτικο στην όψη, diy αισθητική...
Official Site
Specs
Sample Rates: ENclusiv™ comprehensive sample rate support
- DSD: 2.8224 or 3.072 MHz
- DSD2: 5.6448 or 6.144 MHz
- DSD4: 11.2896 or 12.288 MHz
- LPCM/DXD: 44.1kHz to 384kHz at 32 bits maximum sampling rate
- Native support for 88.2, 176.4 & (DXD) 352.8kHz master files
Converter Core: ESS Technologies 9018S Classic SABRE32 reference monolythic 8 channel DAC configured for stereo
USB Input: Proprietary ZeroJitter™ asynchronous USB interface with error correction on classic B–Type connector, USB cable included
Host Support: Custom, high performance Mac OS & Windows ASIO drivers; MAC Core Audio drivers with DoP256 support
Player Application Support: Automatic sampling rate switching, software upsampling up to 384 kHz PCM and DSD4
Clock: FemtoMaster™ super–low jitter 0.082ps (82fs) master clock with jitter minimization utilizing 3 three precision oscillators
Power Conditioning: 11 linear power filtering stages
Host Noise Rejection: Galvanic isolation between the USB subsystem and the DAC circuitry eliminates ground loop noise and blocks computer–generated interference
Headphone Output: Third generation headphone amplifier, 4W into 16Ω doubles the current output to drive low impedance and low sensitivity headphones
Digital Inputs: Two S/PDIF inputs provide jitter reduction and superb D/A conversion when used with CD transports
Analog Outputs: Simultaneously driven, gold–plated balanced XLR and unbalanced RCA line outputs
Power Management: 12V Trigger output
Remote Control: Included 7 button remote, the e22 can be easily programmed to work with most IR remotes
Μετρήσεις από την εταιρία
Reviews
Audiostream / TAS
3500 τα δολλάρια που ζητάει.
It better sounds reaaaaaaly good.
26 June 2006
14,830
Athens
Μπράβο Αντών! Το συγκεκριμένο κάνει θραύση στο εξωτερικό (όχι μόνο λόγω DSD4).
Δεν γράφεις σιγά-σιγά και για κάνα "γίγαντα" παπάκι?
ln()
1 February 2007
5,779
Βόλος
Εγώ ζαχάρωνα το πολυκάναλο: multichannel DSD downloads; Τώρα πια θα διαβάζουμε μόνο για τέτοια πράγματα.
Sonus Naturalis
12 July 2009
9,103
Αθήνα, Ηλιούπολη
Πολύ ενδιαφέροντα χαρακτηριστικά.
Πιό πολύ για Master μηχάνημα μοιάζει, αν και λείπει η AES/EBU.
Αλλά σωστά, μόνο θα διαβάζουμε πλέον γι' αυτά...
Δημοκηδής
23 June 2006
9,996
τι εστί ''παπάκι'' ;;;;
τέτοιο ;
ή μήπως ;
ή
