πωλούνται τα εν λόγω ηχεία σε εξαιρετική κατάσταση στα 350 ευρώ
SpecificationsDescription: Two-way, bass-reflex, stand-mounted loudspeaker. Drive-units: 1" (25mm) TNV aluminum-magnesium inverted-dome tweeter, 7" (180mm) Polyglass-cone woofer. Crossover frequency: 3kHz. Frequency response: 50Hz–28kHz, ±3dB. Low-frequency point: 41Hz. Sensitivity: 92dB (2.83V/m). Impedance: 8 ohms nominal, 4.2 ohms minimum. Recommended amplification: 25–175W.
Dimensions: 17.5" (448mm) H by 9.2" (237mm) W by 13" (333mm) D. Weight: 22.2 lbs (10.1kg).
Finish: Ebony-Moka.
http://www.stereophile.com/content/focal-chorus-807v-loudspeaker
Finish: Ebony-Moka.
