GearBest LED flashlights offers
Gearbest
7 February 2017
1,601
HaikeLite HT35 Long Shots Flashlight - 6500K
CREE XHP35 HD 2300Lm Cold White IPX8 Waterproof
$49.99 with coupon HT35
● Ultra clear AR coated toughened glass lens, the light transmission is up to 99pct
● Waterproof level up to IPX8, the flashlight can work normally even in heavy rainy days
● The shot distance is up to 1000 meters with wide beam range
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● With a waterproof coating on glass, it can protect the flashlight better
● Three brightness levels: 2300LM ( high ), 700LM ( middle ), 200LM ( low )
● The flashlight powered by 2 x 26650 / 18650 battery ( not included )
Gearbest
7 February 2017
1,601
Convoy S2 LED Flashlight - V2 - 1A 6500 - 7000K TITANIUM GREY
Cree XPL H1 450LM 7135 x 8 Driver Memory Function
$12.59 with coupon CS2GIFT
● Cree XPL HI LED
Available light color: V2 1A / U6 3A / U6 4B / U4 7A
1A, 3A, 4B, 7A present for different color temperature
1A: 6500 - 7000K
3A: 5000 - 5200K
4B: 4500 - 4700K
7A: 3000 - 3200K
Liminous flux:
1A: 1000LM
3A: 940LM
4B: 840LM
7A: 840LM
● 7135 x 8 driver circuit board ensures excellent performance
● Modes Directions:
It has 2 group modes
Group 1 ( 3 - mode ): 5pct - 40pct - 100pct
Group 2 ( 5 - mode ): 5pct - 40pct - 100pct - Strobe - SOS
Gearbest
7 February 2017
1,601
DQG Tiny 26650 3th LED Flashlight Torch - 4500K NEUTRAL WHITE BLACK
PMMA TIR System 2500Lm 7 x Cree XPG2
$51.99 with coupon GTiny
Model: Tiny 26650
Flashlight Type: Tactical
Flashlight size: Large size
Emitters: Cree XP-G2
Emitters Quantity: 7
Lumens Range: >2000 Lumens
Luminous Flux: 2500LM
Color Temperature: 4500K
Feature: Anti-Roll Rugged Design,Constant Current Circuit,Cooling Slot of High Efficiency,Lightweight,Reverse Polarity Protection,Stainless Steel Bezel,Tail Stand
Function: Camping,EDC,Exploring,Hiking,Household Use,Night Riding,Walking
Switch Location: Side Switch
Light Modes: High,Low,Mid,Turbo
Mode: 4(Turbo; High; Middle; Low)
Power Source: Battery
Battery Type: 26650
Battery Quantity: 1
Battery Included or Not: No
LED Lifespan: 50000h or more
Gearbest
7 February 2017
1,601
Nitecore i8 8 Charging Slots Smart Universal Quick Charger - EU PLUG BLACK
for Li-ion / IMR / Ni-MH ( Ni - Cd )
$39.95 with coupon N8Charger
● Capable of charging 8 batteries simultaneously
● Active current distribution
● Monitors and charges each of the 8 slots independently
● Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries
● Features three charging modes ( constant current, constant voltage, - dV / dt )
● Automatically detects power level of batteries and select the appropriate voltage and charging mode
● Automatically stops upon charging completion
● Over-charging prevention, reverse polarity protection and short circuit protection
● Activation function for over discharged protected batteries
● Designed for optimal heat dissipation
● Made from durable PC material ( fire retardant / flame resistant )
Main Specification:
● Input: AC 100 - 240V 50 / 60Hz 0.5A ( max ) 30W DC 12V 3A
● Output voltage: battery: 4.2V + / - 1pct, 1.48V + / - 1pct; USB: 5V + / - 5pct
● Output current: battery: 2 x 1.5A, 4 x 1A, 4 x 0.75A, 8 x 0.5; USB: 5V x 2.1A
● Compatible with: Li-ion / IMR: 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500, 16340 (RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 22500, 22650, 25500, 26500, 26650; Ni-MH ( Ni-Cd ): AA, AAA, C, D
Gearbest
7 February 2017
1,601
Nitecore P16 Cree XM - L T6 5 - Mode 960lm 18650/CR123 LED Flashlight
$36.95 with coupon P16GIFT
Model: P16
Lamp Beads: XM-L T6
Emitters Quantity: 1 x Cree XML T6
Lumens Range: 500-1000Lumens
Feature: Lanyard,Memory Function,Stainless Steel Bezel
Function: Camping,Exploring,Fishing,Hiking,Household Use,Hunting,Night Riding,Seeking Survival,Walking
Battery Type: 18650,CR123
Battery Quantity: 1 x 18650 / 2 x CR123 (not included)
Zooming: No
Rechargeable: Yes
Waterproof Standard: IPX-8 Standard Waterproof (Underwater 2m)
Gearbest
7 February 2017
1,601
Convoy C8 LED Flashlight - U6 3A SILVER
Cree XPL H1 U6 3A 993Lm 7135 x 8 Driver 12 Group Modes Memory Function
Flash Sale Price $18.99
Available body color and light color: black ( U6 3A / V2 1A ), silver ( U3 7A / U6 3A / V2 1A )
1A, 3A, 7A present for different color temperature
1A: 6500K
3A: 5000K
7A: 3000K
● Modes Directions:
Black type has 2 group modes
Group 1 (3-Mode): 5pct - 40pct - 100pct
Group 2 (5-Mode): 5pct - 40pct - 100pct - Strobe - SOS
Silver type has 12 group modes
● Memory function
If the flashlight is turned on more than 3s, current mode will be memorized
● Low voltage and reverse polarity protection
When the voltage of battery is 2.9-3.1V, the flashlight flashes 2 times / s
Gearbest
7 February 2017
1,601
NITECORE NU10 Rechargeable LED Headlamp - BLACK
Flash Sale Price $16.99
● Ultra lightweight and compact headlamp with 6 available colors
● 170 degree wide angle illumination adequately covers the entire field of vision
● 60 degree adjustable illumination angle for different environment
● White and red dual light source, 3 brightness levels and 2 special modes
● Built-in 900mAh Li-ion battery rated at 3.33Wh, runtime up to 150 hours
● Advanced Micro-USB power regulation retains all functions while charging
● Dual switch design to prevent accidental activation
● Dust and water resistance according to IP66 standard
● Durable polycarbonate body / constant voltage circuit / power indicator / lock-out function
Gearbest
7 February 2017
1,601
Klarus XT1C Upgraded Edition Tactical LED Flashlight
Cree XP-L HI V3 700Lm Pocket Size Programmable Setting Dual Tail Switch
$27.99 !! with coupon CTLD
● Handy size, superb functionality, industry leading patented features
● Latest CREE XP-L HI V3 LED, max 700Lm output, beam reaches 210 meters
● One-handed tactical control: one-touch Strobe / High / Low
● Innovative dual tail switch, easy interface design
● 3 brightness levels, 2 flash modes, 2 programmable settings for multi-purpose use
- Tactical setting ( factory default ): one-touch Strobe / High, versatile in all tasks
- Outdoor setting: one-touch High / Low; SOS, specially designed for the wilderness
● ITS temperature control, real time monitors and auto adjusts output levels to keep crucial component safe
● Waterproof in accordance with IPX-8 ( underwater 2 meters )
● Constant current circuit driver, no flashes and PWM blinking
● Integrated design for efficient heat dissipation
● Dual spring design resists shock and drop damages
● Reverse polarity protection eliminates damage from incorrect battery install
● CNC machined aero-space aluminum alloy body with mil-spec HAIII hard anodizing
● Hardened mineral glass lens with AR coating, scratch resistance
Gearbest
7 February 2017
1,601
HaikeLite SC01 CREE XHP35 HI Long Shots Flashlight
Flash Sale Price $34.99
● Made of high-quality 6063 aluminum alloy with side-click metal waterproof button, portable and practical
● Waterproof level up to IPX8, the flashlight can work normally even in heavy rain days
● When the light is on, fast single click and long press to lock out the switch
● Six brightness level: extremely low: 20lm; low: 200lm; mid: 500lm; high: 1000lm; hidden turbo: 2000lm ( double click ); hidden strobe: 2000lm ( press the button for 2 seconds )
● Press 4 seconds to activate battery power detection function. When power is more than 50pct, the light flashes 3 times; when between 50pct and 25pct, flashes 2 times; when less than 25pct, flashes one time
Note:
● The flashlight will become hot in turbo mode, please do not continuously use turbo mode for over 10 minutes
● Medium mode and high mode in bright enough for daily use
● The flashlight powered by 1 x 26650 battery ( not included )
Gearbest
7 February 2017
1,601
Klarus Mi7 Ti AA LED Flashlight
Cree XPL HI V3 700Lm TC4 Titanium Alloy Rugged Design
● TC4 titanium alloy construction, permanent color, corrosion and scratch resistance
● Comes in finger size, stainless steel side switch for one handed control
● CREE XP-L HI V3 LED, max output 700LM,max runtime 67h
● 5 modes: high - low - moonlight - strobe - SOS
● One touch access to Moonlight and High output levels
● Battery capacity indication displays remaining power for easy monitoring
● Lock-out mode specially designed to prevent accidental activation of the flashlight
● Over-discharge protection automatically lowers output levels to protect rechargeable batteries
● IPX-8 waterproof standard ( 2 meters submersible rating ) to cope with bad weather
● Efficiency circuit with broad voltage range to accommodate both AA ( included ) and 14500 batteries
● Constant current driver with no PWM flash, suitable for photography illumination
$34.59 with coupon BLMI7
