Ο κατασκευαστής δίνει έξοδο για το black 1.2 Volt ανεξάρτητα από την πηγή τροφοδοσίας (κινητό ή Η/Υ)
Τα Fidelio Χ2 με βάση τα χαρακτηριστικά τους για να πάνε στα 115 dB spl , δηλαδή πάρα πολύ δυνατά
χρειάζονται 0,97V rms συνεπώς θεωρητικά τα οδηγεί άνετα.
Το Red πάλι έχει διπλάσια έξοδο στα 2.1 Volt για πιο δύσκολα φορτία.
Επίσης όσο αφορά την συμβατότητα με android δείτε το παρακάτω
Yes. DragonFly Black and Red will work with most Android devices running on Lollipop OS (and some Android devices running on KitKat), provided that the device manufacturer has adhered to the USB specification and implementation, and supports audio over USB.
To verify that your Android device complies with isochronous USB audio, download and run
USB Host Check.
In our early pre-production testing, we found that some Android devices (4.1 OS and newer) do not provide native support for audio over USB. If you find that your Android device (4.1 or newer) does not support audio over USB, we ask that you please contact the manufacturer of your device. To determine whether your device supports audio over USB, consult the user manual or visit the manufacturer’s website.
For a reliable media player that has its own built-in USB device driver, ensuring reliable connectivity to all USB DACs, we suggest the
ExtreamSD USB Audio driver application. This application is compatible with various audio formats and will manage music on both the Android’s internal memory and inserted SD cards.
Additionally, with the phone connected to the Wi-Fi network, this application can find and connect to DLNA servers/libraries. Version 2.2.5 USB Pro Player now supports playback for Tidal Streaming.
Android devices use a USB format known as “OTG” (On the Go). In order to connect an Android device in USB Host Mode to a DAC, an OTG adaptor must be used. (See
www.audioquest.com/dragontailOTG.)
