πολυ ευχαριστο νεο... να ενεργοποιηθει και το pvr παρακαλω
μαλλον τσαμπα χαρηκα... εβαλα μια ταινια με τα παρακατω χαρακτηριστικα και μου εβγαζε μηνυμα
" ο ηχος δεν υποστηριζεται"
General
Unique ID : 185002774929912647492171523736576620102 (0x8B2E3D07FE670E29AC0216BE4FC27646)
Complete name : N:\men.in.black.3.2012.1080p.bluray.3D.h-sbs.dts.x264-publichd.mkv
Format : Matroska
Format version : Version 2
File size : 11.6 GiB
Duration : 1h 45mn
Overall bit rate : 15.7 Mbps
Encoded date : UTC 2012-09-08 09:59:20
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 13.9 Mbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.290
Stream size : 10.3 GiB (88%)
Writing library : x264 core
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.12 GiB (10%)
Language : English
Default : Yes
Forced : No
