Re: -LG Tv Line-up 2017-
LG Oled TV 2017 - european models / LG Oled TV 2017 - european models / LG Oled TV 2017 - european models | |||||||||||||||||||||||||||
Series | Certificates | HDR | Hardware & Software | Calibration | Picture Quality | Other | Series | ||||||||||||||||||||
Series & Model ________________ | UHD Premium _____ | ISF ccc ______ISFccc - Certified Calibration Controls | THX ____ | Hybrid _____Log Gamma (HLG) | HDR 10 ST2084 (EOTF PQ), ST2086 (static metadata) ST2094 (dynamic metadata) ________ | Dolby Vision ____VS10 | Advanced HDR Technicolor _______ | SoC / GPU / RAM _________________________ Plattform, Central Processing Unit, System on Chip, Instruction set, Graphic Processor Unit, RAM, Total memory | Software ____________ Operating System, Firmware version, | Videopanel _________________________Size class, Type LCD/Oled matrix, Resolution, Pixel structure, Bits of color, Quantum dots, Frequency of T-Con board, Curvature, Screen Uniformity, Anti-reflective filter | Backlight Unit ______________Type backlight, Local Dimming zone, Type LED, MEMC, Backlight Scanning, Black Frame Insertion, Pulsе Wide Modulation | Opportunities for calibration _____________________ISF ccc, Color Menagment System, Technicolor Expert Mode, White balance, Gamma, | Internal Processing _____________________________Scaling, Interpolation, Overscaninng, Digital Noise reduction, Deinterlacing (Video mode, Film mode), -, | Color _______________________________DCI P3 coverage (xy / uv), Rec.2020 coverage (xy / uv), White balance dE, Color Delta E, Gamma, Color Temperature, | Brightness _______________________________Peak in HDR Peak in SDR, Average Picture Level, Automatic Brightness Limiter, | Contrast ______________ANSI Contrast, With local dimming, Without local dimming, White level, Black level | Viewing angle ____________ Horizontal & Vertical (°cone) | Motion resolution ______________ | Input Lag ______________ | Audio _____________________________ | Built in Media Player _______________________________________________Supported file systems Image file formats Audio file formats/codecs Video file formats Subtitles | Connectivity __________________ | Supported Resolutions __________________________Frame per seconds 24, 25, 30, 50, 60, 100, 120 Chroma subsampling 4:4:4 4:2:2 4:2:0 | Conectors __________________________________ | Tuners ___________________ | Note _____________________________________Pros & Cons | Series & Model ____________________ |
W7 (Flat) OLED 77W7V OLED 65W7V no 3D no HFR (High Frame Rate) | Yes | Yes | No | Yes - in Internet video services, HDMI, USB port. | Yes | Yes in internet services, HDMI, USB port. | Yes after update Conversion SDR/HDR ST2084, ST2086, ST2094, Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film | Plattform: SoC: Core Architecture: 2 x Quad Core(2x4) Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: Electronics and remote connection in the sound bar | OS: webOS 3.5 | 76.7" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat - Model: LC770LQD (LG Display) 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat - Model: LC650LQD (LG Display) 54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat - Model: LC550LQD (LG Display) No vignetting; Anti-reflective filter PWM - No BFI - No | No backlight | ISF expert mode - day & night - Technicolor Expert Mode pre-calibrated on cinema standard (either with Rec.2020 content Rec.709 , HDR or SDR) White balance - 2/20points Gamma, | Very Good for HD, True Motion -, 0% with [just scan] engaged, Optional; effective whwn engaged Video - effective jaggies reduction Film - Passed 3:2 & 2:2 cadence test in HD & SD | 77" - DCI/P3 - 98% / 99% 77" - BT.2020 - 73% / 76% 77" - 77" - 77" - 2.2 77" - 65" - DCI/P3 - 98% / 99% 65" - BT.2020 - 73% / 76% 65" - 65" - 65" - 2.2 65" - | 77" - max 800cd/m2 in HDR 77" - max 430cd/m2 in SDR 65" - max 800cd/m2 in HDR 65" - max 430cd/m2 in SDR APL - ABL - full-field peak white came in at: 5% - 900cd/m2 (Vivid mode) - in HDR 10% - 700cd/m2 (Vivid mode) - in HDR | 77" - 77" - x 77" - Inf.:1 77" - 150cd/m2 77" - 0cd/m2 65" - 65" - x 65" - Inf.:1 65" - 65" - 0cd/m2 | 77" - 65°/° 65" - 65°/° Color shift - 26° Brightness - 69° Black Level - 75° | 77" - horizontal lines 65" - horizontal lines | 77"- HDR - 21ms 77"- Game mode - 77"- by default 65"- HDR - 21ms 65"- Game mode - 65"- by dafault | Dolby Atmos sound bar 4.2 channels - 60W (4ohms) 2x15W + 2x15W Dolby Atmos, Dolby Plus, Dolby Puls, DTS, DTS-HD, TrueHD, Wireless Sound Synk | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG, MPO, JPS Audio file formats/codecs AAC (Advanced Audio Coding) AC-3 apt-X FLAC (Free Lossless Audio Codec, .flac) MP3 (MPEG-2 Audio Layer II, .mp3) OGG (.ogg, .ogv, .oga, .ogx, .spx, .opus) Real Audio (.ra, .ram) WMA (Windows Media Audio, .wma) HE-ACC LPCM Video file formats 3GPP (3rd Generation Pertnership Project, .3gp) AVI (Audio Video Interleaved, .avi) DivX (.avi, divx,, .mkv) Flash Video (.flv, .f4v, .f4p, .f4a, .f4b) H.263 H.264 / MPEG-4 Part 10 / AVC Video H.265 / MPEG-H Part 2 / HEVC MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks) Quik Time (.mov,. qt) M2TS (Blu-Ray Disc Audio Video(BDAV) MPEG-2 Transport Stream, .m2ts,. MTS) MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v) MPEG4 TS (MPEG Transport Stream, .ts, .tsv, .tsa) VC-1 VP9 | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 Miracast, Screen Share, Content Share, IP Control, Intel WiDi, UPnP, Wireless Display, | 4096 x 2160 / 60P(displayed as 3840x2160) 4096 x 2160 / 24P(displayed as 3840x2160) 3840 x 2160 / 24P 3840 x 2160 / 25P 3840 x 2160 / 30P 3840 x 2160 / 50P 3840 x 2160 / 60P / 4:4:4 1920 x 1080 / 120Hz - ?? 1920 x 1080 / 24P (Only HDMI) 1920 x 1080 / 30P (Only HDMI 3/4) 1920 x 1080 / 60P (HDMI 1/2 / Component) 1920 x 1080 / 50P (HDMI / Component) 1920 x 1080 / 60I 1920 x 1080 / 50I 1366 x 720 / 24P (Only HDMI)-Up to 18Gbps 4K 60p, 4:4:4, 8bit 4K 60p, 4:2:2, 8,10,12-bit 4K 60p, 4:2:0, 8,10-bit HDR included in HDMI 2/3 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Double tuners DVB-T/T2/C/S/S2 Analog (NTSC, PAL, SECAM) DiSEqC version 1.0 PIP, PAP, PAT Timeshift & PVR MPEG2, MPEG4,HEVC H.265, VP9 ver.2 | OLED 77W7V OLED 65W7V | |
G7 (Flat ) OLED 77G7V OLED 65G7V successor model G6 no 3D no HFR (High Frame Rate) | Yes | Yes | No | Yes - in Internet video services, HDMI, USB port. | Yes | Yes in internet video services, HDMI, USB port. | Yes after update Conversion SDR/HDR Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film. | Plattform: SoC: Core architecture: 2 x Quad Core Instruction set: Operating at up to GPU: OpenGL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: Electronics and remote connection in the sound bar | OS: webOS 3.5 | 76.7" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat - Model: LC770LQD (LG Display) 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC650LQD (LG Display) Anti-reflective filter | No backlight | ISF expert mode - day & night - Technicolor Expert Mode pre-calibrated on cinema standard (either with Rec.2020 content Rec.709 , HDR or SDR) White balance - 2/20 points | True Motion - - - - | 77" - DCI/P3 - 99% 77" - Rec.2020 - 70% 77" - 77" - 77" - 65" - DCI/P3 - 99% 65" - Rec.2020 - 70% 65" - 65" - 65" - | 77" - max 800cd/m2 65" - max 800cd/m2 APL ABL - full-field peak white came in at: 5% - 900cd/m2 (Vivid mode) - in HDR 10% - 700cd/m2 (Vivid mode) - in HDR | 77" - 77" - x 77" - Inf.:1 77" - 77" - 0cd/m2 65" - 65" - x 65" - Inf.:1 65" - 65" - 0ccd/m2 | 77" - ° 65" - ° | 77" - horizontal lines 65" - horizontal lines | 77"- HDR 77"- Game mode 77"- by dafault 65"- HDR 65"- Game mode ms 65"- by default ms | Dolby Atmos soundbar built into stand Harman Kardon 2.2 - 60W (4ohms) Dolby Atmos, Dolby Plus, Dolby Puls, DTS, DTS-HD, TrueHD | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG, MPO, JPS Audio file formats/codecs AAC (Advanced Audio Coding) AC-3 apt-X FLAC (Free Lossless Audio Codec, .flac) MP3 (MPEG-2 Audio Layer II, .mp3) OGG (.ogg, .ogv, .oga, .ogx, .spx, .opus) Real Audio (.ra, .ram) WMA (Windows Media Audio, .wma) HE-ACC LPCM Video file formats 3GPP (3rd Generation Pertnership Project, .3gp) AVI (Audio Video Interleaved, .avi) DivX (.avi, divx,, .mkv) Flash Video (.flv, .f4v, .f4p, .f4a, .f4b) H.263 H.264 / MPEG-4 Part 10 / AVC Video H.265 / MPEG-H Part 2 / HEVC MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks) Quik Time (.mov,. qt) M2TS (Blu-Ray Disc Audio Video(BDAV) MPEG-2 Transport Stream, .m2ts,. MTS) MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v) MPEG4 TS (MPEG Transport Stream, .ts, .tsv, .tsa) VC-1 VP9 | Lan (100BASE-TX/10BASE-T) Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz 802.11 ac WiFi Direct DLNA 3.0, Blietooth (NFC) Ver. 4.1 Miracast, Screen Share, Content Share, IP Control, Intel WiDi, UPnP, Wireless Display | 4096 x 2160 / 60P(displayed as 3840x2160) 4096 x 2160 / 24P(displayed as 3840x2160) 3840 x 2160 / 24P 3840 x 2160 / 25P 3840 x 2160 / 30P 3840 x 2160 / 50P 3840 x 2160 / 60P / 4:4:4 1920 x 1080 / 120Hz - ?? 1920 x 1080 / 24P (Only HDMI) 1920 x 1080 / 30P (Only HDMI 3/4) 1920 x 1080 / 60P (HDMI 1/2 / Component) 1920 x 1080 / 50P (HDMI / Component) 1920 x 1080 / 60I 1920 x 1080 / 50I 1366 x 720 / 24P (Only HDMI)-Up to 18Gbps 4K 60p, 4:4:4, 8bit 4K 60p, 4:2:2, 8,10,12-bit 4K 60p, 4:2:0, 8,10-bit HDR included in HDMI 2/3 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Double tuners DVB-T/T2/C/S/S2 Analog (NTSC, PAL, SECAM) DiSEqC version 1.0 PIP, PAP, PAT Timeshift & PVR MPEG2, MPEG4, HEVC H.265, VP9 Ver.2 | OLED 77G7V OLED 65G7V | |
E7 (Flat) OLED 65E7V OLED 55E7V successor model E6 no 3D | Yes | Yes | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update Conversion SDR/HDR Technocolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film. | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM:Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC650LQD (LG Display) 54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No,120/100Hz - Model: LC550LQD (LG Display) Anti-reflective filter | No Backlight | ISF expert mode - - ?? White balance - 2/20 points | 65" - DCI/P3 - 99% 65" - 65" - 65" - 65" - 55" - DCI/P3 - 99% 55" - 55" - 55" - 55" - | 65" - 55" - | 65" - 65" - 65" - 65" - 65" - 55" - 55" - 55" - 55" - 55" - | 65" - ° 55" - | 65" - horizontal lines 55" - | 65" - HDR 65" - Game mode 65" - by dafault 55" - HDR 55" - Game mode 55" - by dafault | Dolby Atmos sound bar built into stand Dolby Atmos, Dolby Plus, Dolby Puls, DTS, DTS-HD, | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG, MPO, JPS Audio file formats/codecs AAC (Advanced Audio Coding) AC-3 apt-X FLAC (Free Lossless Audio Codec, .flac) MP3 (MPEG-2 Audio Layer II, .mp3) OGG (.ogg, .ogv, .oga, .ogx, .spx, .opus) Real Audio (.ra, .ram) WMA (Windows Media Audio, .wma) HE-ACC LPCM Video file formats 3GPP (3rd Generation Pertnership Project, .3gp) AVI (Audio Video Interleaved, .avi) DivX (.avi, divx,, .mkv) Flash Video (.flv, .f4v, .f4p, .f4a, .f4b) H.263 H.264 / MPEG-4 Part 10 / AVC Video H.265 / MPEG-H Part 2 / HEVC MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks) Quik Time (.mov,. qt) M2TS (Blu-Ray Disc Audio Video(BDAV) MPEG-2 Transport Stream, .m2ts,. MTS) MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v) MPEG4 TS (MPEG Transport Stream, .ts, .tsv, .tsa) VC-1 VP9 | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 Miracast, Screen Share, Content Share, IP Control, Intel WiDi, IPnP, Wireless Display, | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Double Tuners DVB-T/T2/C/S2 Analog (NTSC, PAL, SECAM) with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 Ver.2 | OLED 65E7V OLED 55E7V | |||
C7 (Flat) OLED 65C7V OLED 55B7V successor model C6 no 3D | Yes | Yes | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 64.5" - AM-OLED(Trople Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC650LQD (LG Display) 54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC550LQD (LG Display) Anti-reflective filter- | No Backight | ISF expert mode - - ?? White balance - 2/20 points | 65" - DCI/P3 - 99% 65" - 65" - 65" - 65" - 55" - DCI/P3 - 99% 55" - 55" - 55" - 55" - | 65" - 55" - | 65" - 65" - 65" - 65" - 65" - 55" - 55" - 55" - 55" - 55" - | 65" - ° 55" - ° | 65" - horizontal lines 55" - horizontal lines | 65" - HDR 65" - Game mode 65" - by default 55" - HDR 55" - Game mode 55" - by default | Dolby Atmos TV speakers Dolby Atmos, Dolby Plus, Dolby Puls DTS, | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG, MPO, JPS Audio file formats/codecs AAC (Advanced Audio Coding) AC-3 apt-X FLAC (Free Lossless Audio Codec, .flac) MP3 (MPEG-2 Audio Layer II, .mp3) OGG (.ogg, .ogv, .oga, .ogx, .spx, .opus) Real Audio (.ra, .ram) WMA (Windows Media Audio, .wma) HE-ACC LPCM Video file formats 3GPP (3rd Generation Pertnership Project, .3gp) AVI (Audio Video Interleaved, .avi) DivX (.avi, divx,, .mkv) Flash Video (.flv, .f4v, .f4p, .f4a, .f4b) H.263 H.264 / MPEG-4 Part 10 / AVC Video H.265 / MPEG-H Part 2 / HEVC MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks) Quik Time (.mov,. qt) M2TS (Blu-Ray Disc Audio Video(BDAV) MPEG-2 Transport Stream, .m2ts,. MTS) MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v) MPEG4 TS (MPEG Transport Stream, .ts, .tsv, .tsa) VC-1 VP9 | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Twin Tuners DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | OLED 65C7V OLED 55C7V | |||
B7 (Flat) OLED 65B7V OLED 55B7V successor model B6 no 3D | Yes | Yes | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC650LQD (LG Display) 54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz - Model: LC550LQD (LG Display) - | No Backight | ISF expert mode - No IRE White balance - 2/20 points | 65" - DCI/P3 - 99% 65" - 65" - 65" - 65" - 55" - DCI/P3 - 99% 55" - 55" - 55" - 55" - | 65" - 55" - | 65" - 65" - 65" - 65" - 65" - 55" - 55" - 55" - 55" - 55" - | 65" - ° 55" - ° | 65" - 55" - | 65" - HDR 65" - Game mode 65" - by default 55" - HDR 55" - Game mode 55" - by dafault | Dolby Atmos TV speakers Dolby Atmos, Dolby Plus, Dolby Puls DTS, | - | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Twin Tuners DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | OLED 65B7V OLED 55B7V | |||
LG Nano Cell LCD TV 2017 - european models / LG Nano Cell LCD TV 2017 - european models / LG Nano Cell LCD TV 2017 - european models / LG Nano Cell LCD TV 2017 - european models | |||||||||||||||||||||||||||
SJ95 (Flat) LG 86SJ9500 LG 65SJ9500 successor model UH95 no3D | Yes | No | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 85.6" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC650EQ (LG Display) 64.5" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC550EQ (LG Display) NANO CELL | Edge Led, Local Dimming | IRE White balance - 2/20 points Gamma - 10 points | 86" - DCI/P3 - 99% 86" - Rec.2020 86" - 86" - 86" - 65" - DCI/P3 - 99% 65" - Rec.2020 65" - 65" - 65" - | 86" - 65" - | 86" - 65" - | 86" - ° 65" - ° | 86" - 65" - | 86" - 86" - 86" - 65" - 65" - 65" - | 5.2 Chanel, 80W Dolby Atmos, Dolby Plus, Dolby Puls DTS, Wireless Sound Sync | - | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Twin Tuners DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | LG 86SJ9500 LG 65SJ9500 | |||
SJ85 (Flat) LG 75SJ8500 LG 65SJ8500 LG 60SJ8500 LG 55SJ8500 successor model UH85 no 3D | ? | No | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 74.5" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC750EQ (LG Display) 64.5" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC650EQ (LG Display) 60" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz Model: LC600EQ (LG Display) 54.6" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC550EQ (LG Display) NANO CELL | Edge Led | IRE White balance - 2/20 points Gamma - 10 points | 75" - DCI/P3 - 99% 75" - rec.2020 75" - 75" - 75" - 65" - DCI/P3 65" - Rec.2020 65" - 65" - 65" - 60" - DCI/P3 60" - Rec.2020 60" - 60" - 60" - 55" - DCI/P3 - 99% 55" - Rec.2020 55" - 55" - 55" - | 75" - 65" - 60" - 55" - | 75" - 65" - 60" - 55" - | 75" - 65" - ° 60" - 55" - ° | 75" - 65" - 60" - 55" - | 75" - 75" - 75" - 65" - 65" - 65" - 60" - 60" - 60" - 55" - 55" - 55" - | Dolby Atmos, Dolby Plus, Dolby Puls DTS, | - | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Twin Tuners DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | LG 75SJ8500 LG 65SJ8500 LG 60SJ8500 LG 55SJ8500 | |||
SJ80 (Flat) LG 65SJ8000 LG 60SJ8000 LG 55SJ8000 successor model UH80 no3D | ? | Yes | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 64.5" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC650LQD (LG Display) 60" - AS-IPS, 2880x2160, WRGB 10-bit, Yes, 120/100Hz - Model: 54.6" - AS-IPS, 2880x2160, WRGB, 10-bit, Yes, 120/100Hz - Model: LC550LQD (LG Display) NANO CELL | Edge Led | IRE White balance - 2/20 points Gamma - 10 points | 65" - DCI/P3 - 99% 65" - Rec.2020 65" - 65" - 65" - 60" - DCI/P3 60" - Rec.2020 60" - 60" - 60" - 55" - DCI/P3 - 99% 55" - 55" - 55" - 55" - | 65" - 60" - 55" - | 65" - 55" - | 65" - ° 55" - ° | 65" - 55" - | 65" - 65" - 65" - 55" - 55" - 55" - | Dolby Plus, Dolby Puls DTS, | - | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | Twin Tuners DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | LG 65SJ8000 LG 55SJ8000 | |||
LG LCD TV 2017 - european models / LG LCD TV 2017 - european models / LG LCD TV 2017 - european models / LG LCD TV 2017 - european models | |||||||||||||||||||||||||||
UJ75 (Flat) LG 65UJ7500 LG 55UJ7500 LG 49UJ7500 LG 43UJ7500 successor model UH75 no 3D | ? | Yes | No | Yes in Internet video services, HDMI, USB port. | Yes | Yes in Internet video services, HDMI, USB port. | Yes after update Technicolor Expert mode: pre-calibration and rec.709 rec.2020 HDR on standard film | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 74.5" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC750EQ (LG Display) 64.5" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC650EQ (LG Display) 60" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC600EQ (LG Display) 54.6" - IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC550EQ (LG Display) | Edge Led | IRE White balance - 2/20 points Gamma - 10 points | 75" - DCI/P3 - 99% 75" - rec.2020 75" - 75" - 75" - 65" - DCI/P3 65" - Rec.2020 65" - 65" - 65" - 60" - DCI/P3 60" - Rec.2020 60" - 60" - 60" - 55" - DCI/P3 - 99% 55" - Rec.2020 55" - 55" - 55" - | 75" - 65" - 60" - 55" - | 75" - 65" - 60" - 55" - | 75" - 65" - ° 60" - 55" - ° | 75" - 65" - 60" - 55" - | 75" - 75" - 75" - 65" - 65" - 65" - 60" - 60" - 60" - 55" - 55" - 55" - | Dolby Plus, Dolby Puls DTS, | - | Lan (100BASE-TX/10BASE-T) Wi-Fi, 802.11 a, 802.11 b, 802.11 g, 802.11 n, 802.11 n 5GHz, 802.11 ac, Wi-Fi Direct, DLNA 3.0, Bluetooth (NFC) Ver.4.1 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | LG 65UJ7500 LG 60SJ7500 LG 55UJ7500 LG 43SJ7500 | |||
UJ65 (Flat) LG 65UJ6500 LG 55UJ6500 LG 49UJ6500 LG 43UJ6500 successor model UH65 no 3D | ? | Yes | No | Yes | Yes | Yes ? | Plattform: SoC: Core Architecture: Instruction set: Operating at up to: GPU: Open GL RAM: Total memory: Available memory: Internal storage total space: Internal storage free space: | OS: webOS 3.5 | 64.5" - AS-IPS, 2880x2160, WRGB, 10-bit, 120/100Hz - Model: LC650EQ (LG Display) 54.6" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC550EQ (LG Display) 48.5" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC490EQ (LG Display) 42.5" - AS-IPS, 2880x2160, WRGB, -bit, 120/100Hz - Model: LC430EQ (LG Display) | Edge Led | IRE White balance - 2/20 points Gamma - 10 points | 65" - DCI/P3 - 99% 65" - rec.2020 65" - 65" - 65" - 55" - DCI/P3 55" - Rec.2020 55" - 55" - 55" - 49" - DCI/P3 49" - Rec.2020 49" - 49" - 49" - 43" - DCI/P3 - 99% 43" - Rec.2020 43" -435" - 43" - | 65" - 55" - 49" - 43" - | 65" - 55" - 49" - 43" - | 65" - 55" - ° 49" - 43" - ° | 65" - 55" - 49" - 43" - | 65" - 65" - 65" - 55" - 55" - 55" - 49" - 49" - 49" - 43" - 43" - 43" - | Dolby Plus, Dolby Puls DTS, | - | Lan (100BASE-TX/10BASE-T) Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz 802.11 ac Wi-Fi Direct DLNA 3.0, Bluetooth (NFC) Ver.4.1 | 2 x USB 2.0 (DC 5V MAX 500mA) 1 x USB 3.0 (DC 5V MAX 900mA) 1 x Ethernet RJ45 4 x HDMI 2.0a - (ARC, CEC, MHL 3.0) with HDCP (High-bandtwidth Digital Content protection) 2.2 1 x Satelite In(Main; F-typefemale) 1 x AV Composite in 3.5mm jack 1 x Video Component In 3.5mm jack 1 x Optical Audio Out (AAC/PCM/AC3) 1 x Antena (RF) (female) 1 x CI+ 1.3 1 x RS.232(C) Compatible Rec.2020 input | DVB-T/T2/C/S2 with function PVR, timeshifting, PAP, PAT and PIP MPEG2, MPEG4, HEVC H.265 VP9 | LG 65UJ6500 LG 55UJ6500 LG 49UJ6500 LG 43UJ6500 |
