Microsoft Surface Pro 4 [2015]
alextrela
28 November 2011
3,129
Και νέο firmware update
June 2016 updates
June 20 release
The following updates are available:
Windows Update History Name
Device Manager Name
Microsoft driver update for Surface UEFI
Surface UEFI
v105.1203.768.0 improves system stability when the device resumes operation from sleep or hibernation, and optimizes battery use in connected standby.
Microsoft driver update for Surface Integration
Surface Integration Driver
v1.0.81.0 resolves issues where the touch screen remains active when the cover is closed against the screen.
alextrela
28 November 2011
3,129
IBM To Resell Microsoft Surface Devices To Enterprise Customers
http://mspoweruser.com/ibm-to-resell-microsoft-surface-devices-to-enterprise-customers/
IBM will draw on its analytics and enterprise applications expertise to create new industry-specific solutions for financial services and consumer packaged goods(CPG)/retail companies that take advantage of the unique capabilities of Surface devices. IBM understands the specific challenges of these industries and will work with us to build the right set of solutions across devices, apps and services that will help bring greater mobility into their business, seamlessly blending existing infrastructure and Universal Windows applications on the backend with an easy-to-use, mobile frontend.
Microsoft expands the Surface Enterprise Initiative with Booz Allen Hamilton
http://mspoweruser.com/microsoft-expands-surface-enterprise-initiative-booz-allen-hamilton/
Microsoft also partnered with Booz Allen Hamilton to take "the next step in meeting the needs of Public Sector organizations".
Booz Allen Hamilton will develop scalable and secure solutions for Governments, the Public Sector and Healthcare verticals. Booz Allen’s clients have very specific needs, in terms of app compatibility, security, confidentiality and multiple credentials. Booz Allen has chosen to partner with Surface to take advantage of the world class enterprise grade security, manageability and flexibility available only with the combination of Surface and Windows 10.
Εντωμεταξύ νέοι drivers για την Intel HD.
Intel HD Graphics Driver Update Hits Surface Book and Surface Pro 4
http://www.digitaltrends.com/computing/intel-surface-drivers/
Sent from my iPad Air 2
evanfotis
26 March 2008
5,485
Kαλό το στυλό ήθελε όμως λίγο περισσ'οτερο μήκος και δυνατότητα κεφαλής με tilt sensitivity όπως της wacom & apple pencil
alextrela
28 November 2011
3,129
Και νέο firmware update μόλις βγήκε διαθέσιμο.
Details about the July system updates for Surface Pro 4 and Surface Book
http://mspoweruser.com/change-log-july-system-updates-surface-pro-4-surface-book/
Εδω αναλυτικά οι βελτιώσεις/προσθήκες.
Surface Pro 4:
-Intel(R) CSI2 Host Controller (v30.10586.7076.2424) improves the stability of Windows Hello after an upgrade to Windows 10 Anniversary Update.
-Surface System Aggregator Firmware (v103.1226.256.0) improves the stability of the keyboard when the device resumes from hibernation or connected standby mode.
-Surface Touch (v51.250.106.239) increases overall stability and addresses issues in touch, pen ink, and barrel button eraser scenarios.
-Intel(R) HD Graphics 520 (v20.19.15.4463) improves system performance in some applications.
-Surface Pen Settings (v12.0.303.1) improves the stability of the pen settings and prepares for the Windows 10 Anniversary Update.
-Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller (v8.20.0.931) improves audio stability.
-Intel(R) Smart Sound Technology (Intel(R) SST) OED (v8.20.0.931) improves audio stability.
-Surface Button (v1.1.662.0) improves device usability while the device is in tablet mode.
-Surface Touch Servicing ML (v1.0.207.0) increases overall stability and addresses issues in touch, pen ink, and barrel button eraser scenarios.
alextrela
28 November 2011
3,129
How to customize the active pen settings for Windows Ink on Windows 10 Anniversary Update
http://www.windowscentral.com/how-c...ngs-windows-ink-windows-10-anniversary-update
Pen
The Pen section gives you access to a number of essential and other interesting options:
-Choose which hand you write with: Optimizes the pen experience for left-handed or right-handed use.
-Show Visual Effects: Some active pens may show a ripple effect when pressing down, you can turn off this option to disable the visual effects.
-Show cursor: If you ever used a Surface Pen or any other digital pen, you probably noticed that a cursor appears as the pen gets closer to the screen. This little element can be distracting, so now you can disable the cursor from showing when you're using the pen.
-Ignore touch input when I'm using my pen: Disables responses to on-screen touch gestures when you're using the pen; this could be useful if you're having trouble with palm or fingertip rejection.
-Show the handwriting panel when not in tablet mode and there's no keyboard attached: When enabled, clicking the keyboard icon in the notification area will open the handwriting panel instead of the on-screen keyboard.
airb
25 May 2008
15,144
Λιβαδειά
Microsoft Surface Pro 4 (Core-M, 4GB Ram, 128GB) e-shop.gr
http://www.e-shop.gr/tablet-microso...b-128gb-ssd-windows-10-pro-black-p-PER.903369
http://www.e-shop.gr/crazysundays
(Sent from Xperia Z4 tablet)
buffos
17 July 2006
675
Ενα μήνα χρήστης του surface pro 4 και το πραγματικά είμαι απόλυτα ευχαριστημένος από μέγεθος, δυνατότητες, φορητότητα με μοναδικό και ΤΕΡΑΣΤΙΟ βέβαια παράπονο την μπαταρία. Αν είχε και αυτό λυμένο πραγματικά είναι εξαιρετικό εργαλείο
alextrela
28 November 2011
3,129
Και ούτε θα λυθεί με μελλοντικές υλοποιήσεις ουσιαστικά όσο συναγωνίζονται ποιος την έχει πιο λεπτη με την μεγαλύτερη ανάλυση οθόνης.
Τουλάχιστον σε αποζημιώνει με την απίστευτη οθόνη του :p
Στο top 2 με τις καλύτερες οθόνες στο πλανήτη στο τομέα του tablet/mobile computing.
Η μόνο εφικτή λύση αν βγει type cover με extra μπαταρία που να σου δώσει 2-3 ώρες επιπλέον αυτονομία σε laptop mode εννοείται.
Πάντως φορτίζει γρήγορα και αυτό θετικό που εξισορροπεί την όχι τόσο καλή αυτονομία του και δουλεύοντας παράλληλα.
Σε αντίθεση με αλλά tablet που θες και το διπλάσιο σχεδόν χρόνο που άμα το δουλεύεις παράλληλα έως σήμερα θα φορτίζουν :flipout:
23,811
Απάντηση: Re: Microsoft Surface Pro 4 [2015]
Πόσες ώρες σου κρατάει η μπαταρία ; (μιλάω για wifi, ιντερνετ, office. Οχι παιχνίδια) .
alextrela
28 November 2011
3,129
Ενα 5ωρο πάνω κάτω σε εμενα.
Σε πιο εντατική χρήση εννοείται χαμηλότερη η αυτονομία του.
Θα το ήθελα στο 7ωρο για να είμαι απόλυτα ικανοποιημένος.
Στα περισσότερα μην πω όλα τα άλλα πάνω κάτω εκεί είναι με εξαίρεση κάποιες ειδικές συνθήκες πχ σε Samsung σε multimedia περιεχόμενο εχει πολυ καλή αυτονομία λόγο AMOLED.
alextrela
28 November 2011
3,129
Εχει δοκιμασει κανεις το SP4 με docking station; Αποκριση, lag;
Δεν το έχω τιμήσει προσωπικά έως τώρα διότι δεν μου ήταν απαραίτητο.
