Panasonic PT-AT6000
Portioli
3 June 2007
3,900
Dystopia
Νέος Panasonic PT-AT6000 (PT-AE8000 στα Αμερικάνικα φόρουμ).
Διαφορετική εμφάνιση, νεά λάμπα και έμφαση κυρίως στο 3D ( 20% περισσότερο φως, motion interpolation και νεά ρυθμιστικά).
Θα έχει ιδια τιμή με τον περσινό προβολεά, θα κυκλοφορήσει τέλη Σεπτέμβρη με αρχές Οκτώβρη.
Πλήρες το Press Release:
Panasonic Introduces New 3D Home Theater Projector with Advanced Customization Features
Brighter and Clearer Images with 3D Motion Remaster for an Immersive Theater Experience
SECAUCUS, N.J.--(BUSINESS WIRE)--Panasonic, a manufacturer of consumer and professional projector solutions, today announced the new PT-AE8000U full-HD 3D home theater projector. With 2,400 lumens of brightness and an extremely high 500,000:1 contrast ratio, this 1080p (1,920 x 1,080 pixels) resolution projector embodies Panasonic's 11 years of home theater projector engineering. The PT-AE8000U provides excellent picture quality in 2D, as well as advanced 3D features that deliver a natural and comfortable movie theater experience at home.
Hollywood Collaboration
Since 2003, Panasonic has manufactured high quality home theater projectors in collaboration with Hollywood filmmakers and Panasonic's Hollywood Laboratory. This partnership is instrumental in the development of projectors that deliver the image quality filmmakers intended. The PT-AE8000U is the latest projector to go through this process, having been fine-tuned to produce images as close as possible to directors' original intentions.
"Panasonic engineers bring us in to make evaluations and listen to what we have to say, so that when they are doing the design work they take our considerations into effect," said Steven Poster ASC, cinematographer. "I don't know of any other home theater projector manufacturers doing that at this point."
For more information on Panasonic's collaboration with Hollywood filmmakers in developing the PT-AE8000U, the company has produced a video about the process that can be viewed online at: http://youtu.be/gJ9DqG96M7s
Excellent Image Quality
The PT-AE8000U comes equipped with a new 220W Red Rich Lamp for increased red intensity and a 2,400 lumens brightness rating, which enables the projector to produce bright images and deliver stunning color reproduction. The PT-AE8000U generates deeper blacks by incorporating Panasonic's Pure Contrast Plates, which match the LCD panel characteristics, virtually eliminating light leakage. The combination of Panasonic's Pure Contrast Plates, Pure Color Filter Pro and Dynamic Iris technologies make the PT-AE8000U's astonishing 500,000:1 contrast ratio possible.
Advanced 3D Features
Improving upon its predecessor, the 5-star rated PT-AE7000U1, the PT-AE8000U ensures less crosstalk and 20 percent brighter images for comfortable and natural 3D viewing at home. In order to deliver natural 3D movement, the PT-AE8000U projector's 3D Motion Remaster feature interpolates an image between alternately created right and left images caused by the active shutter system and, as a result, enables smooth, continuous and properly positioned 3D images. The PT-AE8000U projector's built-in IR transmitter enables synchronization with active shutter 3D glasses and can transmit up to 20 feet. An optional IR transmitter offers greater installation flexibility with a transmission distance of up to 33 feet.
Users can customize their viewing experience with the new 3D Viewing Monitor and 3D Picture Balance features. The 3D Viewing Monitor visually shows that the amount of parallax in the 3D images, which varies according to screen size, is within the safe zone set forth by the 3D Consortium Committee, ensuring a more comfortable viewing experience. Using the 3D Viewing Monitor, users can also highlight positive and negative parallax within each image. Further customization is possible with the 3D Picture Balance, which allows users to see the right and left eye images side-by-side to adjust color, contrast and brightness based on the content.
"The PT-AE8000U is the ideal projector for home theater enthusiasts who enjoy customizing their settings," said Scott Wellington, senior product marketing manager at Panasonic System Communications Company of North America. "The PT-AE8000U provides several advanced 3D customization features, previously only supported in 2D, including 3D Motion Remaster, 3D Lens Memory, Keystone Correction and a powered zoom and focus functionality."
The enhanced Detail Clarity Processor 4 and Frame Creation 2 in the PT-AE8000U have been optimized for 3D images and allow the projection of fine detailed images, as well as sharp and clear images in fast moving scenes. Additionally, Frame Creation 2 is now available during 2D-3D conversion.
Installation Flexibility and Customization
Installing the PT-AE8000U is made easy with a 2x zoom lens and wide range of lens shift. The PT-AE8000U can project onto a 120-inch diagonal screen from as close as 11.8 feet or as far away as 23.6 feet. The projector can also be installed from the ceiling or mounted to a wall with +/- 100 percent vertical adjustment and +/- 26 percent horizontal adjustment.
Because many Blu-ray movies come in a 2.35:1 aspect ratio, which is wider than the projector's 16:9 aspect ratio, Panasonic's Intelligent Lens Memory automatically detects and switches the lens and focus position.
The Advanced Gamma Adjustment function has been improved in the PT-AE8000U, enabling users to control the gamma curve and more precisely calibrate the projector by adjusting brightness Y and R, G and B at any of 15 points. By using the Split-Adjust mode, users can freeze the scene and make these adjustments while comparing side-by-side with the original image.
The PT-AE8000U is equipped with three HDMI input terminals, which support DeepColor and x.v. Color, and two 12V Triggers allow more home theater automation, such as lighting and a motorized screen. Additionally, VIERA Link® provides seamless operation of multiple VIERA Link® compatible Panasonic devices by using the PT-AE8000U remote control.
Panasonic's advanced PT-AE8000U home theater projector will be available through authorized Panasonic resellers in late September or early October 2012.
Additional PT-AE8000U Information
For more information on the PT-AE8000U, please visit http://panasonic.net/avc/projector/products/ae8000/index.html or contact us at [email protected].
Contrast
500.000:1 (dynamic)
Lumens
2400
Bάρος
8.7 kg
Τechnology
3 LCD
Lens
2x powered
Lens Shift
H + V
Lamp Life
4.000 Hrs 5.000 (Eco)
Πηγή : EngadgetHD
Review από το ProjectorCentral: Panasonic PT-AE8000U
3D Home Theater Projector Review
Video By Avforums
35,671
Τα ίδια πάνελ με τα περσινά δεν φοράει? (D9)
Επειδή πλέον έχω χάσει τη μπάλα με 'κείνη τη μέτρηση on/off contrast που έχει ξεπεράσει πια κάθε λογική, θυμάται κανείς τι νούμερο δήλωνε πέρσι?
35,671
Πέρυσι ήταν πιο εγκρατής...δήλωνε 'μόλις' 300.000/1:p
Τα 200.000:1 παραπάνω φέτος που τα βρήκε? Κλείσανε 1/10 του χιλιοστού παραπάνω την ίριδα?:D:D
Βρε μυστήριο πράγμα, όμως....τα on/off να μεγαλώνουν 80 και 90% και τα άνσια να παραμένουν στα τάρταρα!!! Όταν ανεβαίνουν 5-7% γίνεται πάρτυ!!:D
35,671
Στην πράξη, απλά, δεν υπάρχουν τέτοια νούμερα, ούτε φυσικά τα βλέπουμε στην ταινία. Πολύ θα ήθελα να μάθω τι τιμές βγάζει ο Πανασόνικ και κάθε Πανασόνικ από 2 μέχρι 8 ire.
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
Panasonic PT-AT6000 3D Review
Conclusion
Panasonic have produced an excellent LCD projector which is capable of throwing out very involving, filmic images. Properly set up in an environment which will do it justice, and fed with the best Blu-ray material, we can think of few better movie-watching experiences in the home than on the PT-AT6000.
In the out of the box Rec709 picture mode, it produces high quality video, although colour accuracy isn’t entirely accurate to the Rec709 HD standard, with a strangely oversaturated green primary. As is the case with any AV product, especially projectors, the Panasonic PT-AT6000E benefits hugely from professional ISF/THX calibration, with our review sample producing more natural colour and a richer image after going through our usual processes.
In the future, we’d love to see a manual iris control – there is a Dynamic Iris in the optical path, and allowing it to be frozen and parked at an opening of the user’s choice would allow the PT-AT6000 to be better integrated into a wider variety of installations. Even when shooting images onto a large screen from a short distance (a scenario that usually runs the risk of a dimmer image), the PT-AT6000E’s images were bright, and we’d gladly cut down light output just a little to achieve better blacks (although the black level quality was certainly not bad, even without this option). We’d also love to see totally judder-free 24p 3D reproduction in the future.
Those omissions, and some slight shading issues (part of the projected image on our review unit showed a red tinge) were our only real complaints with the PTAT6000E. All in all, it was a real joy to watch, painting big, bright, high contrast, realistic, and filmic images. If you’re looking for a high quality, big screen image and are happy to go down the projection route – and treat your viewing environment in order to do a projector of this quality justice – then we don’t think many users will find fault with the Panasonic PT-AT6000.
http://www.hdtvtest.co.uk/news/panasonic-pt-at6000-201211052339.htm
