Perfect Browser !!!
22 June 2006
34,849
NEO HRAKLEIO
Ενα πολυ καλος εναλλακτικος browser για ipad.
Εχει tabs , offline browsing (μπορεις να σωσεις τις σελιδες σε wifi και να τις δεις αργοτερα χωρις δικτυο)!
Υποστηριζει gestures, font resizing, air printing, image blocking για γρηγορο σερφαρισμα σε 3G, IN-PAGE TEXT SEARCH, FULL SCREEN BROWSING και πολλες ακομη λειτουργιες...
http://itunes.apple.com/us/app/perfect-web-browser-extraordinary/id373916467?mt=8#
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Description
Perfect Browser is the fastest and most advanced feature-packed web browser to date. Experience Better-than-Desktop Class web with breakthrough features incl. REAL-Tabs, Desktop Browser Rendering, TOUCH Scroll, TV Video Out, Offline Pages, Private Mode, Precision Scrollbar, Printing, Multi-Touch Gestures, Fast Tab Switching, In-Page Search, Font Size Adjustment, Web Compression, Fullscreen & more.
ACCOLADES:
✪ "The Ultimate iPad Browser" — GIZMODO
✪ "Essential App Every iPad Owner Should Have" — eWeek
✪ Peak US #1 Top Paid App
✪ "If you're looking for desktop browsing experience, PERFECT is definitely worth considering" — Switched.com
✪ "An Absolute Must-Have App" — iPadAppsHub
✪ "iPad App Gem" — iLounge
Highlights:
✔ TOUCH SCROLLING: Automated Smooth Scrolling
Scroll through a webpage by merely touching on the up/down arrow buttons, conveniently reachable from the thumb rest position. Webpages scroll naturally and fluidly with our proprietary smooth scrolling technology.
- The Scroll Bar lets you perform instant, precision scrolling.
✔ REAL-TABS UNLIMITED
Perfect Browser provides UNLIMITED number of desktop browser tabs with ADVANCED features like background tabs.
- Tabs are rendered asynchronously and simultaneously, so it runs smooth and fast even while multiple tabs load!
- Hold down on a link to open in a new tab or a background tab.
✔ POWERFUL PRINTING UTILITY
Print web pages, documents and more from within the app.
✔ DESKTOP WEB BROWSER RENDERING
Perfect Browser can spoof user agent string and render web pages just like the target browser of your choice: Chrome, Opera, Firefox or IE! Websites shows up as if you were surfing from that browser.
Activate from Settings -> Desktop Browser Rendering.
✔ IMPORT YOUR BOOKMARKS
Switching is easier than ever! Import all bookmarks from your PC/Mac browser.
✔ FAST TV Video Out ("Rapid" VGA out)
Perfect Browser can output web pages to an external display at very smooth frame rates. Plug-n-Play!
✔ SAVE FULL WEB PAGES, ACCESSIBLE OFFLINE
Download full web pages with images directly to your device. Perfect Browser displays the exact same web pages even without an internet connection!
✔ ADVANCED MULTI-TOUCH GESTURES
In addition to pinch zoom and standard gestures, Perfect browser supports advanced gesture recognition for frequently used functions.
- 2 Finger Swipe to switch tabs
- 3 Finger Swipe to go back/forward
- 4 Finger tap: Exit FullScreen
- 5 Finger tap: bookmarks.
✔ NON-RELOADING + FAST TAB SWITCHING
Tabs don't reload when switching between them, no matter how many are open.
✔ FONT SIZE ADJUSTMENT
Adjust text size in a webpage for comfortable viewing experience.
✔ WEB COMPRESSION
Perfect Browser can compress web pages so you can surf the web 10 to 15 TIMES FAST and reduce data usage by a lot!
Eg: Wikipedia 336KB vs ~15KB
✔ FREQ-CACHING TECHNOLOGY
Perfect browser's advanced caching system reduces load times significantly (as much as 30-40%) on frequently visited websites! Cache is auto-invalidated.
✔ IMAGE BLOCKING [OFF by default]
Block image loading for upto 8x faster speeds.
✔ IN-PAGE TEXT SEARCH
- Easily find text in webpages with BIG yellow highlighting.
✔ PRIVATE MODE
Nothing is ever recorded and cookies are automatically discarded FOR PARANOID PRIVACY.
✔ FULL SCREEN BROWSING
- Utilize the entire screen to see websites!
- 40% more screen estate compared to Safari.
✔ IMAGE SAVING
Simply hold down on an image to save.
✔ LIGHT MEMORY FOOTPRINT
Perfect Browser barely uses any memory at all.
✔ WEB AUTHENTICATION
Access secure + https web sites.
✔ LAUNCH DIRECTLY FROM SAFARI
Use perfect://
✔ SCROLL WITHIN A PAGE
Use two fingers for in-frame scrolling.
✔ BOOKMARK SCRIPTS
jig
10 July 2007
1,681
Mets, Athens
Aλλος ενας πολυ καλος k γρηγορος εναλλακτικος browser με passkey lock, tabs, incognito mode κλπ ειναι ο
Terra
22 June 2006
34,849
NEO HRAKLEIO
Tελικα βρήκα τροπο να ανεβαζω φωτο Απο το iPad (τη βιβλιοθήκη του) κατευθείαν στα φόρουμ κλπ, χωρίς τη βοήθεια dropbox !
Μέσω icab browser.....
Ένα παράδειγμα....Απο το iPad 2
attachment.php
spyrmak
19 February 2007
4,748
Aθηνα
δεν καταλαβαινω και πολλα απ το screenshot
παντως ειναι θετικο το οτι μπορει να λειτουργει αυτονομα η συσκευη σε ορισμενα θεματα
( χωρις iTunes δλδ )
sfortis
Administration Team
3 August 2006
11,396
t3.large
Icab rules... Τον χρησιμοποιώ αρκετό καιρο τώρα κ δουλεύει άψογα...
softice
28 October 2007
2,078
Μια ψήφο κι απο μένα στον icab...σχεδόν ότι έχουν όλοι οι browsers τα έχει όλα. Κάποιες λεπτομέρειες λοιπουν για να είναι τέλειος.
soprano
8 January 2011
166
τρόπος για να βλέπουμε flash sites στο ipad υπάρχει. δοκίμασα ένα browser (skyfire) αλλά μόνο ta flash video δείχνει
Μιχάλης Κορ.
21,476
Πειραιάς
Απάντηση: Re: Perfect Browser !!!
Mετα απο αρκετο ψαξιμο, ενας καλος browser για Flash content σε iOS συσκευη ειναι ο Puffin Browser , ton δοκιμασα και ειναι αρκετα καλος.
Μετά το τελευταίο του update στις 15-3-2012, αυτός ο browser είναι πολύ γρήγορος !
