- 29 October 2008
- 8,993
55"...[hdtvtest.co.uk]...Philips 55OLED936/12 review
We review the Philips OLED+936 which is the flagship 4K OLED TV from the company for 2021, featuring the latest, more efficient OLED panel capable of higher peak brightness, 5th-gen P5 Dual Picture Engine, HDMI 2.1 with 48Gbps, VRR & AMD Freesync Premium support, as well as Bowers & Wilkins speaker bar.
Our Philips 936 review sample was the 55-inch screen size, model number 55OLED936/12 which is the UK 3-pin-plug version.
πηγή: hdtvtest.co.uk
Επίσης,η Philips 55_706 μέσα από την εφαρμογή AIDA64:
Manufacturer: TPV
Model : 2021/22 Philips UHD Android TV
Board : TP1M_EA_9970A
Hardware : mt5895
platform : mt5895
Installed RAM : 3GB
Total Memory : 2830 MB
Availiable Memory : 901MB
Internal Storage Total Space : 5034MB
Internal Storage Free Space : 4538MB
Core Architecture : 4x ARM Cortex-A73@1800MHz
CPU Clock Range:1200-1800MHz
Screen Resolution 1920x1080
GPU Renderer : ARM Mali-G52
OpenGL ES: 3.2
Android TV : 10
What is the difference between 706 and 806?
1.The 706 series has Ambilight on three sides and the 806 on four.
2.In addition, the 706’s remote control looks much simpler. It has no aluminum / leather trim / backlit / microphone.
3.The tv legs are different (706 chrome,806 mat), although they are almost the same in size and position.
Manufacturer: TPV
Hardware : mt5895
platform : mt5895
Installed RAM : 3GB
OpenGL ES: 3.2
Android TV : 10
