-Philips TV Line-up 2022-
xavito
29 October 2008
8,989
Philips unveils 2022 OLED TVs with brighter 'OLED EX' panel, IMAX Enhanced...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1643281984
Philips (TP Vision) has today unveiled its OLED TV line-up for the first half of 2022. 807 features a next-gen 'OLED EX' panel with 30% higher brightness, 4-sided Ambilight, Android TV, and IMAX Enhanced.
Philips 2022 WOLED tvs:
The company confirms that 807 will feature LG Display's 2022 'OLED EX' panel that was announced ahead of CES 2022.
807 will be available in 48, 55, 65 and 77 inches.
707 and will be available in 48, 55 and 65 inches.
πηγή : flatpanelshd.com
tgiamour
12 January 2012
377
xavito
29 October 2008
8,989
The Philips 807 is the world's first TV publicly advertised to carry the brighter OLED.EX panel from LG Display (LGD).
Four screen sizes are available, namely the 48-inch Philips 48OLED807, the 55-inch 55OLED807, the 65-inch 65OLED807, and the 77-inch 77OLED807.
Key features include:
P5 picture processor with Ambient Intelligence,
IMAX Enhanced support,
two HDMI 2.1 ports with 48Gbps FRL bandwidth,
full-resolution 4K 120Hz VRR (may need firmware update),
4-sided Ambilight,
on-screen Game Bar,
as well as Android 11 Smart TV platform.
OLED EX is basically an improved WBE panel with higher pixel aperture ratio thank to the elimination of some sensing lines contributing to not only 30% higher brightness compared to conventional OLED panels but also reduced bezel thickness whick makes for a very handsome design together with the metallic chrome t-bar swivel stand on the 48-inch,55-inch and 65-inch 807.
πηγή :
hdtvtest.co.uk
WBE = "EVO" panel marketing term by LG Electronics (LGE)
viper550
5 March 2008
594
Το ανέκδοτο της ημέρας ήταν αυτό. Ακόμα δεν έχει έρθει επίσημα η 806 και αυτοί ανακοίνωσαν την 807.
Μιλάμε η Philips είναι παράδειγμα προς αποφυγή σε θέματα μάρκετινγκ και προώθησης.
tgiamour
12 January 2012
377
Η 806 προφανώς δεν θα ερθει,στη Ελλαδα ήρθαν επιλεκτικα κάποια μοντέλα της σειρας του 21 απο τον Κωτσοβολο και ο Σιδηρόπουλος ειχε αναφερει πως ασχολειται με το λανσάρισμα της σειρας του 22.
Το αν θα γινει φυσικα αυτό,ειναι αλλουνού παπά ευαγγέλιο.
Reactions: den
viper550
5 March 2008
594
Μετά το φιάσκο του 21 υπάρχει ειλικρινά κανένας που μπορεί να εμπιστευτεί την Philips? Για μένα δεν υπάρχει πλέον αυτή η εταιρία. Ανακοινώνουν μοντέλα τα οποία τα διαθέτουν σε επιλεκτικές αγορές στην καλύτερη 7-9 μήνες μετά. Πραγματικά αυτό είναι ένα φαινόμενο που δεν το έχω δει πουθενά στην αγορά ηλεκτρονικών. Και πόσο μάλλον όταν μιλάμε για προιόντα που αναννεώνονται κάθε χρόνο και όχι μία φορά στην πενταετία.
Reactions: knick and den
hristoslav2
8 January 2016
359
Varna, Bulgaria
1017786
1017787
πηγή : 4kfilme.de
Reactions: enigmatiko40
viper550
5 March 2008
594
Από features μια χαρά είναι. Η Philips δεν είχε θέμα σε αυτό. Αλλού έχει σοβαρά θέματα αλλά που...δεν μαθαίνει με τίποτα.
Σκέψου τώρα. Μένεις Ελλάδα και βλέπεις την 807. Λες...γουστάρω. Αντε να περιμένω λίγο παραπάνω από τους άλλους (μιας και οι περισσότεροι αρχίζουν να κυκλοφορούν τα νέα μοντέλα ανοιξη με αρχές καλοκαιριού) για να έχω μία τηλεόραση μπόμπα.
Και περιμένεις το καλοκαίρι...και περνάει το καλοκαίρι...και έρχεται φθινόπωρο....και περνάει φθινόπωρο....και έρχεται χειμώνας και σε λούζει κρύος ιδρώτας που ακόμα η 807 παπαλα Ελλάδα. Αλλά μην ανησυχείς φίλτατε φανατικε της Philips. Η CES 2023 είναι κοντά και θα σου παρουσιάσουν την σούπερ ντουπερ 808 για να σε γλυκάνουν για τους επόμενους 8-10 μήνες.
Και βέβαια μετά άντε πάμε πάλι από την αρχή. Αυτή είναι η μόνη στρατηγική της Philips για την Ελλάδα. Αν δούλευα πάντως για αυτή την εταιρεία και διάβαζα τα σχόλια που κάνουμε εδώ μέσα πραγματικά θα ντρεπόμουν.
Αλλά τι λέω εγώ τώρα...
Reactions: den and knick
enigmatiko40
23 May 2010
443
Αθηνα
Πιστευω οτι αφου ανακοινωσε η Philips τα μοντελα τηλεορασεων στο διαδικτυο, οτι θα παρευρεθει μετα απο πολλα χρονια στην CES οπου θα ειναι και οι αλλες εταιριες.
winlink
4 July 2006
1,324
Ελληνικό, Αττική
Σε ποιά CES, του 2023 τον Ιανουάριο του '23; Αν παρουσιάσει εκεί τα μοντέλα του '22, θα συμβαδίζει με την ετεροχρονισμένη επίσης εμφάνιση τους στα καταστήματα :p
enigmatiko40
23 May 2010
443
Αθηνα
Παντως οι τηλεορασεις της Philips ενω περυσι στο συγκεκριμενο και εγκυρο site ειχαν αναρτηθει Απριλιο και Μαϊο, φετος εχουν αναρτηθει εδω και μια εβδομαδα. Δεν λεω οτι αυτο ειναι η απολυτη κινηση της σαν εταιρια να δειξει και να αναδειξει ξανα την παλαια της αιγλη, απλα, ενα σημαδι οτι κατι γινεται.
We stay tuned...
Reactions: spmk
enigmatiko40
23 May 2010
443
Αθηνα
Γνωριζουμε αν στην CES του 2022 θα παρευρισκεται και η Philips? Εχει ανακοινωσει φετος αρκετα νωρις την oled 807 και Led 8807 και θεωρρω οτι θα ειναι εκει.
Γνωριζουμε επισης ποτε θα υπαρχουν διαθεσιμες?
xavito
29 October 2008
8,989
Philips TV Overview Range Line-up_2022
55"...[fwd.nl]...Philips 55PUS8807 review...https://fwd.nl/beeld/review-philips-55pus8807-pus8807-serie-the-one-lcd-led-tv/
Display technology : LCD, transmissive
Type LCD panel: ADS , ANSI contrast of 1,216 : 1
120Hz panel με MCFI
Backlight type : Direct LED
wide color gamut (DCI-P3 coverage) : 90%
a peak brightness of 371 nits in the HDR Films image mode, both on a 10% window and on a completely white field. That's too little to give HDR images the required impact.
enigmatiko40
23 May 2010
443
Αθηνα
Εχει ξεκινησει ενα καινουριο γκρουπ συζυτησεων μεσω Telegram, οπου η αμεση συζητηση με συν-κατοχους philips oled τηλεορασεων, παγκοσμιως, και οχι μονο, αλλα και ανταλλαγες αποψεων και εμπειριων με το αντικειμενο.
Reactions: tgiamour
