- 18 June 2006
- 285
Πωλείται η παραπάνω κάρτα ήχου.
Τιμή: 70€
Περιγραφή:
Περιγραφή:
The Prodigy 7.1 HiFi from AUDIOTRAK is based on the powerful VIA Envy24HT (ICE 1724) audio controller and the Wolfson WM8776 / 8766 audio codecs, providing 2, 4, 6 (5.1) and 8 (7.1) channel support as well as optical digital I/O with 24-bit/196kHz support.
To provide stable high level output signals, Prodigy 7.1 HiFi uses a fine selection of high quality capacitors from Sanyo (SP series) and from Nichicon (up to 2200uF RU series / Nichicon ES series) to optimise the power supply of the analog and digital components on the card and to optimise the audio output quality. The special design of Prodigy 7.1 HiFi with its 4 layer PCB cuts off electromagnetic waves from the internals of the PC – there won’t be problems with an unstable power supply caused by the systems CPU or the HDD.
A separation between the analog and the digital part using an aluminium cover that shields the sound against electromagnetic waves is a major part of the Prodigy 7.1 HiFi design. Even better, the OpAmps on the card are installed on sockets, providing the possibility to change them to the users preference.
The Prodigy 7.1 HiFi driver software is based on the EWDM standard from pro audio manufacturer ESI providing perfect compatibility with Windows 2000 / XP / 2003 and even Windows XP x64, offering high performance and low latency operation with all important famous audio applications. The DirectWIRE 3.0 and Advanced NSP (Native Sound Processing) support in the driver allows you to virtually patch all your digital audio sources internally between various different software applications running at the same time and use effect plugins simultaneously. Audio streams can be transferred between different audio applications, which is especially great when using software effects, synthesizers or virtual instruments. The driver also includes support for the 3D technologies from QSound Labs in Canada: Q3D/QEM, QMSS, QRumble, QSizzle, QExpaner, QEQ and QNormalize.
Key Features
- 192 kHz 7.1 HiFi surround audio interface
- 24-bit / 96 kHz ADC with 102dB(a) dynamic range
- 24-bit / 192 kHz DAC with 108dB(a) dynamic range
- S/PDIF digital I/O with optical connectors
- High quality RCA connectors for the main analog output signal
- Up to 4 simultaneous inputs and 10 simultaneous outputs
- Special design to eliminate CPU and HDD noise
- Supports 5.1, 7.1 and other surround formats
- Professional EWDM driver based on ESI technology
- DirectWIRE support to record any signal from any source internally
- Advanced NSP support, use effect plugins to expand your sound
- Integrated headphone and microphone amplifiers
- ASIO 2.0 support for professional multichannel applications
- QSound support under Windows X
- Works under Windows 2000, XP, 2003 and XP x64
- Compatible with all major game and surround standards
- Compatible with all major professional audio applications
